Technical ***March 2020 Banger Meet Thread***
Discussion in 'Traditional Hot Rods' started by Jiminy, Feb 29, 2020.
  1. winduptoy
    winduptoy
    I like it when the car parts hang out in the house. Nice
    Old Dawg, Jet96 and Shane Lach like this.
  2. V4F
    V4F
    from middle ca.
    BERTS my son !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  3. My wife draws the line at this, in the house
    But, I can build another shop when I need
    J
    Old Dawg, Jet96 and winduptoy like this.
  4. V4F
    V4F
    from middle ca.
    wow john , thought you had it covered . I use kitchen because it is cleanable . good for motors & mc . at one time I had 3 motorcycles in the house . 1 behind xmas tree , one in kitchen & 1 in bedroom . no biggy ………… steve
    Old Dawg likes this.
  5. Steve
    When we started dating she found engine parts in the dishwasher
    Pistons and cylinder heads in the ovens for coatings
    Ch***is in the bedroom and dyno parts in the living room
    She still stayed around and agreed that a shop or two make sense
    So, I have two and planing number 3
    John
  6. Leadbeater
    Leadbeater
    some neat stuff and info here . ive posted this here already but hey this is the banger section. B engine duno what the body will be yet have a 31 running ch***is its goin in
    built one already had so much fun it. it has a very stock drivetrain however. time to jaz up the next
    Dustyp489, Old Dawg, Jet96 and 4 others like this.
  7. I'll try to answer your clutch housing questions, @51 mercules;
    Differences between A/AA and B/BB rear clutch housing is the bolt pattern; B/BB are smaller (which is why, an A flywheel can't fit in a B/BB clutch housing). Differences between A and AA/BB is the depth, the truck ones are shorter, making for a better fit with most conversions (T5, M40, etc). The B have the box and rear clutch housing cast in one piece, where A, AA and BB is bolted to the box.
    Differences on front clutch housings (beside affromentioned bolt pattern) are, that A is a cast one piece, where B has a cast upper housing and an extented oil pan at the bottom - and the width for the frame mounts (B being narrower; see threads on a B gear box in model A frames).
    Old Dawg, 51 mercules and winduptoy like this.
  8. V4F
    V4F
    from middle ca.
    I have only 2/3 of 2 car garage , but only one project now so its enough …….. to old to start more … good for you john ……….
  9. 51 mercules
    51 mercules
    Thank you! I appreciate it.
    Dannerr likes this.
  10. WOW! Though my wife is a "keeper", if I brought car stuff into the house she'd have my hide tanned and tacked on an outside wall of HER garage. I have to work in an offsite garage or my trailer! A house that I DESIGNED AND BUILT! Not only that; she has a longer reach than me! (LOL!) 149-4920_IMG (2017_06_30 03_13_08 UTC).JPG
  11. Johnny Nitro
    Johnny Nitro
    from Chicago
    Question for those running 12v electronic ignition, and high compressions heads:
    What spark plug gap are you running?
    Also, to those running dual 81s:
    What’s your jetting, and power valve size?
    Thanks for reading!
  12. rwrj
    rwrj
    from SW Ga
    I did a good bit of research online, settled on running mine stock, .035. Old Police head, Model B distributor. Seems to do well.
    John Heckman and v8flat44 like this.
  13. v8flat44
    v8flat44
    Love this thread. Sometimes i wanna sell the 52 Vic and take the plunge into Banger Land.
    Coulda had a deceased friends 30 A coupe for little $$$ coulda, shoulda.........
  14. brjnelson
    brjnelson
    On my 81'z I use the stock power valves & .035 main jets
    with a 7.5 :1 Winfield
    winduptoy likes this.
  15. CGkidd
    CGkidd
    Good to know. I'm getting ready to go thru mine and was planning on rejetting because it's a little rich
    Sent from my E6910 using The H.A.M.B. mobile app
  16. winduptoy
    winduptoy
    81's have a 71 power valve and 36 main jets stock as I recall. I just jetted the two 81's on my B, Crager OHV in the Vicky. It wound up with 73 power valves and 37 main jets. I am running around between 5000' and 7000' elevation routinely and I'm a little on the lean side at 7000' MSL.
