Technical A-1 Cordone Parts Junk!!
Discussion in 'The Hokey Ass Message Board' started by Beachboybob, Mar 18, 2020.
  1. Beachboybob
    Beachboybob
    from california
    Folks, I don’t make it a habit of slamming companies, but I feel obligated in this case to alert Old Ford owners of the totally unacceptable part quality I received from A-1 Cordone. I finally realized how foolish I was to not question the proper operation of a Remanufactured 1957 Fomoco Distributor to improve advance management of my 1954 239 V8 after a professional mechanic wasted five hours chasing multiple causes for intermittent spark at the plugs. After reading a thread from another 50’s Ford owner experiencing the same problem with A-1 Cordone parts, we removed the purchased distributor and investigated every aspect of it. We discovered both the condenser AND points to be SO POORLY constructed (China!) that they failed to produce a consistent, strong, controlled electrical signal from the coil. Exchanging this JUNK for original, American Made Points and condenser out of a ‘64 260 engine resulted in the 239 Engine starting instantly and running like a clock. Obviously, there is NO QUALITY CONTROL AT CORDONE! They don’t even know if their parts work! AVOID THEM! Spend your hard-earned money elsewhere with a reputable supplier! This distributor was NEVER TESTED before being sold! It cost me five hours of mechanics time! I could have bought a NOS distributor for the money wasted in discovering that the Cordone unit was JUNK!!
    Bird man and lemondana like this.
  2. CyaNide
    CyaNide
    from Texas
    It’s Cardone and their stuff has been questionable for years. I used to sell parts and they were the big supplier for reman parts. Especially hydraulic parts were prone bad out of the box. Hopefully you kept the core.
    CN
  3. leon bee
    leon bee
    Enough of us know all this **** that I don't think a pro mechanic woulda taken 5 hours to discover the junk.
    mrhp, 5window, deathrowdave and 11 others like this.
  4. arkiehotrods
    arkiehotrods
    It is pretty well known that points and condensers made in China are garbage. Little bit surprised your mechanic took five hours to figure that out. Last several sets of point and condensers I bought from local parts store were junk. Other than NOS, NAPA is one of few places where quality points and condensers can still be found (Echlin).
    A lot of other people think Cardone stuff is junk
    https://www.google.com/search?q=car...rome..69i57.4151j0j8&sourceid=chrome&ie=UTF-8
  5. jimmy six
    jimmy six
    I bought a Cardone 57 replacement 8 yrs ago. I measured all of it according the original 56 to determine if it was correct demsionally. It was correct. It’s condenser failed in 3 months, the one I purchased failed in 4 months so I installed a Pertronix ll and it’s been perfect.
  6. Beachboybob
    Beachboybob
    from california
    Wow! I didn’t know there were so many Indy-car mechanics on this forum! A well known Y- block builder didn’t tell us the distributor was junk when I described the symptoms and what we had done to isolate the problem! I’ll admit I’m not a pro mechanic!
    Glad everyone knows about Cordone! Thanks for the replies!! Best!
    5window and stillrunners like this.
  7. leon bee
    leon bee
    I realized after I posted that I guess now you can be a real mechanic and not know anything about points and condensers. I often forget I'm an old geezer.
  8. Ebbsspeed
    Ebbsspeed
    True.
    Also true. Probably very little if any experience with points/condenser ignition. The "professional mechanic" probably also spent quite a bit of time looking at that funny thing on top of the motor with an air cleaner on top and a fuel line going into it.
    Carburetors were still on cars for quite a few years after the points and condenser were replaced by electronic ignitions.
  9. Beachboybob
    Beachboybob
    from california
    I’m just teasing you guys a bit! No worries, mates! I forgot to tell you that this ‘54 Ford had sat 13 years in a garage, with only 61K miles. We had to rebuild the generator, fuel pump, carburetor, and clean up the original plug wires . These fixes, in addition to upgrading the distributor for better control of spark advance, presented lots of possible causes for the intermittent spark. We admittedly made a mistake in ***uming the distributor was good. Discovering our mechanical foolishness was not only a bit embarr***ing, but we were P.O’d that Cordone created the misconception that the distributor should be fine, since it was rebuilt. That was a lesson learned, albeit one that prompted me to alert others to their poor part quality!
