Projects 31 Kustom Roadster (DIY duvall, tudor to roadster conversion)
Discussion in 'Traditional Hot Rods' started by Chevy28, Feb 13, 2020.
  1. HelminenHotrods
    HelminenHotrods
    from Finland
    Hello from Finland!
    Bought the tudor in spring of 2018. I was still building a 28 chevy, so ford had to wait for a year.
    Spring 2019, chevy was ready, and enough with the fourbanger for me. Sold it and Ford build begins :
    When i got it
    Goodbye chevy
    Before i decited to build it as a roadster, i cleaned up the rusty body, and of course chopped it..
    I love the look of an chopped sedan, but every time i looked at it, i wished i had an roadster.
    -Markus
  2. HelminenHotrods
    HelminenHotrods
    from Finland
    Started cutting and mocking up. Got brookville quarterpanels. FB_IMG_1580764098573.jpg
    I have to use fourbars front and back due to Finnish laws, but will be upgrading to front split wishbones once the time is right.
    Frame was sitting too high with 4inch drop axle, so i dropped the front crossmember and C-notch rear. Also did 2 inch bleedsweep.
    I wasnt't sure about welding cast iron housing on that gm 7,5" rear axle, so welded up tubing to it.
    IMG_20191229_210556.jpg IMG_20190927_224803.jpg IMG_20190927_224739.jpg IMG_20190929_214846.jpg IMG_20191001_230514.jpg IMG_20191014_190859.jpg
    Didnt want to copy original model a cowl. Still have to figure out the door tops at some point. FB_IMG_1580764186835.jpg
    IMG_20191024_231733.jpg IMG_20191031_222121.jpg FB_IMG_1580764199968.jpg FB_IMG_1580764196550.jpg IMG_20191219_203948.jpg
    -Markus H
    Rawrench, rat bastad, Spooky and 32 others like this.
  3. HelminenHotrods
    HelminenHotrods
    from Finland
    After the cowl i moved to rear of the body.
    Got quarter panels lined up. The brookville panels needed quite a lot of work, all shapes wore different between those two panels.
    Made below and above deckpanels. IMG_20200212_201005.jpg IMG_20200212_201237.jpg IMG_20200212_201409.jpg IMG_20200212_201530.jpg
    Also had to work on the rear axle. Eaton locker with 3.73:1 ratio. First one for me, but think it came out okey, with help from the internet ? FB_IMG_1580764004090.jpg FB_IMG_1580763991141.jpg FB_IMG_1580763995096.jpg
    Thats where im at now. Next on to do list is decklick and inner structure to body
    -Markus H
  4. panhead_pete
    panhead_pete
    Awesome build so far thanks for posting. How will you sort out the swage lines from the doors to the 1/4s?
  5. sloppy jalopies
    sloppy jalopies
    Very nice work on the panel above... cowl top... frame rails... etc.
    I was going to run '30 roadster quarters behind '30 closed car cowl and doors on my sportster...
    but I found a pair of '30 sport coupe quarters... beltlines matched...
    my plan had been to remove the lower beltline bead for about 4" in the trailing edge of the door,
    weld in a flat patch which blended to the upper bead and then mount my outside latch handles about 1/2" below the former bead's lower crease...
    making it look like it was planned for as finger clearance when opening …
    figured I could replace the door easier than the quarter if I pooched something...
    and yes, I have pooched !
    ……. go c28 go ! ...
  6. HelminenHotrods
    HelminenHotrods
    from Finland
    Swage line is same as belt line ?
    Tig welded the shortened doors, rather than overlaying like original. IMG_20200203_193609.jpg IMG_20200203_193645.jpg
    -Markus H
  7. GordonC
    GordonC
    Nice work!
    winduptoy likes this.
  8. HelminenHotrods
    HelminenHotrods
    from Finland
    Inner structures slowly coming together, also made decklid frame.
    IMG_20200225_214252.jpg IMG_20200225_214151.jpg IMG_20200225_214048.jpg IMG_20200225_213935.jpg IMG_20200225_214453.jpg IMG_20200215_215712.jpg
  9. Keep up the good work.
    kidcampbell71 and Chevy28 like this.
  10. Squablow
    Squablow
  11. newenglander
    newenglander
    Awesome job!
    Chevy28 likes this.
  12. Dirk35
    Dirk35
    That half-hoop thing you made to bridge the axle tubes so you could weld the upper 4 link brackets is brilliant. Thanks for sharing that. Does it adds and extra inch of height to the third member housing which will make your floor recess have to be bigger? Or is it forward enough on the housing that it is the same height as the upper part of the housing? But I like how you did it, and will keep it in mind.
