Technical What did you do today?
Discussion in 'The Hokey Ass Message Board' started by Daniels Auto Repair, Jul 9, 2016.
  1. neilswheels
    neilswheels
    from England
    Made holes for these, and pondered fuel line routing
    chryslerfan55, LAROKE, Hombre and 2 others like this.
  2. vtwhead
    vtwhead
    @neilswheels did you get the 348 freed up? Firewall looks great by the way.
    Hombre likes this.
  3. Me too, but I make it up on volume. [​IMG]
    40two, mgtstumpy, jakespeed63 and 2 others like this.
  4. pecker head
    pecker head
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    Just for the record.
    I’ve received information regarding this problem from MSD.
    check rotor-phasing. Ensure you're using the correct Ignition Reference Angle for your distributor (inherent crank reference angle/rotor-phasing of the distributor). Rotor-phasing will be way off if it's wrong.
    http://www.masterenginetuner.com/top...all-fails.html (Crank Reference Angle Importance)
    https://forums.holley.com/images/misc/quote_icon.png Originally Posted by Danny Cabral
    Testing the MSD CD ignition box.
    Points Output - white wire & Magnetic Pickup - violet/green triggering:
    https://www.msdperformance.com/suppo...ng_techniques/ (Troubleshooting Info)
    Ensure the distributor's rotor-phasing is correct:
    http://do***ents.msdperformance.com/8644_tb.pdf (MSD Rotor-Phasing Do***ent)
    MSD has a good video on why it's important:
    (MSD Tech Rotor-Phasing Video)
    For naturally aspirated engines, the rotor is usually phased halfway between minimum & maximum amount of timing advance used.
    For forced induction engines, the rotor is usually phased at maximum boost retard, because that's when cylinder pressure is the greatest.
    chryslerfan55, Hombre and mad mikey like this.
  6. WB69
    WB69
    from Kansas
    Serviced the mowers. Then spent a few hours on one.....damn, here it goes again. Love warm weather but hate all the mowing!
    Hombre and Boneyard51 like this.
  7. David Gersic
    David Gersic
    from DeKalb, IL
    Brakes on wife’s OT car. Was a nice to spend in the garage, alone.
  8. Jalopy Joker
    Jalopy Joker
    finally dugout my old TV DVD/VCR player and installed in "Man Cave" - have a bunch of films have not watched in a long time, some never - have a Firestick set up on main Family TV for Netflix, etc - but, this is cheaper 20200322_084433.jpg 20200322_084504.jpg
  9. HOTRODPRIMER
    HOTRODPRIMER
    That's not a bad idea, I have a stack of vintage hot rod dvd's I got from a fellow club member when I traded him a bunch of vintage NOS Henry Gregor Felsen books, many I have never gotten around to watching. HRP
  10. ROADSTER1927
    ROADSTER1927
    This morning I made a new green lense for the blinker housing in my Ramp truck project. I hole sawed the bottom of a green pill bottle, cut it down some more by hand. Cleaned up the chrome and glued the lense in.:D lense5.jpg lense4.jpg lense2.jpg lense3.jpg lense1.jpg lense.jpg
    40two, MO_JUNK, chryslerfan55 and 5 others like this.
  11. The37Kid
    The37Kid
    No those were fresh photos, I just got side tracked with something I found in there, details tonight. :)
    Bob
    Hombre, Boneyard51 and Budget36 like this.
  12. impala4speed
    impala4speed
    Pretty cool. I just read that VHS tapes are making a comeback a**** the 80's kids in the same way that vinyl records are now popular. Of course, vinyl has always been popular with this 60's kid. :D
    chryslerfan55 and Hombre like this.
  13. Boneyard51
    Boneyard51
    Buy a Hustler zero turn! You will love mowing, then!
    Bones
    chryslerfan55, X-cpe and harley jim like this.
  14. Boneyard51
    Boneyard51
    Bob, I started cleaning my shop this winter I still haven’t got it completely done. The great thing about cleaning a shop that has been stacked upfront years is finding stuff you forgot yo u had!
    I have been trying to find a drill motor thing for grinding valves, to complete my valve grinding equipment for several years, finally found one I liked last spring, at the Springfield swap meet! This winter, while cleaning my shop, I found a Souix box, under my work bench that had one in it! I have no idea where it came from! If you clean your shop..... I bet you would be in for some surprises ,like mine!
    Bones
    chryslerfan55, Hombre and The37Kid like this.
  15. Why? He said in despair.
    I have two very expensive VCR recorders that chewed up their cost in VHS tapes. This problem wasn't totally the fault of the machines, but were aided by the fact that if a tape was played a lot, it had to be taken apart and lubricated.
    I was so grateful when the Laser disk player, and finally DVD happened. When the newer devices ****ped the bed, at least you didn't destroy the irreplaceable medium on the disks. The hard part of archiving the VHS material to a hard drive, is that it is a real time manual operation, and requires constant monitoring.
