Hot Rods # 10 Track Roadster Build- Marty Strode
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Jan 24, 2020.
  1. AmishMike
    AmishMike
    Justice brothers - thanks for the reminder. Have to get to Duarte Ca. To visit there great car museum again. Not the largest but great collection & price is right - free. Wonder if still open during national virus
  2. Blues4U
    Blues4U
    from So Cal
    CA's on lockdown now. We're only supposed to go out for essential goods & services. I don't think this would qualify.
  3. Marty Strode
    Marty Strode
    I built it in 2014 with a blown Flathead, and switched to Ardun power in 2017. It's now is a Lakester, after a 19" lengthen job and a new body. IMG_0683.JPG IMG_3303.JPG IMG_3295.JPG
    dwollam, catdad49, 1947knuck and 9 others like this.
  4. Marty Strode
    Marty Strode
    Dean, I wish I could run one like you !
    1947knuck, cruiserjohn76 and Stogy like this.
  5. Dean Lowe
    Dean Lowe
    Yeah, you learn a lot playing with machines for 52 years.
    catdad49 and Stogy like this.
  6. Marty Strode
    Marty Strode
    Got the brake rocker arm ***embly tacked in place, and the pull rod connected. Rather than machining bungs, I sometimes turn down hi-nuts or rod connectors for that purpose. Once fully welded, there will be a gusset on the threaded tube. I can't complete the pedals until I get the br*** bushings for the pedal shaft. These are 35-38 pedals. IMG_4425.JPG IMG_4426.JPG IMG_4429.JPG IMG_4430.JPG IMG_4431.JPG
  7. RICH B
    RICH B
    Curious on how determined the ratio of the rocker arm.
    Stogy likes this.
  8. Marty Strode
    Marty Strode
    Rich, The pedal length from center of pivot to center of the pad is 13", it will be shortened 1", to 12", and the arm that connects the linkage is 3". Divide 3 into 12 =4 to 1. The ratio of the rocker arm is 1.466666 times 4 = 5.864. This has proven well with a 1" master cyl in these cars. However, it is simple to change ratios by changing the blades on the rocker arm. Thanks for the question. IMG_4432.JPG IMG_4434.JPG IMG_4435.JPG IMG_4439.JPG IMG_4438.JPG IMG_4441.JPG
  9. RICH B
    RICH B
    Thanks! Good tech info and nice re-use of mechanical brake pedals.
    Stogy likes this.
  10. Marty Strode
    Marty Strode
    The main reason I use them is, the tight space and the the clutch pedal, eliminates the use of hydraulic pedals because of the master cyl location. The fact that no one uses them, makes them dirt cheap.
    catdad49, dwollam, 1947knuck and 3 others like this.
  11. studebakerjoe
    studebakerjoe
    Marty, they were dirt cheap till everyone sees your ingenious solution.
    catdad49 likes this.
  12. Marty Strode
    Marty Strode
    Oh Yeah, another reason I like them for this application is, with the master cyl moved back under the seat, the floor is clean of access doors or removable panels. P1010134.JPG
  13. rottenleonard
    rottenleonard
    Marty, you may be past this already but I was up in one of my sheds just now and ran across a couple of tank ends. These must have been from when we were still prototyping but they look pretty good. If you want them for the project I'll send them over.
    ATTACH=full]4614277[/ATTACH]
  14. Marty Strode
    Marty Strode
    Last night, I bent the back end of the rear arms, cut the ends off and tacked in the bungs. I am certain that some on here will debate the reliability of using this style arm, but I have them running with lot of miles, and some track time to boot. The weak point is the eyelets that bolt the arm to the housing. The plan is to reinforce that area. With the placement of the fuel tank, it's difficult to employ a torque arm, just offset of center, as is recommended. Going forward, one thing that might be a problem is drive line angle, with the pinion shaft centered vertically. Rough measurements show a 16" driveshaft, the pinion is 2-1/2 to 3" higher than the output shaft at the trans. All of the rest of these I have built, either had quickchanges or 9" Ford rears with the pinion 2" or lower from center. As a last resort, Bruce (Mr. Quick Change) will get his wish ! Take care, my friends. IMG_4442.JPG IMG_4446.JPG IMG_4444.JPG IMG_4449.JPG IMG_4450.JPG IMG_4452.JPG IMG_4453.JPG
    dwollam, catdad49, 1947knuck and 11 others like this.
