Technical Ladder bar for open driveshaft conversion
Discussion in 'The Hokey Ass Message Board' started by GraeffSS, Mar 14, 2020.
  1. GraeffSS
    GraeffSS
    Hello guys, recently I've been researching, and i may have found a third member to convert up to '54 Chevys from torque tube to open driveshaft (If it works out i'll do a thread on that).
    Anyway, those axle use a pivoting mount instead of a spring pad, so without the torque tube i'll need a way to keep the axle in position, and the logical option is a ladder bar, but how do i build one?
    What design considerations i should have? Should it be parallel to the ground or to the driveshaft? To neither one (triangulated)? About how long should it be?
    I did a quick sketch, with no concern for dimension or angles, just to illustrate the idea:
    Edit: While doing further research, I've found out that this is called a floating axle housing. and what i need to locate it are not Torque arms, but Ladder Bars! (I changed the ***le for clarification)
  2. Budget36
    Budget36
    Don't over think it, leaf springs and ubolts have done fine, Look at 55+ years of your Chevy.
    Now if you're drag racing...
    alanp561 and Johnny Gee like this.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    You only need to remove pivot. Next drill new holes on spring pads of replacement rear so axle will sit centered in wheel opening.
    alanp561 likes this.
  4. GraeffSS
    GraeffSS
    I know the simplest way is making new spring pads and mounting the axle with u-bolts.
    The thing is: I would only be changing the differential/third member, not the entire axle, and i didn't want to mess with the mounts already in place (which have already been moved years ago to work on the '28 frame i'm using).
  5. bchctybob
    bchctybob
    I would make a bracket to bolt onto the third member with “ears” to attach a ladder bar as close to the driveshaft as practical. Then build a single ladder bar that attaches to those ears and to the ch***is exactly in line with the center of the front u-joint. It won’t be geometrically perfect in all respects but it might do what you need it to do without binding.
    GraeffSS likes this.
  6. Ebbsspeed
    Ebbsspeed
    The OP's axle uses a pivoting mount instead of a spring pad.
  7. Budget36
    Budget36
    When I read the post I made a poor ***umption he was changing out the entire rearend for another.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Wasn't poor. There was no mention it was in a 28 frame in the opening post.
    seb fontana likes this.
  9. GraeffSS
    GraeffSS
    Sorry for the confusion guys. I should have mentioned what the axle was mounted into. I did however say that i found a third member, and not a rear end, so in my view it was implicit that i was not changing the axle.
    gimpyshotrods likes this.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Instead of a solid pivot point as you have drawn. Go with a slider system (works like close drive shaft tube). Google 82-02 Trans Am Torque Arm. For now look at this.
  11. 26 T Ford RPU
    26 T Ford RPU
    If you mount the axle on a pivot mounted on the leaf spring it will move backwards when going over a bump or just adding weight in the back of the car, the torque arm mount on the axle will move forward with the same action causing a fluctuation in the pinion angle. JW
  12. 6sally6
    6sally6
    images.jpg How about something like this?!
    6sally6
  13. Mimilan
    Mimilan
    Use "Truck Arms"
    The greatest force on them is
    1: "forward thrust" to propel the vehicle. [this force is from the outside driving wheels]
    2: rotational "downward torque" from braking.
    3: pinion torque reaction.
    in ^^ that order
  14. Desmodromic
    Desmodromic
    I ***ume that what you have drawn in the first sketch is what you have now, except with a closed torque tube. This must have a slip tube, or the present suspension would not work without binding. I also ***ume the "axle pivot point" is of singular articulation and can transmit the acceleration/braking thrust through the springs to the ch***is (i.e., it is not like a shackle),
    Also, I ***ume the "ladder bar" you are proposing is not truly such, in that it, on it's own, does not prevent the axle housing from rotating, i.e., it is pivoted on top of the center section. So, what you are proposing is functionally a "four bar linkage" setup, with no consideration given to making the upper and lower arms of equal length, or parallel to each other, or to the ground. (The front halves of the springs are essentially the "lower links", and the single upper link correctly serves as replacement for both upper links.) Note that with an open drive shaft with a slip joint, there is absolutely no reason to extend the "ladder bar" to a location in close proximity to the front u-joint.
    The geometry would be better if the front portion of the spring were longer, parallel to the ground, and the upper link shortened. But I don't like the longer leaf being in compression under acceleration, and the upper link, being quite long, would need to be pretty robust to preclude buckling under heavy braking.
    I think I agree with Johnny Gee that his suggestion would be the easiest way out. Note that the axle end of the slider tube would need to be affixed to the center section, in a way that would preclude axle housing rotation about its center line, but allow very slight rotation around its vertical axis.
    Or just go to a standard parallel leaf spring system.
    All of which begs the question, why are you doing this in the first place?
    By the way, if you had told me the car is powered by a Model A banger or a V8-60, I may have had a different response!
