Projects 33’ (6) Metal Work
Discussion in 'Traditional Hot Rods' started by 33Doll, Mar 16, 2020.
  1. 33Doll
    33Doll
    Finally got some time to start on the Metal work! Took this week off to concentrate, and to “isolate” myself for a bit from all this
    TP-Corona-hoarding Insanity!
    I’m just hesitant, measure 4 times!
    Then cut! I’m a little nervous!
    This is a family car, not your average Hoopty! Wish me Luck!
    Stogy, texkbc, dwollam and 7 others like this.
  2. oj
    oj
    Pulling the body?
  3. 33Doll
    33Doll
    This plus a template once body is out of way.... then cut the nasties! Adjustments.JPG
    Stogy likes this.
  4. A Boner
    A Boner
  5. 33Doll
    33Doll
    Both sides:
    Even though the p***enger is made of bondo, its pretty close to original. Gonna leave it until I build the other side! Ok, im gonna separate the frame and body!.....Gulp! No going back now! IMG_8833.JPG
    Stogy likes this.
  6. BoogittyShoe
    BoogittyShoe
    I wish you determination and stamina. It can only get better. It's not "too" bad.
    33Doll likes this.
  7. 33Doll
    33Doll
    Thanks [emoji1317]
  8. And remember the wise words a now deceased friend gave to me when I was going to embark on a similar project when I first started out many years ago.
    "It"s only metal, trust me, you can't f#$k anything up so bad that it can't be fixed."
    Those words gave me the confidence and re***urance I needed to make the first cut. I've never looked back, but often thought about those words.
    Good luck and keep us posted.
    Stogy, desotoman53, brEad and 7 others like this.
  9. 33Doll
    33Doll
    Thanks For the Encouragement!
    Moving along quickly now! With the body up! Start with frame repair. Not that bad, just ugly!
    Made a template, and holes for reference. IMG_8848.JPG IMG_8851.JPG IMG_8853.JPG IMG_8854.JPG
  10. 33Doll
    33Doll
  11. flamedabone
    flamedabone
    It is a lot less scary once you take the plunge. Looks like you have it pretty much figured out. Has that body ever been off the frame?
    -Abone.
    Stogy likes this.
  12. oj
    oj
    Take a suggestion? Before I cut into the frame etc I would be making a substantial brace from a frame jig and bolting to some of the holes at the rear of the frame, they would be my witness points and hold things together. I see you don't have a frame jig but you can 'make do' with a substantial steel plate wider than the frame and weld some 2 x 2 uprights with a 'flag' that bolts into the frame. I'd also get rid of the rear end.
    As nice a car as that one is, its worth the effort and I can tell from your templates that you are going to do it right. I'd be making sure each of the frame horns are the same and make a jig to keep them that way before you cut.
  13. woodiewagon46
    woodiewagon46
    from New York
    You won't regret doing it the right way, the car is too nice not to. Keep us posted!!
  14. 33Doll
    33Doll
    Moving along nicely!
    Had to cut the inner piece out too!
    Luckily the traction bars, and rearend mounts are bracing it. Only the curves, and top channel are really holding it.
    Any more, and it might collapse.
    Only way to get to the back side!
    Ill weld the patch, then replace the bottom curve flat section then weld back in the inner piece, it will work.
    Ill clamp angle iron later, when i line the x member inner piece back in.
    Yeah its the redneck way, oh well. Too late
  15. 33Doll
    33Doll
    But got this far!
    Gap is a little bigger than I like,
    But Im pretty good at s***ching!
    More penetration, less warping that way. Have to move around doing it that way! Pretty good for one day though!
  16. Bandit Billy
    Bandit Billy
    I'ts a little late now but a trick one the guys taught me is to weld in the inner rail piece first from the backside so there is less weld dressing and you can shoot some rust preventative on it begore covering it up with the face plate.
    Stogy, Hnstray, 33Doll and 1 other person like this.
  17. brady1929
    brady1929
    Cool project. Good luck.
  18. 33Doll
    33Doll
    Yeah, I can do that still in reverse.
    I haven’t welded the inner in yet, cause I wanted to weld both sides but with the gap I have, probably don’t need to now, but we’ll see. I got a bunch of rust conversion juice, to paint on everything and in between.
    Stogy and Bandit Billy like this.
  19. roll of the dices
    roll of the dices
    Looking good. Keep us posted.
  20. tub1
    tub1
    from tasmania
    wonderful job your doing it will be worth the work and time you put into it its not just a car you want to replicate your family car with it is the car so much more value on a personal level
  21. sleepchamber
    sleepchamber
    Alright, alright, alright! Lookin' good!
  22. 33Doll
    33Doll
    Good as it gets!
    Now to tackle the inside!
    IMG_8853.JPG IMG_8855.JPG IMG_8858.JPG IMG_8862.JPG IMG_8866.JPG IMG_8873.JPG
  23. rusty rocket
    rusty rocket
  24. 33Doll
    33Doll
    Kicked **** Today!
    Formed some curved patches on a vice, and ball-peen hammer formed, it also hardened the **** out of it too!
    Hella strong!
    Adjustments.JPG IMG_8883.JPG Adjustments.JPG IMG_8879.JPG IMG_8889.JPG IMG_8892.JPG IMG_8893.JPG IMG_8894.JPG IMG_8898.JPG IMG_8900.JPG IMG_8904.JPG IMG_8906.JPG IMG_8911.JPG IMG_8912.JPG
    Just need to finish the bottom
    Tricky welding upside down!
    Wire wants to melt into the cup!
    Feeling Good So Far!
    Ef’ that Corona BS!
    brEad, anthony myrick, Stogy and 4 others like this.
  25. roll of the dices
    roll of the dices
  26. LM14
    LM14
    from Iowa
    When welding overhead turn your wire speed up a touch.
    SPark
    Stogy, kidcampbell71 and 33Doll like this.
  27. 33Doll
    33Doll
    Thanks! Makes sense!
    Will try tomorrow!
    Stogy likes this.
  28. 33Doll
    33Doll
    Hard to see all what I did but here is a side by side of the inside rail, before and after:
  29. flamedabone
    flamedabone
    That turned out perfect. Nice work.
    -Abone.
    33Doll likes this.
  30. 33Doll
    33Doll
    Thanks SPark! The wire speed trick Worked! Didn’t even get any boogers!
    Love the HAMB!
    brEad, dwollam, LM14 and 2 others like this.
