Hot Rods Kohler Kustom shop projects photo dump
Discussion in 'The Hokey Ass Message Board' started by thunderbirdesq, Jan 12, 2020.
  1. thunderbirdesq
    thunderbirdesq
    Bolt in motor mounts to fasten to a painted/boxed chassis, it’s a challeng to build a whole new drivetrain/mounts/steering setup on a fully painted finished car. We are using a different boxed chassis to build all the parts then they will be bolted to the car after fabrication is completed. These are gonna get a dip in the chrome tank...
    alfin32, ABONES, Deescott and 14 others like this.
  2. 4wd1936
    4wd1936
    from NY
    Hey Andy, Nice to see you are still at it. I was beginning to think you might have been kidnapped by aliens. I'll bet you could work on vintage space ships too. Might be time for me to hook up the trailer and buy another of your crazy contraptions. Best of luck, Ron
  3. nunattax
    nunattax
    nice work paint them black!
  4. All great here! Just looking for nice weather now that ski season fell apart
    Stogy and thunderbirdesq like this.
  5. thunderbirdesq
    thunderbirdesq
    On to the trans mount, I’m afraid we’ll have to lose the boling bros battery box and relocate the battery, gonna be in the way of the trans mount and 3 of the 6 stainless pipes running all the way out the back :)
    alfin32, ABONES, brEad and 13 others like this.
  6. thunderbirdesq
    thunderbirdesq
    Lots of careful measuring and gentle persuasion (portapower, ratchet straps, big hammers, small hammers, dollies, clamps, etc...) to get these quarters and roof parts to line up, but it’s starting to take shape!
    Our pal bob stopped by for a quick carb adjustment on his minty 41 Tudor. Now I happen to like 41 fords... but it’s kinda hard to imagine what the designers were thinking looking at the 40 vs 41 styling!
    alfin32, catdad49, 40LUV and 5 others like this.
  7. 383deuce
    383deuce
    Andy, Just thought I would check in on ya as it has been a while. Everything is looking cool as I see you just keep on building the cool stuff and kicking it out the door. Things have slowed down some on this end. I think turning 80 is starting to catch up with me. Seems like I like driving hot rods more than building them these days. But that's alright with me. Hope to see you on the road some day.
  8. nunattax
    nunattax
    nice panel van
    Stogy likes this.
  9. thunderbirdesq
    thunderbirdesq
    hey Dennis, thanks man, I hope you and your family are well! I can understand that sentiment with that bitchin 3w in your garage, Likewise pal, hope to see you soon, tell the gang I said hey, stay well!
    Stogy likes this.
  10. TomT
    TomT
    Agreed!
    thunderbirdesq likes this.
  11. thunderbirdesq
    thunderbirdesq
    Bolt in Trans crossmember/master cylinder bracket.
  12. fonti
    fonti
    Andy built me 2 killer hot rods till now and i can't thank him enough for all he did! Another build is getting finished right now and a promising project is waiting to get started... I am proud to call him my friend and look soo forward to the adventures to come!!
    Malcolm, catdad49, sko_ford and 6 others like this.
  13. thunderbirdesq
    thunderbirdesq
    thank you my friend! I appreciate everything and these opportunities to build cool stuff with you and all my guys who “get it” we’ve got some cool stuff up our sleeve!
    btw, Sergio’s 32 is apart and out for paint and 170c is in the shop and getting her tonneau cover fitted!
    Malcolm, catdad49 and louisb like this.
  14. dudley32
    dudley32
    My Kohler Kustoms dropped axle installed...thanks guys!!
    (got rid of the red paint)
    Stogy, alfin32, Malcolm and 5 others like this.
  15. thunderbirdesq
    thunderbirdesq
    Looks great!! Thank you!!
    Stogy likes this.
  16. thunderbirdesq
    thunderbirdesq
    Bolt in battery box that loads from the bottom, with an aluminum heat shield, yes the battery will be installed with the vents facing up during final assembly.
    7E2CE778-9515-4411-B9F7-2F9B8C84FF90.jpeg 2CC80E3B-C3ED-49DA-A74A-91FCE49D095F.jpeg
    Stogy, alfin32, Malcolm and 6 others like this.
  17. thunderbirdesq
    thunderbirdesq
    Built a sturdy little bracket to anchor the wishbone, starting to fill this chassis up! Next is adapting an f100 steering box to fit in place of the stock a box and use his factory 29 column.
    097903F7-24CC-44FE-9ED4-079F305B8756.jpeg FE7EDC3A-8174-45F0-BC8B-4B7A1D52B8D5.jpeg E6CDC797-6FE5-41C3-A9A4-B65168BEA602.jpeg
    ChuckleHead_Al, Stogy, gonzo and 11 others like this.
  18. clem
    clem
    Now all you need is some new shock mounts....
