Hot Rods 1954 Chevy 210?
Discussion in 'The Hokey Ass Message Board' started by Taylor J onion, Mar 21, 2020.
  1. Taylor J onion
    Taylor J onion
    By looking at it without any trim any clues to if it's a 150 210 or belair? 20200321_191941.jpeg
    Sent from my SM-G955U using The H.A.M.B. mobile app
  2. 52HardTop
    52HardTop
    If you search a 210, it looks like it is the same as this car. The 150 has no trim while the 210 has the line and the bel air has the bell air emblem and trim on the rear quarters.
    Johnny Gee likes this.
  3. Taylor J onion
    Taylor J onion
    As far as value between the belair and 210 is it significant
  4. 52HardTop
    52HardTop
    I guess you can say that yes. The Bel Air is the top of the line. But, there are many who prefer the 210 just as much. It all depends on a persons taste. Sometimes it's more about a Hard Top or Coupe body and not so much the model line or trim.
  5. 62rebel
    62rebel
    How many lines of holes?
  6. 52HardTop
    52HardTop
    Hey rebel, it looks like there is just the one line down the quarter. I don't see the two lines of holes that would say it had the bel air trim.
    MO54Frank and 62rebel like this.
  7. hotrodjack33
    hotrodjack33
    You can tell by looking for welded up trim holes on the quarter panels from inside the trunk. No welded up holes =150. 1 row of weldedup hole=210. 2 rows of welded holes =BelAir
    62rebel likes this.
  8. 62rebel
    62rebel
    One of the few stovebolt chevs I like, and I prefer a sedan over a hardtop in this body style. Straight six with appropriate hopup parts, body smooth as possible and a dark color.... mmmm tasty.
    Gasser 57 and 52HardTop like this.
  9. squirrel
    Not common on 54s, but later Chevys it's pretty common to change trim level....you can look a the cars's serial number tag on the door hinge pillar, if it starts with A-150, B-210, C-Belair.
    And the body trim tag under the hood will have a style number, if it starts with 54-12** it's a 150, 54-10** it's a 210, or Belair if it has a D after the number.
  10. Taylor J onion
    Taylor J onion
    Would this have a actual tag on the door jam or would it go off the original motor cast number to match the ***le
  11. squirrel
    The car should have a serial number tag spot welded to the driver door hinge pillar. Whether the ***le uses that number, or the engine number, is determined by the state the car was ***led in, long ago, and really doesn't matter.
    MO54Frank likes this.
  12. hotrodjack33
    hotrodjack33
    Holy **** ! Is there anything @squirrel doesn't know ? The guy is amazing :D.
    62rebel likes this.
  13. squirrel
    I only know one thing...how to look stuff up :)
  14. jimmy six
    jimmy six
  15. squirrel
    That's a Hardtop Belair, but you could also get it as a sedan, two or four doors.
  16. Gasser 57
    Gasser 57
    from New Jersey
    What a great start to bringing one of these to life!
    gotta56forme likes this.
  17. J53
    J53
    from WI
    And if the tag numbers above don’t match then someone put a ‘54 front end on a ‘53 210 -which is common. Also, it looks like it possibly has ‘55 headlights, or a “brow” of some kind. Definitely not ‘53 or ‘54 whatever they are.
  18. patsurf
    patsurf
    'knowledge is of two kinds---you know it,or you know where to find it'--fly leaf of an encyclopedia had that quote,rather fittingly...
    catdad49 likes this.
  19. Taylor J onion
    Taylor J onion
  20. sunbeam
    sunbeam
    Wasn't a 150 the only one without rock shields on the quarters.
  21. Taylor J onion
    Taylor J onion
    I don't see any holes in the quaters for the shields
  22. J53
    J53
    from WI
    That little part that extends out over the top of the headlight. Yep, those are ‘55 Chevy headlights grafted on to the fenders of the ‘54, it was/is a common modification. While ‘53 and ‘54 were slightly different, the headlight “doors” (trim rings) were flat to the fender with no “brow”
  23. J53
    J53
    from WI
    Pretty sure all models had rock shields. The 150’s had rubber ones while the other models had stainless.
  24. jimmy six
    jimmy six
    Showing the stainless side trim and typical two tone..210 has a single line like the one in the model car kit. He needs to look for holes or filled holes by looking inside. Jim that one has a 409 4-speed. 409 HP
  25. Taylor J onion
    Taylor J onion
    Ahhh I see what your talking about now I never would of realized that
  26. J53
    J53
    from WI
    What’s the back end look like?
  27. Taylor J onion
    Taylor J onion
    I never got pics of the rear but from what i could tell was original, 95% of the body work is done and it has a new floor body was off and he did all new brake lines and brakes painted the frame with por15 with a gloss finish, front disk conversion, motor was trash so it has a rebuilt 216 right now
  28. fastcar1953
    fastcar1953
    150 has smaller back gl***. the trim around the windows says 210 . has 54 tail lights But they were changed a lot between 53 and 54's. Dash would provide more clues. Depends on chrome trim. seat brackets also had different trim. Is the original engine in it? 235 but 53 had babbit rods unless automatic. 54 has inserts.
  29. fastcar1953
    fastcar1953
    I bet it's a 235 not 216. Any pics of engine?
    52HardTop likes this.
  30. Snegrah
    Snegrah
    from Pacifica
    This is a bit confusing to me. It has no stainless trim on the front and rear windows. I think only the 150 was in rubber only. Yet, there are holes for the single strip body side moldings from the front fender to the rear which means that would be a 210. These all came with rock shields. Rubber was 150, stainless was 210 and Belair. But they're not on the car. So, my bet is 210 with 150 front and rear windows.
    Please check the body tag and let me know!
    Tom
    Sent from my SM-G965U using The H.A.M.B. mobile app
    myothercarisjustasbad likes this.