    I've found that it is real common for the 81's to have 65 power valves in them because that is what is stock for the 97's
    It is also not uncommon to see EE1 bases on an 81
  17. Johnny Nitro
    Johnny Nitro
    from Chicago
    Thanks for the responses. I’m running between .035-.040 plug gap. Still seeing how that turns out.
    I have the stock setup on my 81s, but I feel like the power valve is too large. I had the rod on the “W” setting, and it would bog a tad, so I switched over to the “S”, and it is much more responsive, but I feel I could go smaller on the PV to be perfect.
    I’m also having an issue where I’ll be driving at a steady pace, and when I come to a stop the idle will stay elevated until I give the throttle a jab, at which point it will idle down. Any ideas?
  18. V4F
    V4F
    from middle ca.
    7-1 head ………. NGK …… works for me ……… steve
  19. Shane Lach
    Shane Lach
    Tossed a spare block in the car for mock up. Working on finishing the flywheel housing mounts now. All the bolts seen will be rivets btw. Just bolted for mockup.
  20. winduptoy
    winduptoy
    Well that makes my tongue stiff!
    Jet96 likes this.
  21. winduptoy
    winduptoy
    So, significance of this photo is that I got the improved oil fill tube back on it. I had lost the cap and was having a hard time finding one and I posted it on here a while back....time flies...it was last year. Well @Jet96, Grady, parted with one that he had and gave...yes gave it to me. Thank You jet96 all you guys are great. Stay safe and healthy
    Sent from my XT1585 using The H.A.M.B. mobile app
    Jet96 likes this.
  22. winduptoy
    winduptoy
    Old Dawg, v8flat44, Jet96 and 8 others like this.
  23. That is a nice looking setup right there!!
    Enjoy
    J
  24. 97
    97
    Plug gap depends on type of ignition ....electronic allows bigger gap. If you use a bigger than stock gap with points ignition it can cause a miss at high load(wide open throttle) especially if compression is stock or relatively low.
    The high idle which goes away when you jab the throttle is probably an indication that at least one throttle shaft is worn, and is sticking open slightly. That will also give you a flat spot on high load/ acceleration. High idling is because of air getting past the throttle shaft or throttle plates. It could just be a sticky linkage but most times it is wear.
    Power valves wear , they can be leaking fuel into the venturi all the time the engine is running , even if the valve itself has no reason to be open.
    Some other things that affect the way the engine runs , i.e. cause a bog, misfire, flat spot etc are float level, air leaks in the body and the air horn ( warped) , damaged gaskets, worn needle and seat, jets, blocked air correctors, blocked , worn or damaged emulsion tubes , pump plunger, and pump spring .
    I guess what I am saying is , 90% of "carburation issues" are found in the ignition , (timing) and make sure the stock carb(s) is 100% before you start changing jets and power valves. The changes might cover up issues but that is not a cure.
    These carbs are running on fuel through the main jets almost as soon as you move the throttle,....right from the idle transition, and the power valve is not only opened mechanically by the pump plunger at full throttle, they are also partially opened / activated by the hydraulic pressure of the fuel in the pump well under acceleration.
    Dannerr and Old Dawg like this.
  25. winduptoy
    winduptoy
    Bert is your son?
    brjnelson likes this.
  26. V4F
    V4F
    from middle ca.
    wouldnt that be cool ! no just telling the guy where to get wind wings ............. steve
  27. joemac05
    joemac05
    And thank you very much, I have noted all the suggestions.
  28. V4F
    V4F
    from middle ca.
    just helping out when i can ............
  29. burnzy37
    burnzy37
    Couple of banger pics from last weekend in New Zealand. Nice little gathering at my place.
    20200313_174739.jpg 20200314_122408-1.jpg 20200314_132429.jpg BDE3CBEE-A0E3-472B-BD08-B099B470C127.jpeg.jpg BAF50056-C8ED-4899-8C2B-7E0FF262990E.jpeg.jpg 20200314_122502-1.jpg
  30. Kiwi 4d
    Kiwi 4d
    Very relaxing afternoon at your cool pad @burnzy37 , pleased my wife said no to a V8 in the B4. Though it sure needs some HP help, which is a plan already happening . Hopefully it will be as lively as your banger. ​
    Greg Stokes, winduptoy and burnzy37 like this.