  15. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    A V8 Quickchange lowers the rear yoke 3".
    A Boner likes this.
  16. Marty Strode
    Marty Strode
    I know, I know !
  17. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    You brought it up :D
    Stogy, Dick Stevens and OFT like this.
  18. 1-SHOT
    1-SHOT
    from Denton
    Do you make a kit of all the brackets and list of parts needed to build #11 ?thanks Frank
    Stogy likes this.
  19. Bandit Billy
    Bandit Billy
    Marty, I get the whole "old school" tool thing but a 10 key adding machine? C'mon! I'm a little surprised it doesn't have a handle on the side. :cool:
  20. Blues4U
    Blues4U
    from So Cal
    I've got pretty much the same thing on my desk, different brand, maybe a couple different features, but basically the same thing. I see no need to replace it.
  21. Marty Strode
    Marty Strode
    Billy, It's kinda like North Korea out here, were going to get Betamax next year !
  22. Marty Strode
    Marty Strode
    Frank,
    I never have put a kit together, however I had some of the parts laser cut. If I had found the HAMB 20 years ago, to connect with people with a real interest, and willing to build something, it would have been far different. I mailed a lot of these out, with not much response. IMG_4455.JPG
    dwollam, AndersF, catdad49 and 9 others like this.
  23. stillrunners
    stillrunners
    from dallas
    Nice to follow - great work going on there !
  24. Marty Strode
    Marty Strode
    Over a month ago, I mentioned getting a better camera and setting up a tripod to improve the photos I take. Shortly after, I get a call from Rooman, to talk about Track Roadsters. He mentioned he had an extra camera, and he would put together a package and send it to me. The big brown truck showed up today, and delivered this. I had a nice tripod, so as soon as I get the proper photo card, we should see some improvement in photo quality. I don't have visions of grandeur, being the next Steve ****an. Thanks Keith, my friend. IMG_4236.JPG IMG_4456.JPG IMG_4459.JPG
  25. Marty Strode
    Marty Strode
    I welded in the gussets for the rear kick up, they were sawed out of 3 X 1-1/2 tube. IMG_4462.JPG IMG_4463.JPG IMG_4466.JPG
  26. woodbutcher
    woodbutcher
    :D Hi Marty.Looking good Sir.I`ll saddle up and go along eor the ride.
    Good luck.Have fun.Be safe.
    Leo
  27. lake_harley
    lake_harley
    Marty.....Were the numerous roadsters you've built done to about the same wheelbase? I printed a side-shot photo of your red #7 roadster and have it thumb-tacked above my computer for inspiration. I made an attempt to determine the wheelbase by roughly scaling it and figuring that the body is about 49" from the firewall to the back would put the wheelbase right around 99". Is that close?
    Thanks
    Lynn
  28. bigblockdan
    bigblockdan
    Marty - love following you on HAMB - great stuff. Need to catch up to you and Ernie this summer.
    Time is a flyin!
  29. Marty Strode
    Marty Strode
    Lynn, your figures couldn't be much closer, the 25 and older bodied cars have 100" wb, like a stock "T". The 26-27 ch***is I built was 103.5 like a model A. The big difference being, on a 26-27, the body dictates the rear axle location, whereas on the early ones the rear axle can shuffle forward, and look OK. I started out with a 27 steel body, and wanted something similar to the Don Turner car pictured below, for the street, but with the amount of engine set back, I couldn't make it work. 2012-07-10 180022.jpg
  30. Larry Anderson
    Larry Anderson
    They finally shut us down at the truck plant yesterday, now I have time to get caught up on this thread and the roadster p/up build. It's all up to you to keep us going through this quarantine Marty...
    Sent from my SM-N950U using The H.A.M.B. mobile app
    catdad49, brEad and AChopped1950ford like this.
