Hot Rods # 10 Track Roadster Build- Marty Strode
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Jan 24, 2020.
  1. Marty Strode
    Marty Strode
    Good to see you posting on here Dan, when this thing blows over, we will have to make up for lost time. Without the swap meet and Portland Transmission Show, things will be a little dull ! Folks, the Ernie, Dan mentioned is my Pal Ernie Martin. For the last nearly 40 years Ern and I have been building, racing, and having fun with our cars. He is a top notch mechanic, who handles the ***embly of our engines, transmissions, and rear ends of all descriptions. He is also an excellent fabricator, with an eye for detail, and a stuntman to boot ! He has raised the quality of my work, by example. img20180723_19142525.jpg IMG_1563.JPG
  2. lake_harley
    lake_harley
    Marty....Thanks for the reply, info and photo. The Don Turner car looks awesome with the short wheelbase, but wow, is that ever a short hood! I always liked the looks and increased practicality of the '27 with more of a trunk area, but so often they end up looking really long, and I like short wheelbase cars. One of the best proportioned '27 Ts in my book is Pete Chapouris' roadster. I've included a photo of it for those who may not be familiar with it. I think it has a 103" wheelbase, but somehow it doesn't look quite so long like many '27s do.
    I'd love to build another T but I'm really torn between a '23 with turtledeck and a '27 roadster. I think I saw early in the thread that the body you're using is from Speedway. Are you satisfied with it (them)? I saw that the '27 roadster body trunk area (maybe a lakes car?) actually has somewhat of a "rain channel" built around the trunk opening, or was that on a '23 turtledeck? I'll have to go back to look.
    Thanks again.
    Lynn
  3. Marty Strode
    Marty Strode
    I have been very happy with Speedway bodies.
    cruiserjohn76 and 1947knuck like this.
  4. Marty Strode
    Marty Strode
    Here is the rough steering box install. I weld a wedge plate on the inside of the rail, to tip the column inboard at the wheel. After clamping the mounting bracket , with the plate sandwiched between, I tack the plate to the frame. After transfer punching the hole pattern, I drill 5/32 pilot holes, followed with a 1/4" drill. The drill guide with the angled foot, allows drilling through the rail, using a long bit. I enlarged the holes to 3/8" and bolted on the bracket. Next will come, drilling the holes to 1/2" all the way through, to install sleeves, to prevent squeezing the rail, when fully tight. There will also be a bung welded in the bottom rail, for an additional 3/8" bolt. The neat aspect of this box and bracket arrangement is the dual pinch bolt, to pivot the box, changing the angle of the mast, before installing the mount under the dash. IMG_4480.JPG IMG_4481.JPG IMG_4473.JPG IMG_4474.JPG IMG_4475.JPG IMG_4476.JPG IMG_4477.JPG IMG_4479.JPG
    ratrodrodder, dwollam, OFT and 16 others like this.
  5. A Boner
    A Boner
    Marty, how much roomier does the unchanneled Ernie Martin Modified feel than your channeled Modified? I would imagine everything else in the ****pit is pretty much the same. They say every inch helps.....unchanneled would give 3 or 4 inches of extra (height), room!
  6. Marty Strode
    Marty Strode
    *****, I only channel mine 2", Ernie is a good sized guy, and it does have a roomy feel to it. He didn't want to be sticking any higher out of the body. I have a video we shot off of Ern's roll bar being edited right now. It gives a great perspective of how it feels from the ****pit, along with being a picturesque drive.
  7. A Boner
    A Boner
  8. Marty Strode
    Marty Strode
    To finish the steering mount install, it required a few extra steps. The VW mount had .430 dia holes, and needed to be sleeved down for 3/8 bolts. So I drilled the mount out to 31/64" and turned down some 1/2" tube, and tacked the sleeves with silicone bronze, and ground both sides flush. Using a step drill, the frame holes were enlarged to 1/2" and sleeves were fully welded through the frame. I used a .010 over reamer to get a final fit on the holes. Notice the slot I milled in the lower mount, it allows for a 3/8" Allen bolt to secure the mount from the bottom. Back to the front end, for caster correction on the bones, and cap the bull noses on the rails tomorrow. IMG_4482.JPG IMG_4483.JPG IMG_4485.JPG IMG_4487.JPG IMG_4489.JPG IMG_4490.JPG
  9. Marty Strode
    Marty Strode
    More detail work. Got the caps for the frame rails fit in place, I will weld them in the morning, when I am rested. Should get the caster corrected on the front bones, tomorrow and have it sitting on the floor Saturday. IMG_4491.JPG IMG_4492.JPG IMG_4493.JPG IMG_4494.JPG IMG_4495.JPG IMG_4496.JPG IMG_4498.JPG IMG_4500.JPG IMG_4499.JPG IMG_4501.JPG IMG_4502.JPG
  10. Marty Strode
    Marty Strode
    Got all of the welding on the front of the ch***is done. When welding the caps, I leave the front inside weld until the rest is ground and finished. When doing the caster correction on the front bones, I saw from the bottom up, leaving around 1/2" uncut. That way I can bend to the proper angle (2 degree change) and weld the bottom. Once the car is on the ground, if I need to make changes, I can saw the lower weld and change the angle. Looking across the shackles, I think it's pretty close. A little more welding in the morning, and I will pull it out of the jig, reinstall the engine, and body. IMG_4504.JPG IMG_4505.JPG IMG_4507.JPG IMG_4513.JPG IMG_4515.JPG IMG_4518.JPG IMG_4517.JPG IMG_4521.JPG IMG_4523.JPG IMG_4522.JPG
  11. gary kessler 1932
    gary kessler 1932
    Love your work!!
