Technical What’s your set up for pressing wrist pins look like?
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Mar 21, 2020.
  1. I have some tools I made to remove the old pins,,,,is that what you’re asking ?
    Tommy
  2. squirrel
    For installing them, I generally have the machine shop use their rod heater.
  3. jimmy six
    jimmy six
    The palm of my hand. I use only floating pins and stock GMC rods are pressurized thru the rod. But on my custom Cunningham’s or ****’s for our dirt track engines, I use my left palm... I’m left handed.
    For removing them my left thumb works well or if they are stuck I put on a socket and hit it with a mallet as I hold the piston in my right hand.
    302GMC likes this.
  4. hemihotrod66
    hemihotrod66
    I don't press them just heat the rod end and they drop right in...
    flatford39 likes this.
  5. G'day, I let the machinist press all pins in for us. As far as removing them we have a simple frame attached to the bench with a 12 ton hydraulic jack on it. Pops them out quite easily. Pins go in the s**** steel barrel and pistons into the s**** aluminum barrel. Rods get wired together by set and put on the shelf for future use. All Chevrolet stuff.
    A couple of years ago we did haul in about 200 sets of rods, manifolds, heads, and a bunch of 350 4 bolt blocks. Got tired of people offering s**** value for good parts.
  6. I’m sorry,,,,,I was always told not to press them back on,,,,,only use heat to install .
    That was why I was asking .
    I guess the old guys that told me were right after all .
    Tommy
  7. 302GMC
    302GMC
    from Idaho
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
  9. My set up looks like this, I drop them off at Boeser Machine in Aviston Illinois and let Dan do his thing.
    Lloyd's paint & glass likes this.
    Deuces likes this.
  11. sunbeam
    sunbeam
  12. Ok then show me your machinist’s set up
    I need to swap some really nice nearly newSBC KB Dished pistons for some KB flat tops on some really nice nearly new eagle rods.
    installing the pin with freezing and heating the rod is really easy. These silly things do not have a good surface to block off of for pressing the pins out.
    We’d probably like to sell these really nice nearly new dished pistons
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Couldn't you make a custom backing devise of sorts?
  14. More than likely I probably can but what’s it look like ?
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    You have the pistons to go by so I don't know? Pic's?
  16. Budget36
    Budget36
    I can kinda describe my shops set up. They lay two rods in a fixture that electrically heats the ends. I've seen them do this, seems to take about 10 minutes to just drop the pin in with light tapping. They have different "shims/etc, depending on the piston diameter. I looked into one of the heaters a few years back, seems to me used was in the 500 range, out of my league for as often as I'd use it.
  17. 71FC3E23-87F8-45D1-8025-D8868AC61B1C.jpeg CF2F74A6-17DF-497C-9736-2CC6DC6CD0D5.jpeg 6DDE450C-EAAD-4122-AEFE-3C682993F69A.jpeg Okay Vick ,
    Here is the tool I made,,,it fits stock Chevy pistons very well.
    But,,,could easily be modified to fit different styles of pistons.
    The top corner that is notched out clears the ring land area,,,,and allows the pin area of the piston to rest flat on the surface .
    Then I made a pin driver out of bar stock,,,,,,it is a few thousandths under the pin bore size,,,and I machined a pilot onto the end to locate the pin,,,I didn’t want to risk it being out of location or slipping off .
    Then into a press,,,and no problem.
    Hope it helps out,,,I guess this is what you were looking for ?
    Tommy
  18. toxic waste
    toxic waste
    from Iowa
    This is what works the best to put rods and pistons together and removel with out breakage. 20200321_175853.jpg 20200321_175911.jpg
    Tickety Boo, WB69, triumph 1 and 3 others like this.
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ Nice back piston/rod from interior rather than the exterior.
    WB69, Max Gearhead, stanlow69 and 2 others like this.
  20. Budget36
    Budget36
  21. Yes it does
  22. gimpyshotrods
    gimpyshotrods
    It looks exactly like Shawn O'Connell
  23. squirrel
    pic from the link above
    Neat, I guess I need one....or not.
    WB69, Max Gearhead and Johnny Gee like this.
  24. '51 Norm
    '51 Norm
    from colorado
    s55mercury66 likes this.
  25. here’s the pics of these pistons
    It’s pretty irregular and the embossing isn’t even close to even
    CCE97800-2D47-432B-9653-A28579C62882.jpeg A12BF4A9-2F29-4F39-B2EB-E0460A84DE50.jpeg 4D13ADCF-7DE0-478C-989B-D7DE222A53C3.jpeg
    Johnny Gee and Desoto291Hemi like this.
  26. RmK57
    RmK57
    Get your rods bushed for floating pins. Looks like the pistons have grooves for spiral locks. The tougher part is pressing them back on as there could be some offset clearance.
  27. jimmy six
    jimmy six
    Sorry, I misunderstood “press” and haven’t used press in pins since 1966. Even my stock Y-Block has floating pins.
  28. squirrel
    Be careful if you are supporting the rod by the piston when you press it out. Most cast Chevy pistons don't have the boss for the retaining ring, and they're easier to support safely.