    Kinda ****s you bought an entire Model A Sedan and only used the cowl and door skins. I personally am preferential to Sedans over open cars, but that is just my personal taste.
    Your work is outstanding. Thank you taking the time to share. I know it takes a while to take the time to stop and clean up stuff and take pictures. Then it takes even more time to build the post and write it up to share, so thank you for that and keep the updates coming.
    Oh yeah,, now you'll need to change your user name since you sold the Chevy. :D:D:D
  13. scrap metal 48
    scrap metal 48
    Looking good.. Nice work....
    Chevy28 likes this.
  14. rusty rocket
    rusty rocket
    Very nice work!
    Chevy28 likes this.
  15. HelminenHotrods
    HelminenHotrods
    from Finland
    Thank you for kind comments !
    Dirk, the half hoop adds up one inch. Trunk is going to be quite small. Fuel tank will be placed there, and with the frame kickup and 2 inch channeling there will be room for a six pack and few tools.
    I do admid its kind of waste of an sedan, but i have stashed the tudor backhalf for future project. Would have liked roadster body, but not many around in Finland, at least for affordable price.
    Little offtopic:
    Fun score today. 81A flathead with chromed heads ! For Ol' mans 39 coupe project.
    -Markus
  16. HelminenHotrods
    HelminenHotrods
    from Finland
    Been working on trunk lid.
    First time english wheeling one piece panel this big. Came out fine. Room for filler, but happy with the shape. IMG_20200312_222450.jpg IMG_20200312_222421.jpg IMG_20200312_222546.jpg Made trunk lid bead and handle, to fit V shape on the above trunk panel. Still need to do mechanism for latch/handle and trunk lid hinges. IMG_20200322_210308.jpg IMG_20200322_210318.jpg IMG_20200317_211858.jpg IMG_20200320_232235.jpg IMG_20200320_232259.jpg IMG_20200322_210103.jpg IMG_20200322_210149.jpg
    Deutscher, 49ratfink, rod1 and 37 others like this.
  17. manyolcars
    manyolcars
    Your work is Awesome!
    Flynn's_57, Stogy and clem like this.
  18. Just Gary
    Just Gary
    Amazing! :cool:
    I love the little "V" in the center of the "above trunk panel" (aka "tulip panel").
  19. Nice work,enjoying this.
    Chevy28 likes this.
  20. clem
    clem
    Now that’s impressive !
    Especially like the curves on the boot lid and the little extra swaging between the seat and boot lid.
    Surprised that you didn’t fabricate your own quarters with ability like you have.
    Thanks for taking us along.
  21. Bonehead II
    Bonehead II
    How do you bend that square tubing like that, super job.
  22. HelminenHotrods
    HelminenHotrods
    from Finland
    Thank you ! This is learning process for me, and first time doing full panels. At some point i want to try and make guarterpanels myself, atleast now i have good templates !
  23. HelminenHotrods
    HelminenHotrods
    from Finland
  24. sloppy jalopies
    sloppy jalopies
    Excellent work,
    looks like you could make about any panels you need...
    I see the square tube inner structure in your pic...
    I build with panels from different cars so a cage like your's would really help...
    I recently drew up a little print of the about same idea... drew it about 1" lower with [4] 1"x3" tabs on each side welded along the top of a 1/2" conduit frame work...then drill through the trunk gutter and into them... I could then use clekos to align and hold the panels while I build the subfloors...
  25. WB69
    WB69
    from Kansas
    Awesome craftsmanship.
    Stogy and Chevy28 like this.
  26. Great work! Man I kinda love that little Chevy roadster!
    kidcampbell71 likes this.
  27. HelminenHotrods
    HelminenHotrods
    from Finland
    Thank you ! I had fun with that little chevy, but fourbanger and short gear ratio killed the buzz for me. Overdrive would make huge difference ! 33663506_1441458145959257_5272775746929033216_o.jpg IMG_5398.JPG IMG_5191.JPG IMG_5184.JPG
  28. She’s a real sweetheart! Thanks for the extra pics!
  29. HelminenHotrods
    HelminenHotrods
    from Finland
    Decklid handle and lock is about done. IMG_20200425_130458.jpg IMG_20200425_191511.jpg IMG_20200425_200517.jpg IMG_20200425_200546.jpg
  30. HelminenHotrods
    HelminenHotrods
    from Finland
    Small update on ford. Handle working and popping !
    Hinges made out of 39 ford hinges IMG_20200503_191642__01.jpg IMG_20200503_191710.jpg IMG_20200503_200056.jpg
    BigRRR, Deutscher, Rawrench and 22 others like this.