  19. thunderbirdesq
    thunderbirdesq
    Pedals in Dave’s car, built a throttle cable setup with stainless ends, ball joints and cable. 710CB1B7-7E33-472F-84A3-5D730E1679A3.jpeg DCDA01BE-CFB7-49B0-AFD8-2D5195CB98BE.jpeg
    Exhaust system for Sergio’s roadster, it’s finish welded now but I forgot to snap a pic.maybe tmw.
    f100 steering in the Brock’s mock-up chassis, still gotta check the angle in their actual car to confirm column position before finish welding the new flange. 1E6159F6-D650-49D1-A1C7-BC28B194B605.jpeg
    welded up a zillion extra holes...
    And the rockers are being fit to pats 3w. Lots of fine tuning to do in a lot of areas but it’s really starting to feel like a car!
    olscrounger, Stogy, gonzo and 12 others like this.
  20. thunderbirdesq
    thunderbirdesq
    One of the last things I had to do on Sergio’s roadster chassis before paint was finish the upper shock mounts. The t rear crossmember is pretty narrow where later crossmembers are wider toward the frame rails. This meant it was too far away to use a mount off the crossmember. The gussets first the rear crossmember also encroach on the desired mounting area. Trying to keep it pretty simple and something that looks like it could be a factory bracket, I came up with these, This is a late 32 frame with the extra frame rail wall supports around the rear rear crossmember and axle area.
    6A6BC42D-1ED8-41DA-9DAA-29DB87EB1EED.jpeg D4DEC9AB-AF66-4C03-9E5E-E9B600F0A5C7.jpeg 68FED0B2-23D8-475D-8256-3AD3C77DCC4D.jpeg 355D3E52-ABB2-4098-BD13-446BFEC7E6E2.jpeg 98F9963C-744C-425B-B5FA-A8F7B10932C9.jpeg
  21. louisb
    louisb
    Those are slick.
    --louis
    thunderbirdesq and loudbang like this.
  22. thunderbirdesq
    thunderbirdesq
    A couple dropped axles...
    E8A90BDA-319F-4136-AA6F-B92779AC1012.jpeg 181D5A59-269A-4F22-B525-CCE09E40423F.jpeg
    E brake setup on Sergio’s 32 chassis.
    549E3102-AC5E-4700-A4EB-D22A134BE86F.jpeg 5FB0BBCA-67E7-401F-AF81-A43DDA584042.jpeg 40AB18F9-B095-4DB1-8760-FCABFB23537B.jpeg
    filling in some blanks on pats 3w body.
    AED101E1-D3A7-4110-849C-000C9531A674.jpeg DBBDD871-3033-4ECD-B833-B4B76CE1FB74.jpeg
  23. thunderbirdesq
    thunderbirdesq
    066C3C37-48C5-461D-9C59-E820FC0BFEDB.jpeg E94EDD0D-A009-49ED-97E7-6E06A5B3F743.jpeg
    Working on a low profile aluminum two carb intake for romeos McCullough, trying to minimize the hood blister as much as we can. I still have to do a few things and need some longer carb stud to put it all together but I think it will work out perfect.
  24. thunderbirdesq
    thunderbirdesq
    Four freshened up 48s for a weiand four pot intake for my new 283
    B side of pats 3w fill-in-the-blank game
    Working out some more shaping and panel placement with the spare tire well on Dave’s special.
    And a bitchin piece of the puzzle showed up for a supercharged flathead going together for my buddy Garrett! 1D887D40-C4F5-4B68-BE58-722E0D2BB8BF.jpeg
  25. Always inspiring Andy
  26. Like you I am not here much anymore but love following you on Instagram.
  27. thunderbirdesq
    thunderbirdesq
    Likewise Ron, love your new coupe, looks like fun!
    loudbang and dlw1932 like this.
  28. thunderbirdesq
    thunderbirdesq
    Scratch built some progressive 4x2 linkage for the weiand wc4d goin on my 283, refreshed and restored a 39 gearbox for the Brock’s coupe, I do a few things to these to help them live a long life, this top will get a positive 2nd gear stop yet too. and we’re about to start on some polished stainless Belond-ish headers for Rich’s y block!
    DE866B4D-E940-4C11-9145-2528EC7CE6CE.jpeg D00167D8-A376-4E87-9974-5437CABF1059.jpeg
    Stogy, brEad, kidcampbell71 and 4 others like this.
  29. Nice work Andy !
    loudbang and thunderbirdesq like this.
  30. thunderbirdesq
    thunderbirdesq
    A few pic from the body shop of sergios 32, it’s almost ready for paint!
    D9AF09C5-6286-4B09-B8D4-CF9F6A74A26C.jpeg 624A0797-3E9B-4642-98B2-A8413FD4DE97.jpeg C0DFB571-35C0-45D7-B79B-2AB03D3D9B84.jpeg
    final assembly on his 201
    And some final shaping and planishing out the tail section of Dave’s special with the weaver hammer. This thing is a BEAST!
    Stogy, brEad, Shadow Creek and 6 others like this.
