First, let me preface this with, I am not a carb guy. Wanna talk Hilborn fuel injection, I'm all about that. So, I have a little 29 Model A roadster with a 265 and a 3x2 with 3 Strombergs. The previous owner only had the center carb hooked up. I found the linkage under the seat for the other 2. So basically it's a 2 barrel. The problem: It pukes all over itself occasionally. Like out of the top, around the accelerator pump rod etc. The car has a really small 12V elec. pump and one of the Mr Gasket regulators. I figure the float is hanging and allowing it to overfill. The questions: 1. Who sells the best/most complete overhaul kit for a 97? 2. Who sells the most accurate low pressure regulator 5 lbs. and under? I would like to get this thing running right, but I only wanna do it once. Thanks, Root
I use ONLY a vein type pump. If its a pulsating pump it will push past the needle and seat. I also set the fuel regulator at 2-3 PSI
Buy one of the Holley regulators. They come in a higher pressure version and one that regulates from 1 to 4 pounds. And buy a low pressure gauge from ****ster here in the HAMB cl***ifieds. Then set them to 2 pounds MAX. And, any Stromberg parts or service you need can be obtained from our own Uncle Max. He's the absolute best.
****ster here in the Hamb will provide you good rebuild parts. Residual electric pump pressure after the engine is shut off will cause Stromberg leakage also. A solution would be to install a separate switch for the pump and turn it off before the ignition.
It does it going down the road. I can always tell. It smells like raw fuel and then I can look over the windshield and watch it geyser. The round Mr. Gasket regulator worked great for a while.
Probably the best regulator is this one. Aeromotive 1-5 psi. I installed one on my RPU with the 3 new Strombergs from Clive. https://aeromotiveinc.com/product/low-pressure-carbureted-regulator/ View attachment 4619686
Blue, that's a sanitary looking installation. Is that regulator aluminum? If it is I think I'd be inclined to scratch the Edmunds logo into it and give it a buffing. Help hide the newness.
Thanks, I welded a mount for it to the edge of the crank case draft hole block off plate. It is aluminum and I had considered taking it apart and blasting it for black paint but never got there. I may in the future but I think it looks okay down low on the side of the engine. And it works great at 1.5 psi.
I just run the stock flathead pump, works great. On another note, what can I use to get a nice looking finish, without resorting to paint.
I did some troubleshooting tonight. When it would start loading up, I would turn the pump off to see if it would clean up and it did. So the carb may just need a new pressure regulator first, then worry about the overhaul later.
I run one of these Malp***i units on my car with 97’s. It is a low pressure regulator and filter all in one.
