Technical 348 409??
Discussion in 'Traditional Hot Rods' started by u2bomber, Mar 9, 2020.
Tags:
  1. G'day, I would love to get my hands on another 409. I had a block freshly hot tanked at the machine shop back in 1997 when we had our major flood. The machine shop was next to a dry cleaner. All the nasty solvents from the dr cleaner flowed through the machine shop and my block grew fuzz in 10 days. Ended up going to s****.
    I have a lead on another that I have failed to follow up on. My high school Physics teacher from 1974 decided that he was going to hoard 283, 327, and 409 engines. He bought all my left over stuff. I should approach him about scoring a complete p***enger car 409 before it gets too late. Maybe he will want to part with a bunch of the old stuff.
  2. joel
    joel
    I paid $800 for a good 348 block and crank and a bare set if '61 heads about 4 years ago. My plan was an Edelbrock small port aluminum intake. The crank is forged; I been told all 348 cranks were forged.
  3. killbilly
    killbilly
    I have a 348 that I cant find a part # on Has a date code # of J2857 ...would this be a 65 casting year? i have looked on the 348/409 website...i have looked this block all over
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    casting date october 28th 1957. made for a 1958 model year chevy
  5. u2bomber
    u2bomber
    from california
    hey everybody ,
    good news is the motor is at my house ,so so new is not a 409 which I knew .
    I cannot get the photos to upload today but here's the skinny I believe a 1960 348
    3755011
    f8 60
    heads 3758379
    manifold 3748848?
    gm no 1
    k657. **
    carbs gn rochester 2
    one has vacuum
    one does not one has large can on side choke?
    crank 3732692. ?
    gm 23
    crank has main caps nut no rods or pistons water pump etc
  6. BLACKNRED
    BLACKNRED
    August 60 block with spark plug cooling holes, Nov 57 intake, heads will need work to get higher HP, block will have a single notch ( this is standard for 348 car blocks).
    Using 9.5:1 pistons will give a nice driving engine able to run on **** fuel with out knocking.
    Good pick up,
    alfin32 and fordflambe like this.
  7. saltflats
    saltflats
    from Missouri
    If you didn't have to pay 409 prices, then you should be good, if it is build able.
  8. BSL409
    BSL409
    Nice score!! you could always put a 4" stroker crank in and away you go:D:D
  9. vtwhead
    vtwhead
    Have you checked for cracks just below the head surface on each side. Known for cracking front to back about an inch or so below the deck surface. Had one that was pinned by a machinist. Seem to be ok.
    Have you check the p/s front tab for the suffix code? Located here:
  10. sunbeam
    sunbeam
    Back in the day I remember a lot of 58 and 59s that were tri-power 348s with 409 short blocks in stock cl***.
  11. u2bomber
    u2bomber
    from california
    I inspected the block visually around the head area.It is single notched on cylinder . as for the price I payed that's still up in the air . what is the general opinion of what I have is worth ? I can magneflux the block if the value is there ,of course I know it is essential for the build so I guess im asking for a general value of the parts I have without magneflux and if I do it . I also have the valve covers . I will try to upload the dam pics
  12. u2bomber
    u2bomber
    from california
    Its for my merc ,I need grunt and go
  13. u2bomber
    u2bomber
    from california
    Looks just like your minus a few grand lol
  14. vtwhead
    vtwhead
    U2, any chance you can give us the suffix code. A 60 block should a FE code. There were two could be an F. FA or maybe the FE which would be killer but I doubt that it is a FE. FE had a solid cam and the highest HP for a 348. If it was an Fe it would be worth a bunch of $$$$$$.:D
  15. u2bomber
    u2bomber
    from california
    I have the motor in my garage ,where is the suffix code and ill go find it
  16. u2bomber
    u2bomber
    from california
  17. saltflats
    saltflats
    from Missouri
    The suffix code will be on the right front block deck surface. Just ahead of the cylinder head.
  18. the flatlander
    the flatlander
    Was watching the Mechum auction the other night & listening to the "experts" describing the cars as they came thru. There was a nice 61 bubbletop at auction. They went on & on about how it was a "wow" 409 with trips.... idiots ! Just goes to show that all (of us ) experts are in our shop building cars. And, know something more than the wizards on TV shows....bet they caught **** for that one :)
  19. 56don
    56don
    Well, lets hope that the rich kids who bid on those cars actually have knowledge about them and ignore those auctioneers.
  20. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    alfin32 likes this.
  21. blowby
    blowby
    from Nicasio Ca
    Hey what's that opening above the timing cover that's not on SB or BBCs?
  22. u2bomber
    u2bomber
    from california
    eh
    When he pulled the cover off it while laying on the pile of other stuff and said 409 I thought ??? so I called back and he said dipstick was on p***enger side and I thought 409 or truck 348 ,when I picked it up from the old timer it didn't even have a oilpan on it ,but I am not an expert on W motors so I asked and on the 348 409 site got every drop of info I needed about the 1960 348 .and what to go after if and when I do it it would essentially be a 380cu when done
    neilswheels and partsdawg like this.