  15. willys36
    willys36
    Here's how I did my '53 Chevy PU. Made riser blocks to compensate for removal of the factory swivel from I think 1.5"x5" rectangular tubing, had new U-bolts made at my spring shop. Drill hole in bottom of blocks to clear spring bolt, index axle. Most medium size towns have a spring shop to service big trucks. Weld the blocks to the axle.
  16. willys36
    willys36
    I put ladder bars on my leaf spring Willys, they have a slip joint in front mount made from MII front end rubber donuts.
  17. thirtytwo
    thirtytwo
    I think maybe a similar to a cal trac might be simple and easy to do also
  18. gimpyshotrods
    gimpyshotrods
    Both really great ways of turning the entire rear axle housing, along with the bars, into one giant rear anti-sway-bar.
    Might be fine for a drag car, but could make for some undesired handling characteristics on the street.
    Who wants a car that cannot corner, at-speed, for fear of m***ive over-steer?
    There is a reason why Chevy (and NASCAR) truck-arms, and Pete & Jakes ladder bars get closer together as they go forward, ending just a few inches from each other, at the front.
    49ratfink, Stogy and X38 like this.
  19. Stogy
    Stogy
    Hamber @GraeffSS, I don't have any knowledge to add here but good to see you hanging around and wrenching with the old stuff...Lots of Thinking Hambers here with knowledge to admire and glean...thanks everyone...I get most of what you and the others saying...parallel leafs and a pivoting rear end And Torque Tube...lots going on there...;)
  20. el Scotto
    el Scotto
    from Tracy, CA
    If the rearend is already on pivots you should look into a torque arm as mentioned above ala the 1982-1995? GM F-body rear suspension.
  21. GraeffSS
    GraeffSS
    I get what you're saying, i'll take it into account
    I'll keep the "Truck arm" option in mind, in case a ladder bar doesn't work
    (Responses for this one in red within the quote)
    I got this part that for a drag car, the bars can be parallel but not for the street.
    Since mine would be just street driven, my idea was putting just one bar, as close to the center as possible to avoid the "sway bar axle effect"
    Thanks, so far this seems like the best solution. I'll look into how the slider is built
    From your ideas i came up with a new sketch:
    The top bar would be adjustable (for setting the pinion angle), and the ends would be Heim joints.
    The bottom bar would have the slider on the frame attaching side, and the length/attaching point would be decided latter (I'm reading about instant center and what it influences).
    (Note: I drew the top arm that short because i believe it may hit a frame crossmember if made longer)
    bchctybob likes this.
  22. gimpyshotrods
    gimpyshotrods
    This is all a lot of work, to avoid getting/making static spring perches, and some u-bolts.
    Stogy, Blues4U, goldmountain and 4 others like this.
  23. Mimilan
    Mimilan
    Truck Arms are ladder bars [ except they point together at the front as an "A" frame ]
    Could you give us some more details about the original leaf spring pad/pivots.
    Are they floating [shackle style] or do they swivel only.
    The leaf spring and the torque tube both move different arcs, so unless one is floating it will bind.
    Does the original torque tube have a slider type driveshaft?
    He could simple add traction over ride bars like Shelby Mustangs had [pseudo 4-link]
    Stogy likes this.
  24. GraeffSS
    GraeffSS
    They only swivel, and the original torque tube was a slider type
    I looked it up, it's an interesting option, i never knew Shelbys were that way.
    I discussed the options with my father, and in the end i think we'll go with new perches and U-bolts...
    Can't blame me for wanting to do something different though...
  25. Mimilan
    Mimilan
    This is very common on Rally Cars [Leaf Link Suspension] because FIA rules required the original supension but traction devices were allowed.
    Ford Cortina GT's [Mk1] had traction override bars from the factory
    [In the attachment the upper is Lotus Cortina and lower is Cortina GT]
  26. Budget36
    Budget36
    The '82-?? F bodies used a torque arm from rearend to transmission. Also a panhard bar behind the axle and lower control arms as well. Might be a bit messier than you were thinking? It's a good compromise between acceleration and handling though.
    You could find what it looks like exactly on thirdgen.org.
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ A leaf spring suspension does not need panhard bar.
  28. speedshifter
    speedshifter
    Mimilan Yes Chev torque tube has a slip joint at front of enclosed driveshaft. Geg
  29. willys36
    willys36
    Yes. Offered in case thread starter wanted "the look" of ladder bars. Surprisingly handling with the setups is really pretty good. Easiest solution for his truck is the previous suggestion I posted.
    Stogy likes this.
  30. 38Chevy454
    38Chevy454
    The truck arms have two things that allow them to work so well. First is they angle in and the front ends are relatively close together. Second is the GM arms are I-beam profile, which allows them to twist, therefore negating a lot of the anti rollbar aspects. If the arms are tubing, they have way higher twist resistance.
    Sent from dumb operator on a smart phone
