Hot Rods Cody Walls Builds 32 Ford 3 window coupe “The Ardun Killer “ .
Discussion in 'The Hokey Ass Message Board' started by Cody Walls, Aug 21, 2019.
  1. Cody Walls
    Cody Walls
  2. Cody Walls
    Cody Walls
  3. vtwhead
    vtwhead
    Flawless work man. Keep the updates coming.
    Stogy and lothiandon1940 like this.
  4. Cody Walls
    Cody Walls
    Thank you
  5. HotRodMicky
    HotRodMicky
    What a cool Project!
    So cool with such deep channel job.
    What do you plan for a seat ?
    With a a lowered floor?
    And swinging pedals?
    They are easier to push if you sit low down
    What do you plan for a transmission?
    Outback and chryslerfan55 like this.
  6. Cody Walls
    Cody Walls
    Thank you . On the seat I’m going to be running a cut down stock seat .
    On the pedals I’m not sure yet until I get the motor in and see how much room I have .and how comfortable I’ll be .
    On the trans . I’m back and forth
    It’s either going to be a Packard trans or a 5 speed .
    Outback, chryslerfan55, Stogy and 2 others like this.
  7. HotRodMicky
    HotRodMicky
    I would vote for a Packard trans and QC. The QC wont be visible, but you can change gears for drag strip or highway speed .
    Cody Walls and El Hueso like this.
  8. Gofannon
    Gofannon
    If you can find a Cyclone and want to run a Packard trans, you'll need the equally hard to find Hildebrandt or Offy Packard adaptor. @Stovebolt has the same setup, and he's in Australia and I'm in NZ, so they are around. However, you are limited to clutch size. A Chevy 9 1/8" just slides in, but these were designed for a flathead clutch so I have yet to find out what the largest of those will fit. A more practical and cheaper option would be to buy the adaptor from Buffalo to adapt a SBC ****tershield and redrill for the Packard. Then you could go to 11" clutch, and swap to a 5 speed easily if you need to.
  9. Tim
    Tim
    from KCMO
  10. Cody Walls
    Cody Walls
    Thank you for the information as well as the photos, I have heard that the clutch selection on the cyclone was limited to size but I didn’t know exactly . From what I was told with my motor setup I’ll need a nice slice clutch . This is the first time I’ve seen the Packard adaptor . I’ve been talking with stovebolt about his .
    The Packard face on That adaptor looks a lot like a Chevy trans mounting surface .
    Outback, Stogy and chryslerfan55 like this.
  11. Gofannon
    Gofannon
    Mounting holes are different. Here's the cheap and nasty conversion I was going with until the Cyclone fell in my lap. 10mm (3/8") plate to bolt the Packard to OE Chevy 6 cylinder bell housing. The holes with bolts in them are the Packard ones, left side of pic is the bottom of the adaptor. Packard clutch shaft is identical to Chevy. There seems to be 2 different bearing retainers for Packard. One can be machined down to Chevy size to take a Chevy thrust bearing. Mine is larger diameter and can't. With the Cyclone the Packard bearing retainer is discarded and the trans bolts to the adaptor. Then a Ford bearing retainer is bolted inside the adaptor for Ford thrust. If you find a Hildebrandt or Offy Packard adaptor, you could use it with a Buffalo adaptor and a SBC to Flathead trans adaptor, and still run a bigger clutch.
    kiwijeff, Stogy and chryslerfan55 like this.
  12. Cody Walls
    Cody Walls
  13. Cody Walls
    Cody Walls
  14. Blue-Collar-HotRods
    Blue-Collar-HotRods
    Unbelievable talent! I might have missed it before, but what is the frame out of?
    Stogy, loudbang and chryslerfan55 like this.
  15. Cody Walls
    Cody Walls
    Thank you , it’s the stock 32 frame that came with the car
  16. Cody Walls
    Cody Walls
    Wow they are extremely close , I see why guys ran them back in the day . Thank you for the photos and info
  17. greaser
    greaser
    Incredible work Cody. I'd be happy to have 10% of your fabricating ability!
    How much is the channel? Pics almost show it heavier in the front.
    Stogy, Cody Walls and loudbang like this.
  18. Fitnessguy
    Fitnessguy
    Build looks great Cody. Looking forward to seeing the rest of the floor build. The most satisfying part of my build was any and all metal fab. I'm no pro by any means but very satisfying to have an idea/image in your mind and then make it come to light! Keep the pics coming!
  19. Cody Walls
    Cody Walls
    Thank you .
    9”up front 8”in the back , it’s the most I could go and still be able to fit . I would have went more but I’m 6ft
    Outback, chryslerfan55, Stogy and 4 others like this.
  20. Cody Walls
    Cody Walls
    thank you
  21. El Hueso
    El Hueso
    Clever. I like how you mimicked the '32 frame with the sheet metal on your channel. Well done!
    -Brent-, brEad, Cody Walls and 3 others like this.
  22. Cody Walls
    Cody Walls
    3ED18D2D-9A15-4576-B055-CADABEE0E5D1.jpeg firewall progress . This is as far as I can go until I get my motor .
    lucky ink, Outback, 51box and 18 others like this.
  23. dentisaurus
    dentisaurus
    from Boston
    Love this build, straight six is so cool. Wondering if a Jag V 12 distributor might be another option. Jaguar were using them in race applications in the late 50’s so it would sort of qualify for a H.A.M.B. build. Can’t wait to see this one come together.
    D-Russ, loudbang and chryslerfan55 like this.
  24. Cody Walls
    Cody Walls
    Well there goes my trunk space , lol
  25. Cody Walls
    Cody Walls
  26. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    How 'bout twin bucket rumble seats?
  27. jimmy six
    jimmy six
    It would take a lot to move the body back up on the frame..
    Tman and loudbang like this.
  28. Lots of work done so far keep the updates coming.
  29. Cody Walls
    Cody Walls
    Yes it would . But then it would be like every other 32 out there
    kiwijeff, Countn'Carbs, bowie and 4 others like this.
  30. Cody Walls
    Cody Walls
    Lol , once I get the gas tank and battery in there , there’s not going to be room god anything else
    Outback, chryslerfan55 and loudbang like this.
