Technical 4 banger with Juice brakes.
Discussion in 'Traditional Hot Rods' started by Chalkie, Mar 21, 2020.
  1. Chalkie
    Chalkie
    from England
    Good evening
    I am currently building up a Ford model a Ch***is and running gear, with a 27 ford model T roadster body on. I am using the Ford 4 banger engine to begin with as to get it registered here in the UK . As I would like to v8 it in the future and I don't have the rod brakes. I have brought everything but the master cylinder to fit juice brakes. I would like to know how other people have mounted the master cylinder to work with the stock model A pedal box.
    I have been googling, searching, reading books and asking about but I have not turned up anything as such, Either the posts are full of people discussing use of Juice vs Rod brakes or any guides showing you what people have done have dead links or photo buckets faded pictures you can't see very well and pictures speak a 1000 words and also a lot easier to have in front of you when making one.
    Any help would greatly be appreciated
    Thanks
    Stephen
  2. redoxide
    redoxide
  3. Hitchhiker
    Hitchhiker
    Chalkie likes this.
  4. Chalkie
    Chalkie
    from England
  5. Hitchhiker
    Hitchhiker
    A 3 inch piece of pipe with a flange on each side to mount the master cylinder off the crossmember a little bit to make room for the push rod.
    I don't have any pictures on this computer, but if you go back to the thread on my pickup it is on there.
    Chalkie likes this.
  6. ClarkH
    ClarkH
    Some guys weld a bracket to the brake cross piece. I simplified matters and welded the bracket right to the brake pedal. Distance from center of pivot point to bracket and pedal is 6:1, as I recall. Moved battery to trunk and fabricated an MC mount directly behind pedal. Connect the two with adjustable rod. Mustang drum/drum MC, ~1968.
    Chalkie, Hank56 and stillrunners like this.
  7. winduptoy
    winduptoy
    To start I'll try to set the stage and give a description. I have a B OHV Banger in my '29 A Roadster with an A frame. The battery is relocated to the trunkIt has a B pan and B transmission. It has B front engine mount and a rear mount on the transmission. The bellhousing does not mount to the frame so those mount holes were unused. The B transmission doesn't have a pedal cross shaft so had to figure out where the A pedals needed to be located for the clutch and the brakes. I used the unused holes in the bellhousing for a bracket mount for the cross shaft on the transmission side.....and to attach the transmission side of the master cylinder bracket t.... I'll go take some photos....
    but I used a master cylinder off of a '53, '54 Ford Pick Up...that had the right size cylinder bore ratio for the wheel cylinders. Made a bracket/plate out of 3/16" x 4" material that mounted behind, but parallel to, the pedal cross shaft. My frame is boxed, so I welded a tab to the frame to bolt the bracket/plate to. The other side attached to the bracket mentioned above, I wanted to be able to not have the commitment of having it directly welded to the frame. I hole sawed the plate for the master cylinder, locating it centered in line with the mechanical lever on the cross shaft and low enough that it would center on the eye of the lever. I had relocated the lever so it was 90 degrees to the plate when the brake pedal was all the way back.
    I made a push rod using the original mechanical brake clevis to attach to the brake cross shaft lever.
    Some of this may apply or may not to your application. I tried searching the HAMB before I did this project but came up with not much so it is probably good to have a thread on this. Post so we can see what YOU do.
    Good luck,
  8. winduptoy
    winduptoy
    Well my car is driven hard in the salt, dirt and mud so it has signs of use....
    Notice the bracket that hugs the transmission, it supports the cross shaft and M/C bracket/plate IMG_20200321_160014717.jpeg
    Sent from my XT1585 using The H.A.M.B. mobile app
    Chalkie and stillrunners like this.
  9. winduptoy
    winduptoy
    Cross shaft mounted on frame side so I could take it out and throw it away if it didn't work. I took a shaft off an A bell housing. The bracket that hugs the transmission on the bell housing. I just heated it with a torch and bent it up in my Big ***ed vise. IMG_20200321_155918422.jpeg 1584831966922.jpeg
  10. stillrunners
    stillrunners
    from dallas
    Nice work - winduptoy !
    winduptoy likes this.
  11. Hank56
    Hank56
    from NC
    BCC70354-AD82-4B2F-8E81-18E1BE2B2DDD.jpeg I built a similar ride to yours last year...I’m still running rebuilt mechanical brakes with no issues so far...I took it out cruising twice already this weekend....I’m building another banger powered rpu right now..this one I’m gonna do juice breaks and a hopped up banger .I’m gonna use this battery box /master cylinder kit - http://www.bolingbrothers.com/model-a-master-cylinder-battery-box-***embly/ unless I find something better or cheaper...this one lets you use your stock break pedal...check out the page it might give you some ideas...
    Chalkie, trikejunkie and winduptoy like this.
  12. Russ B
    Russ B
    my setup has the master cylinder tied to the battery box. You see the bellcrank has a pivot mounted on the box. The mc mounts low facing to the rear. I could not find a photo of the mc and mount. You might go to FordBarn and do a search for more information and pics.
    this is what I have, the pic is from Bolling brother’s site.
  13. Chalkie
    Chalkie
    from England
    Evening, sorry for the late replies the misses made me clear out the front room and paint it, had to take my pc out to be able to do that only just got it back in but thank you for all your replies, the posts have been very helpful. dose anyone have the measurement of the arm on the Bolling brothers mount? as i could possibly just make a mount to hold the MC off the side of the gearbox as I have my battery located in the boot anyway.
    Yet again thank you for all your replies.
  14. Chalkie
    Chalkie
    from England
    That's a beautiful looking RPU
    Hank56 likes this.
  15. Chalkie
    Chalkie
    from England
    That's cool. are the brake pedals Cast iron or? I'm not sure been told cast iron can be horrible to weld.
    Thanks
  16. ClarkH
    ClarkH
    Ford pedals of that era are forged steel. It welds nicely. I cut my backet off a junk F1 pedal so it would be similar steel.
    Chalkie likes this.
  17. Chalkie
    Chalkie
    from England
    Just happens I've got a set of f1 pedals and some 36 ford pedals aswell.
    ClarkH likes this.
  18. manyolcars
    manyolcars
  19. Chalkie
    Chalkie
    from England
    Is the lever arm for the Brakes on the battery 1:1 ratio? if so I could work a length out
    Thanks
    Stephen
