Hot Rods Windshield frame fab?
Discussion in 'The Hokey Ass Message Board' started by XtechX, Mar 16, 2020.
  1. XtechX
    XtechX
    from Edmore, MI
    Anybody make their own model A front window frame?
    If so do you have any pictures or details on how you did it?
    I also have thought about trying to figure out how to make a non opening window as well, some kind of built in frame work and then glue in a windshield with a nice seal.
    Any thoughts on either method?
    dana barlow likes this.
  2. mr.chevrolet
    mr.chevrolet
    I have a 31 chrysler without a WS frame. I gathered 3 pieces of "U" channel wide enough to accept gl*** and a gasket. "U" pieces are going to be the upper section going left to right and also the 2 side pieces. then i was going to use two pieces of 90 deg angle, stretch them in a a shrinker/stretcher to fit curve of cowl. weld U pieces, slide gl*** in and then fit the bottom. wasn't going to have it open. no pics as it's in the dream stage right now.
  3. morac41
    morac41
    I made a lot of these over the years You will have to find a dealer in br*** sections ..The company I dealt with has disappeared in the last few years I had dealt with them since the early '50s... They had at least 100 different profiles plus rounds..square..angle strap U section flat bar Ect...The last time I brought several different sections a few years ago was to make new quarter vent windows for my 41 Caddy convert Br*** will chrome perfect
  4. continentaljohn
    continentaljohn
    I did a tech post many years ago for a roadster.. In the 1980s many guys in the streetrod scene glued in the gl*** with rubber molding.
    I am sure the frame can be made but with so many of them around and cheap 50 bucks or so.. you may have that in materials
  5. Model A Gomez
    Model A Gomez
    I remember an article years ago about a glued in windshield in a Model A closed car, they welded in 1/2' square steel tube around the frame work and glued in the windshield. My question is why reinvent the wheel, Model A parts are fairly easy to find and reasonably priced. New and used windshield frames are out there, the 28 - 29 are sized different than 30 -31 .
    continentaljohn likes this.
  6. RICH B
    RICH B
  7. flamedabone
    flamedabone
    Please do not glue the windshield in.
    -Abone.
    RICH B likes this.
  8. continentaljohn
    continentaljohn
    I know I sure would miss the opening window and especially on hot humid rainy days because you can crack the front window and side windows and its a nice breeze like old school A/C
    RICH B likes this.