    Cheers, Guys!!
    Bob
    pitman, VANDENPLAS and JeffB2 like this.
  10. 56don
    56don
    I used to work at an auto parts store a few years back. I found out that Cardone was junk then. Their so-called "rebuilt" alternators were only used ones that were cleaned up and replaced only the bad parts like the bearing or the diode, the rest was just a used alternator.
    VANDENPLAS likes this.
  11. Budget36
    Budget36
    Shhhh, don't let my kids OT V8 Chevy here this, her distributor has been in the car for a year without issues.-cardone special via Amazon.
  12. 41rodderz
    41rodderz
    from Oregon
    I appreciate the post. Eyeing RockAuto lately, I had seen one of their options was Cardone parts . You just saved me money and headaches. Never bought a Cardone part . I buy from Napa and I guess there is no reason to switch.
    arkiehotrods likes this.
  13. leon bee
    leon bee
    I'm a NAPA guy, too. So far Echlin hasn't let me down, maybe I'll go get some more to hoard.
  14. tb33anda3rd
    tb33anda3rd
    not just cardone, N.A.P.A., mail order, auto zone, etc... you NEED to check every new part from every source. I have found the wrong part in the right box, handling damaged correct part, old core in new box, right part that doesn't fit or needs to be fitted, quickly failed part, part breaks when installing, fails visual inspection, etc..
    the ratio of "problem" parts to no problem parts is about 6 issues out of 10.
    Budget36, RMR&C and egads like this.
  15. This ****s.
    It’s happening more and more with my work also, new parts junk out of the box.
    tou find the issue, replace the part and the issue is still there!
    Especially in your situation where you did a bunch of stuff at the same time.
    So now the diagnostic process starts all over again, but ***uming the “ good new part” is just that..... GOOD !!
    adds time and headaches to all.
    ****s you bought junk, but glad you figured it out.
    warhorseracing likes this.
  16. Aaron65
    Aaron65
    from Michigan
    I just replaced the leaf spring bushings in my '65 Dart, and the eye bushings came with new bolts and nuts. One of the last things you do on that job is put weight on the springs and tighten up the eye bushings and shackles. Well, the threads on one of those new eye bolts stripped right out at about 45 lb./ft. Sooooo, I dropped the spring, cleaned up the old bolts, and slapped it back together. It's getting pretty sad...55 year old bolts are more reliable than new.
  17. bobss396
    bobss396
    I've had poor results even with NAPA parts I got for my Ford, so I stopped going there entirely, but they do have a carb cleaner I like...
  18. bschwoeble
    bschwoeble
    I caught hell on another thread for writing that nothing from China is made to last. N O S parts at swap meets keep going up in price. It's no wonder.
    nunattax and Gasser 57 like this.
  19. town sedan
    town sedan
    To paraphrase James Evans from Good Times "how can you know where you're going if you don't know where you've been."
    A-1 Cardone use to be a good brand, but in the 27 years I've been selling auto parts they're reputation has been going down. Actually it's hard to understand why any auto parts suppliers still deal in our antique stuff. Anymore good used properly rebuilt parts are the best. I like the old Ronny the Raygun's philosophy of trust but verify. That's one reason why I always boil a new thermostat with a thermometer in the water.
    -Dave
    kadillackid and warhorseracing like this.
