Technical Camber problem
Discussion in 'Traditional Hot Rods' started by Mike Colemire, Mar 20, 2020.
  1. Mike Colemire
    Mike Colemire
    I put a mopar wavy axle under the front of my plymouth 33 project, transverse spring behind axle with a model A crossmember and hair pins. I put new king pins and bushings in, everything is good and tight. My problem, tires are leaning in at the top, negative camber, my question is, is there anyway I might have installed the spindles on opposite sides? I wouldn't think it'd cause this, the steering arms bolt at the bottom of the spindle, the stops are in the front. It was apart for a long time, had them marked but some where along the line the marks are gone. Maybe it was that way to start with, I don't know but before I go to heating and bending thought I'd ask. Any other ideas on me screwing it up another way?!
  2. Jokester
    Jokester
    pics??????????
  3. -Brent-
    -Brent-
    Mike, how many degrees are we talkin'?
  4. Mike Colemire
    Mike Colemire
    I don't really know how many degrees, I need to find a gauge that goes on the center of the hub like dirt trackers use. I guess I could put a straight edge, level maybe, and use an angle finder and get an idea. I'll try and get some pics.
  5. Mike Colemire
    Mike Colemire
    Just using an angle finder it looks like they are 5 degrees in at the top.
  6. Penetrator
    Penetrator
    from SK CAN
    Knee jerk reaction... wrong spindles.
    Ned Ludd and Mimilan like this.
  7. Mike Colemire
    Mike Colemire
    They were the spindles that came with the axle and they had been on there for years.
  8. dana barlow
    dana barlow
    from Miami Fla.
    If you didn't have that camber before, using the same parts** other then pins,you must of rolled over/upside down, the spindles ? Or the axle is bent in center? If not they wrong already some how
  9. sunbeam
    sunbeam
    Are the spindles right side up?
  10. Mike Colemire
    Mike Colemire
    I would think so, the spindles have 2 1/2 inch holes on the bottom for the steering arms to bolt to, upper holes are a lot smaller. The stops are on the front and serve to hold the king pin also, they are threaded. The only thing I could think of is I could have switched sides but I don't see that causing this. There is no damage or dents in the axle.
    gregsmy likes this.
  11. maneri
    maneri
    from ohio
    brakes/stops should be in back side ---looks like mopar or after market axle -what's the bolt pattern??
  12. Mike Colemire
    Mike Colemire
    Mopar axle, 4.5 BP.
  13. alchemy
    alchemy
    If spindles were upside down, it would be off many degrees. Are you sure the spindles had a good alignment before? Just because they were already on it doesn't mean they had a good camber. Maybe somebody just threw some Mopar spindles on the axle that had the same size kingpins. I know that some early Fomoco products had spindles that looked the same, but had different inclinations.
    ras, norms30a, Ned Ludd and 3 others like this.
  14. dwollam
    dwollam
    Looks like you made the same "mistake" I did on my '33 Plymouth Coupe. I used a '38 Dodge wavy tube axle and retained the 11" drum brakes. It looks like you have hairpins on your axle with a Model A type front spring. That's what I did and showed on my thread on here and several people told me it was wrong and dangerous! They said go either parallel leaf or 4 bar on a tube. hairpins ok on an I beam. I still haven't changed it or made up my mind but it's not ready to be driven yet anyway. Now back to your problem. I have two 1933 wavy axles and both those and my '38 axle have the stops on the back side of the axle. That's stock that way. There is something wrong on yours for sure. The tires should be in at the top.
    Usually the calipers are to the rear of the axle.
    Dave
    woodsnwater likes this.
  15. Fordors
    Fordors
    The spindles were on the axle but did you ever see wheels and tires on the axle? I looked high and low for alignment specs for early Mopars, I have seen it before but can’t find it now. IIRC there are different KPI’s on various Mopar spindles. Could you have an axle from one car and spindles from another? Or do you know for sure those parts were always together?
    Try contacting Rusty Hope and see what he knows about the two spindles that look like yours, do they have different king pin inclination?
  16. Desmodromic
    Desmodromic
    Despite the current issue of Hot Rod magazine's claim that it doesn't matter, I agree the calipers should be on the back. If front mounted, they can triple the load on the spindle's axle and bearings in a hard stop.
  17. mkubacak
    mkubacak
    I am not saying I do not believe you, because I have no idea how it works. Please explain how the location of the calipers changes the force applied to the other parts. My feeble mind sees it as a being applied to one spot on a circle a fixed distance from the center.