    Nowadays I backup everything onto a hard drive, and clone the drive as a backup when the drive is full. A person can set up almost any old computer as a player.
    Bob
    chryslerfan55 and impala4speed like this.
  16. Chgo Sox Fan
    Chgo Sox Fan
    Snowing in central Indiana today. So I brewed 5 gallons of beer and added the yeast to 3 gallons of apple juice that will become a ****ed hard cider. Work on my 51 Chevy SD will resume tomorrow.
    Shutter Speed, Hombre and Budget36 like this.
  17. The37Kid
    The37Kid
    Way up top in the center is a 10 foot long piece of clear 1x6 that I stained to replace a piece of trim on the back of the garage. Think it has been up there 2 years (Son in Law said 5), part of many unfinished projects. Not any more. Bob
  18. WB69
    WB69
    from Kansas
    Got 2 big Gravely ztr's. Still takes 4 to 5 hours of non-stop mowing with both mowers to get over it all. Usually weekly. Not so fun anymore.
    chryslerfan55 and Boneyard51 like this.
  19. rob-redm
    rob-redm
    went for a spin in my 36 3w before the rain comes back in... Then broke I the car on the way home..
  20. Blues4U
    Blues4U
    from So Cal
    Got out of the house, took the wife for a drive up the hills and had a side of the road picnic. Then back to quarantine....
    40two, i.rant, Butler 32 and 21 others like this.
  21. Dick Stevens
    Dick Stevens
    Then you are mowing too much of your land, let some of it go, I do and that makes it a lot better!
  23. Mike Miller
    Mike Miller
    Changed my trailer from surge brakes to electric and re wired it.
    jakespeed63 and Hombre like this.
  24. WB69
    WB69
    from Kansas
    Good advise!!
  25. LAROKE
    LAROKE
    From the BillyBob Shop log
    March 23rd 2020 Third p*** over the cab exterior above the belt line. Scotchbrite cookies on two more dents I discovered and abrasive buffs in the Dremel motor tool in the cowl vent channels, door hinges and around the rear window. Another washing of the cab top with Dawn dish soap and I spied two more dents previously missed,
    Finally, I was to the point where I could PRE paint prep the dent areas and slather them with some filler. Still waiting for ordered sandpaper for blocking. Have to make do with what I have on hand. Truckers, God bless 'em, have their hands full with more important deliveries.
  26. jakespeed63
    jakespeed63
    Sunday's project simple rebuild on Saginaw steering box for the '64 Olds. Been a professional techniciam, for 35yrs, but never completely took apart a steering box.(first and last) Always got by, with pitman seals and the occasional sector shaft seal. (extracting using the hole drilled sheet metal screw method)
    Spent the better part of the day, carefully taking everything apart, using my factory book and a wise *** on YouTube video. After struggling, finally got back into the ch***is and fired it up. UGH!! Steering wheel started going to the right, all by itself.
    ...guess what I'm doing Monday??
    Have to admit, it was a good experience and felt good cleaning all the crud, out of the inside. Been over almost every inch of this sled, so thought why not. Lesson learned.
  27. LAROKE
    LAROKE
    March 24th 2020 South Florida's broiling summer is approaching and I'm looking for ways to mitigate the effects in the BillyBob Shop. I hadn't given much thought to a dehumidifier because the shop is not insulated and the two 12' x 12' overhead doors are big air leaks. There is a 24" diameter hole up high in the rear wall with a broken fan in it as well.
    My friend, Dave ***ton, has a free-standing shop comparable to the BillyBob Shop and he reports that a dehumidifier drys it considerably, making it more comfortable for summer work. Based on Dave's report, I purchased a heavy-duty dehumidifier. I got one rated for double the area of the BillyBob Shop because of the sixteen foot ceiling height.
    Set it up in the BillyBob Shop over the weekend and started it up. Within three hours, the humidity had dropped from 58% to 46% and the water container had topped out at 1.8 gallons, at which point, it turned itself off.
    The next day, I searched the shop and found a garden hose I had originally gotten, way back, to drain a water bed and hooked it up to the dehumidifier to provide continuous drainage. It's running continuously now. Lowest observed humidity in the shop has been 42% thus far. I can feel a difference and it's too early to tell, but I believe it's relieving the heat rash on my forearms somewhat
  28. Hombre
    Hombre
    Laroke, I am curious how this work's over time. Here in Alabama I could sure use something that would help with the heat that is coming fast. Thanks for any information you have...
    LAROKE and lothiandon1940 like this.
  29. lonejacklarry
    lonejacklarry
    You might consider a ceiling fan, or two, to move the air around for your dehumidifier. This was suggested to me by my furnace guy as I have a tall ceiling. It appears to work better.
    chryslerfan55, Hombre and LAROKE like this.
  30. LAROKE
    LAROKE
    Thanx
    chryslerfan55 and lothiandon1940 like this.