  20. 41 GMC K-18
    41 GMC K-18
    I used to work in an auto parts store when I was kid in the 60's, back when there was a big rack of books rather than a computer. I remember when delco-remy parts came in very cool thick paper boxes with metal tops and bottoms and the container was sealed and it had a string you had to pull to open the box. Such packaging these days would be cost prohibitive. Not that the packaging had anything to do with quality control, or that it was an ***urance that the part inside of the box was correct, but it was an indication that the manufacturer cared enough make sure the product was protected and that when you opened the box, you were the first one to open it. Those days of good parts and quality control are long gone!
  21. 41rodderz
    41rodderz
    from Oregon
    Well I know my Dad had problems finding quality rotors that the usual parts stores carried .
  22. Beachboybob
    Beachboybob
    from california
    Thanks to Everyone for taking time to comment! They support testing of acquired parts for this old Ford in the future before installation.
    Oh! My apologies for repeatedly misspelling CARDONE!! I missed the point in one of the early threads! Yeah, I know....now you're thinking I might be half the problem!! There’s always that possibility!!!
    I’ll post some photos of this survivor ‘54 Crestline once we get it cleaned up. It’s a time machine! It still has the ***embly line markings on the firewall. The interior has always been covered with blankets. We now await Concours Parts restocking of the gas tank specific to this year. Thanks again! Bob
    warbird1, arkiehotrods and egads like this.
  23. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    Bought car done steering gear for '71 K5, had to take it off and install a second unit...blew fluid all over the place too.....and look how spell check made their name come out. It's obvious even to a computer...
    tb33anda3rd likes this.
  24. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    If I may address this. I deal with just this issue for an OEM I work for and it's mostly societal change. With the elimination of vocational arts cl***es in schools for the last 2 generations, the end result is "kids" today don't even have an adult (let alone father figure) who can p*** on automotive knowledge and skills. Since there's 2 generations that can't work on NEW cars, that leaves all us old farts working on our dinosaurs. Rebuilders really have no choice but to support us..... there's no other market left (other than wholesale jobbers). Little Billy doesn't know how to diagnose a bad crank sensor (and sadly enough, most of us don't either or don't want to learn).
    If it wasn't for YouTube, they'd all be walking......
    X-cpe, pitman, kadillackid and 3 others like this.
  25. arkiehotrods
    arkiehotrods
    I was just getting ready to tell you that since you have now opened this can of worms, we need to see the '54. Looking forward to seeing some photos!
  26. Gasser 57
    Gasser 57
    from New Jersey
    No conversation about garbage aftermarket parts is complete without including Dorman. Hard to believe they haven't been mentioned yet. I try to buy oem parts when I can now but to be honest, even they aren't what they once were.
    OLSKOOL57 and Truckdoctor Andy like this.
  27. sport fury
    sport fury
    I will never buy rebuilt brake components from BBB industries. they rebuild brake parts for AutoZone. their technical customer support was very disappointing. I still buy from AutoZone but not their rebuilt brake parts. better off keeping your cores and rebuilding them.
  28. G'day, I used to work at one of the big box store automotive places. I had so many issues with A1 Cardone power steering parts. I had one customer go through three power steering pumps for the same vehicle. After I switched to an AC Delco dealer I sold him one from there. Seven years later it is still working. A1 Cardones power steering stuff does have questionable quality.
  29. manyolcars
    manyolcars
    I ordered a rebuilt water pump from ebay because I wanted a rebuilt made in USA pump and they sent me a NEW chinese pump. Cardone ****s and their distributor uses points and condenser that have no replacements, Once the points are used up you have to buy another distributor. Does anyone reline brake shoes? I'm ready to put my old shoes in the s****
  30. many years ago, Arrow and Champion also made questionable rebuilt starters, alternators, etc. After going through 4 rebuilt starters in less than a month, the auto parts person said, "why don't you buy a rebuilt Delco starter " I asked how much difference was the cost. He said about $ 5.00. I asked why didn't he sell me that in the first place ? He said, I thought you wanted to save some money. After installing 4 starters out in the driveway in January in the winter in Connecticut I was not a happy camper. The extra $ 5.00, was well worth saving the aggravation.
    Beanscoot likes this.