  18. Mr48chev
    Front or back mount on the calipers doesn't really matter outside of ascetics. It isn't going to change the stopping power it just looks like hell if you don't have fenders to cover it up.
    The question is: did you actually run that axle and those spindles or are they something you acquired years ago and stuck back until you could use them?
    Reversing side to side won't have any effect on camber, installed upside down would have a drastic effect.
    Wrong king pin inclination setting for the spindles would have a big difference but you would have to go year by year through the Mopar alignment specs and find out if there is a difference between say 32 and 36/7 I'm not well enough versed in early Mopar to know right off hand. I'm not sure when they swapped from mechanical to hydraulic brakes but that may have been the cause of a spindle swap.
    Johnny Gee likes this.
  19. -Brent-
    -Brent-
  20. sunbeam
    sunbeam
    Are your sure look at post 21 With out a good picture it's hard to tell but the top of the spindle the king pin hole will be farther away from the brake backing plate. https://www.jalopyjournal.com/forum/threads/dodge-wavy-tube-axle-can-i-fit-ford-spindles.179346/
  21. RICH B
    RICH B
    Hard to tell in the picture; was more stuff cut off the axle than the original spring saddles? Heat possibly could have pulled the tube. I'd pull the wheels and hubs off, level it across the top of the spindles, and get an accurate measure of the camber off the face of the spindle on both sides. Once armed with that info, should be able to tweak the axle back in compliance on a press. Looks like you batwing brackets are just tacked; maybe finish the welding, that could pull the tube around too.
    thunderbirdesq likes this.
  22. Mike Colemire
    Mike Colemire
    As far as the calipers, they will work front or rear, I never ran this axle, it came with the body, the stops were on the front of this axle, as I mentioned, they also screw in and hold the king pin instead of the wedge deal like ford has. The axle had been together for a long time, it had traces of that old grease like they used years ago, it was hard as a brick. The best I can tell, the spindles and maybe the axle to is out of a truck. I'm going by the pic on Rusty Hope's site on that. I've found several specs on camber, + 1/2 in, to 1/4 to 3/4's. I would think you would want them closer to 0 but I'm not sure on that. Thanks for all the help, I'm going to try and get time to fool with it tomorrow. I like the looks of the old wavy axle but I wish I'd went with ford.
  23. Mike Colemire
    Mike Colemire
    Also, I was going to go with ford spindles but I read where you could have a camber problem.
    RICH B likes this.
  24. jaracer
    jaracer
    What happens to the camber if you roll the axle backward to give it more caster? Does the camber improve?
  25. Mike Colemire
    Mike Colemire
    No, I went both ways, no change. In the pic it's at 6.5 degrees tilted back.
  26. 2OLD2FAST
    2OLD2FAST
    from illinois
    I'd wasn't the calipers on the rear if for no other reason , to keep the brake hoses shorter and out of harms way closer to the frame ....AFA the camber ,
    I'm betting in the spindles being the problem ..
  27. Fordors
    Fordors
    If it was mine I would pull the spindles and get the ends of the axle on top of the king pin bosses as close to the same angle- if one reads 8* you want the other one to read the same with your angle finder. If they are at least close that will at least give you an idea of the king pin boss angle.
    Next check a spindle, with the stub axle level what does a king pin read? That is your KPI- king pin inclination.
    As an example, an 8* axle and 4* KPI will give the result you have. I still haven’t found the specs but I believe there are Mopar spindles like you have that have different KPI’s.
  28. dwollam
    dwollam
    The Dodge trucks had I beam axles just like in my '36 Dodge pickup. Cars had tube up through 1933, then '34 was independent, then back to tube in '35-'38. I'd have to say if the spindles were already on the axle and the stops are in the front, the axle is in backwards.
    Dave
    mrhp likes this.
  29. Mr48chev
    Backwards/frontwards isn't going to affect camber. changing caster on that axle shouldn't change camber because it isn't the same as changing shims on an A arm or other independent suspension caster/camber adjustments where changing one changes the other.
    I can play with an axle I have clamped in one of those black and decker work stands tomorrow and stick one of ( or each of) my gauges on it but I'm positive that won't change.
    I'm still thinking that A a previous owner swapped spindles to have some that worked with better brakes or B the camber got changed by work someone did on the axle at one time or another. I could believe that more if it didn't match side to side though.
    studebaker46 likes this.
  30. Mr48chev
    This is out of my 1946 Motor manual Showing the alignment specs for 35/46 Dodge IMG_9152 (1).JPG
