As the ***le says are they suitable? They are made of nylon and are sold as a simple way to run air lines. But the questions is really can they burst and blow shrapnel up the wazoo (to use a technical term)?
I have not used them, but cl*** 5,6,7, and 8 trucks with air brakes use nylon air lines all over the truck, tractors, and trailers. I have never seen one burst, they will melt if exposed to flame, welding slag, etc. I’m just not a big believer in quick connect type fittings. It seems like after a while they start to leak air. Sent from my iPhone using The H.A.M.B. mobile app
6 years and counting in my shop. So far so good. Maybe do the first bit from the compressor with metal to help the moisture condense out.
Well a got a screaming blow out sale deal on a kit so it will be add on to my existing copper system. Or perhaps I'll run it underground into the house...
If there’s any chance that it will encounter cold temperatures with warm air from the compressor running through it then you’ll get condensation. Then if is cold enough to freeze your underground line will be toast.
Good point... but around here the ground only freezes about 3-4" deep even on a very cold day like -4*celsius.
I’ve used it for years, have had no problems. Was sceptical about he push on fittings, but they’ve held up to 135 psi.
RapidAir also offers a hard line kit. I liked the idea of the hard lines to prevent any sagging between drops. For a few bucks more, I got this 1” OD aluminum hardline kit, with 3 manifolds for the drops. The kit includes 90’ of tubing, and wall standoffs to mount the tubing.
Installed the Maxline 3/4” system in a friends shop and the 1/2” system in my garage. Both have worked well. The maxline pipe is aluminum reinforced and holds its shape well. Northern tool stocks basic kits and fittings and occasionally has sales or coupons that help on the cost.
