home made tools and equipment...
Discussion in 'The Hokey Ass Message Board' started by kustombuilder, Jan 16, 2008.
  1. hotrod1948
    hotrod1948
    from Milton, WI
    Very nice. Well thought out..perfect size for that machine.
    tb33anda3rd likes this.
  2. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Well done :D.........
  3. DDDenny
    When I was a machinist I made A LOT of soft hammers for the shop guys, a chunk of steel round stock, a couple plastic ends and a Cherokee hickory handle, once in a while someone would bring one back complaining of the handle loosening up and want the handle replaced.
    I would take it and give it a good whack on the end to seat it and drill a hole through it and install a 1/4" roll pin.
  4. atch
    atch
    Wouldn't a couple of old steering column shafts do this for just about free? i.e., anything before the collapsible shafts came into being.
  5. dirt t
    dirt t
  6. whtbaron
    whtbaron
    from manitoba
    Got tired of my welding helmets kicking around the welding bench and decided I needed a place to hang them on the wall. Took an old towel rack that got tossed during a home reno a few yrs ago... rearranged the bars and blew a little black paint on it... voila! DSCN4772.JPG DSCN4773.JPG DSCN4775.JPG
  7. Fortunateson
    Fortunateson
    Nothing like Powerfist Black!
    VANDENPLAS and whtbaron like this.
  8. atch
    atch
    A friend gave this to me. He made it back in the dark ages.
    Slide "hammer" made with needle nose Vise Grip, Model A brake rod, and a stack of washers welded together.
    b-t-w; the "date of manufacture" is April 18, 2006.
    b-t-w (2); I wasn't there when he made it, but he told me that the weight was welded washers. Doesn't look like it to me, but I can't argue with the man who made it. 20200318_180751.jpg 20200318_180817.jpg 20200318_180801.jpg
  9. stealthcruiser
    stealthcruiser
    I'm diggin' the "reduction gear" on your drill press!
    I need something similar on my old Delta drill press!
  10. Nothing elaborate, just needed an extension on the jack, to get dummy case up in place while fitting it to crossmember and floor pan. Inexpensive floor jack I had around, and some 2 by 6. It's bolted to the jack, so it can't rock. Been a blessing on my arms! IMGP3133r.jpg
    The 39 guy, saltflats, brEad and 5 others like this.
  11. RMONTY
    RMONTY
    Been taking advantage of social distancing. Finally finished my rotisserie.
    Watch "March 21, 2020" on YouTube
    lewk, whtbaron, VANDENPLAS and 6 others like this.
  12. BigO
    BigO
    We've all drop a part that landed in a hard to reach place so i came up with a way to retrieve parts that a magnet can't pick up. Yes its very simple looking but does a great job. The wax cover on Babybel cheese is very tacky and even works as it gets dirty i just put it on a piece of br*** rod, i also use it (the wax) to hold trim in place when deciding where i want it and able to stand back and look without the distraction of strips of tape, and it wipes of with wax&grease remover. Just something that has worked well for me. BigO
    chiro, weps, VANDENPLAS and 12 others like this.
  13. BigO
    BigO
    20200325_123643.jpg 20200325_123528.jpg Small punches i use to work on jewelry but also use to straighten stainless trim, masonry nails.
  14. BigO
    BigO
    Known as a ring clamp I use one at home to hold small pieces when they need to be filed or polished, it has 2 leather pads to keep from scratching the piece your working on.
    20200326_124908_HDR.jpg 20200326_124922_HDR.jpg 20200326_124929.jpg 20200326_170232.jpg
    jaw22w, Nostrebor and b-body-bob like this.
  15. seb fontana
    seb fontana
    from ct
    Tube rib tool - keeps hose from sliding off
    chiro, Lepus, whtbaron and 26 others like this.
  16. impala4speed
    impala4speed
    Now that is really slick!
    VANDENPLAS likes this.
  17. seb fontana
    seb fontana
    from ct
    Spring Re-arch press
    whtbaron, fiftyv8, RMR&C and 5 others like this.
  18. gatz
    gatz
    seb, that's brilliant
    gonna have to make one of these....
  19. 30spdstr
    30spdstr
    jmkporsche and tb33anda3rd like this.
  20. Dyce
    Dyce
    I love that with the ball bearing! It reminded me of the one I made to do 3/8 fuel line. It was a cheap side cutter....
    enloe, Lepus, VANDENPLAS and 13 others like this.
  21. I purchased one of those many years ago
    It kinda worked but mostly didn’t. I remember it would piss me off more than anything
  22. Roger O'Dell
    Roger O'Dell
    I just use an inverted flare, but only do partial.on tubes
  23. seb fontana
    seb fontana
    from ct
    Nice and simple, will do many size of tube! Gave me an idea for the next one!
  24. 1946caddy
    1946caddy
    from washington
    There never seems to be anyone around when I need to load a car, that doesn't run, onto a trailer, or drag something around in the shop. So, I built this portable winch setup that uses a cheap, remote controlled Harbor Freight winch. Attach one end to a unmovable object and the other to what I want to move.
    enloe, VANDENPLAS, ekimneirbo and 6 others like this.
  25. I have both large and small commercial units, but needed medium sized puller in a hurry. I welded a visegrip onto a rod, and drilled a 2" piece of solid round stock for use as the slider hammer. For the handle on the end I welded a nut on one end of a piece of 3/4 iron pipe.
    It is ugly, but it works great.
    Bob
    Boneyard51 and loudbang like this.
  26. impala4speed
    impala4speed
  27. atch
    atch
    ...and the picture is where?
  28. Rustridden31
    Rustridden31
    from Denver, CO
    Made a welding cart out of an old file cabinet. Added wheels and hooks/handles. Holds all I need, helmet, tools, gloves, etc.
    lewk, Boryca, The 39 guy and 22 others like this.
  29. atch
    atch
    Excellent; excellent. I've been scratching my head as to how to store my helmets in such a way that they don't get dust and grinding grit on/in them. Inside a file cabinet will be perfect. I think I'll make a welder cart with a 2 drawer file cabinet and replace the one I've had since I bought the welder (sometime in the early 90's). Thanx for the pix.
  30. fiftyv8
    fiftyv8
    from CO & WA
    Now my friend that is one good idea for an old file cabinet.
    Thanks for sharing.
    Looks to ne like there is space enough in one of those draws to store your helmet...
    Rustridden31 and loudbang like this.
