Technical Free 239 y block out of a f100 in a 55 fairlane
Discussion in 'Traditional Hot Rods' started by michael dunphy, Mar 17, 2020.
  1. michael dunphy
    michael dunphy
    I was just given a running EBV 239 y block out of a f series truck! I have a 55 fairlane! When I bought the car some one took the 272 out of it and I want to go back with a yblock! This one was free! What changes if any do I need to do to make it work in my 55? Not looking to burn up the road just want the yblock look and sound! And like I said it's free
    dana barlow likes this.
  2. 56 ford custom
    56 ford custom
    from Socal
    Does your 239 have the crossover exhaust pipe? Also you might want to swap out the oil pan and pick up.
  3. Chris
    Chris
    You will need a car timing cover, bellhousing (if manual transmission), front mount, exhaust manifolds, oil pan, and possibly water pump/fan set up.
    flatford39 and 56 ford custom like this.
  4. michael dunphy
    michael dunphy
    [​IMG]yeah it has the cross over pipe! The oil pan is almost flat it looks to be only a couple inch drop! The oil pan is the issue! I've found one on eBay and it's like 400 bucks!
  5. Chris
    Chris
    Yeah that tall fan won't work in your car, you need a car pump/fan. I think I have a car pan lawing around. You will need a rear sump. Be warned quite a few things about 239's are 239 only and will not interchange with later Y blocks
  6. michael dunphy
    michael dunphy
    It sounds like even though it was free it's gonna cost big bucks to make work!
  7. 56 ford custom
    56 ford custom
    from Socal
    You can find a much cheaper pan then that!!
  8. michael dunphy
    michael dunphy
    I have the trans and the bell from the original 272! I found a timing cover on eBay for 40 bucks! Now a water pump and a oil pan and sump?
  9. michael dunphy
    michael dunphy
    Chris if you have a car pan would u be willing to part with it?
  10. Chris
    Chris
    Sure, I will look and see what I have. I just s****ped a car timing cover
  11. AldeanFan
    AldeanFan
    You can put a 292/312 front dress on the 239 and use a more available water pump.
  12. Oldmics
    Oldmics
    I"m sure I have a timing cover and a pan and sump for a car if interested.Probably a used water pump you could rebuild
    Oldmics
  13. Yutan Flash
    Yutan Flash
    from Gretna, NE
    You can put lipstick on a pig...there's a reason there's not a lot of lover for the 239. I suggest selling it and put the money towards a 272 or 292 that actually came out of a '55-'56 Ford.
    Oldmics likes this.