  12. Marty Strode
    Marty Strode
    Pulled it from the jig, it rolls !!!! IMG_4526.JPG IMG_4529.JPG IMG_4531.JPG IMG_4534.JPG IMG_4535.JPG IMG_4540.JPG IMG_4541.JPG
  13. saltflats
    saltflats
    from Missouri
    Very nice, thanks for taking us on the ride. :)
  14. Bandit Billy
    Bandit Billy
    @Marty Strode every time I see your cuts/welds I want to take up needlepoint or perhaps the piano. I'd have a better chance catching up with Mozart than with you. Thank you for my inferiority complex today.
    Signed, Not worthy
    tractorguy, OFT, Blues4U and 6 others like this.
  15. tombstone
    tombstone
    from sk.canada
    Marty .... Thankyou for all your posts/info ‼️ Damn it man your build tech are an absolute inspiration for me and I’m sure others ‼️
    OFT, Blues4U and loudbang like this.
  16. catdad49
    catdad49
    Man, that looks so simple.........but it's Not!
  17. Blues4U
    Blues4U
    from So Cal
    It's beautiful!
  18. Marty Strode
    Marty Strode
    Oh, come now Billy, the quality of your cars, is a testament of what you can do.
    loudbang and Bandit Billy like this.
  19. Marty Strode
    Marty Strode
    For you shut ins, it's movie time ! My Nephew Ken, edited some footage we shot a few years back.
  20. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    That's it! Everything is for sale. I have to have a track roadster:D
    loudbang and tractorguy like this.
  21. Johnny99
    Johnny99
    Wonderful thread Marty, thank you. Great video with Don Rich on guitar! You sir are a craftsman.
  22. Marty Strode
    Marty Strode
    Wasn't Don from Tacoma ? A real loss to Buck and "Real Country Music".
  23. Blues4U
    Blues4U
    from So Cal
    Great video Marty, loved the ride along, that roadster sure sounds sweet. What is that read sports car?
  24. Marty Strode
    Marty Strode
    My friend built it from scratch, starting with gluing foam together, and shaving it into the desired shape. Being a master with fibergl***, he laid the body up from there. He wanted something between a Testarossa and a Maserati. Powered by a SBC and 4 speed, quite a car ! IMG_2904.JPG
  25. Liberty Garage
    Liberty Garage
    Is the hook on the dash to keep it in 2nd gear??
  26. Marty Strode
    Marty Strode
    You are correct sir ! When we ran small quarter miles, 4.11s and second, we used the hook. On tracks a little larger, we would plug in a 6.30 gear and run high.
    catdad49, dwollam and loudbang like this.
  27. Johnny99
    Johnny99
    Olympia. Quite the musician.
  28. tractorguy
    tractorguy
    Wow.....talk about the good ole days......I remember the coupes and sedans on the dirt in the 1950-60's (as a kid).....would have a hook shaped piece of threaded rod on the cross tube between the two front roll bar downtubes.....shift up into second gear......flex the long shift lever just enough to get it in the hook.......green flag !!
    catdad49 and loudbang like this.
  29. Marty Strode
    Marty Strode
    A bent carriage bolt with the the head still on, double nutted to the lower dash rail was employed quite often.
  30. Marty Strode
    Marty Strode
    Well, the weather permitted rolling it outside, for some longer distance shots, with the turtle hull attached. IMG_4542.JPG IMG_4543.JPG IMG_4544.JPG IMG_4545.JPG IMG_4547.JPG IMG_4548.JPG
