Hot Rods boogered up AN aluminum threads on my fuel cell.
Discussion in 'The Hokey Ass Message Board' started by southcross2631, Mar 26, 2020.
  1. southcross2631
    southcross2631
    I got a really good deal on fuel cell the other day. It has 2 # 8 AN fittings that have been slightly cross threaded. Where can I find a thread chaser to try and save the fittings.
    worse case scenario I cut the fittings off and weld new one on. don't want to do that because I don't have a tig welder or a spool gun for my mig welder.
  2. squirrel
    Male 3/4-16 thread, eh? and you need a die?
  3. 48jeep
    48jeep
    If the threads are male threads, you can probably use one of those square sided thread files. Match the thread count up to what the AN fitting uses and file away carefully. The thread count number is stamped on each face of the file.
  4. Dick Stevens
    Dick Stevens
    These work great, at work we had a couple of different sizes and they were a life saver many times! They can be used to restore the thread without cutting off material like a die will, by running it backwards and let it reshape the damaged threads or run it to cut like a die would.
    mgtstumpy, harpo1313, sunbeam and 2 others like this.
  5. big duece
    big duece
    from kansas
    I was always under the impression the tight tolerances that the AN fittings were designed for the aerospace industry and were so much higher quality tooling than hardware grade threads of the same size. Rather than try to "correct" existing threads, may be best to replace the fitting. If the 37* taper is damaged, the best threads won't help.
  6. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    I prefer to use jeweler's files for cleaning up boogered threads. ***uming it's a male -8 so shouldn't be a big deal.
    bchctybob and onetrickpony like this.
  7. Boneyard51
    Boneyard51
    Guys, threads are threads! Don’t know how bad your threads are, but I bet they can be rescued! In my tool box I have one drawer marked threading! Taps, dies, thread files, yes they do exist! Triangle files and several universal thread restorers that look like a monkey wrench!
    But I come from a generation that was taught by the greatest generation to FIX, not replace!
    I bet you 23 beers I could restore your threads! I have done it many times on race cars that were cross threaded by youngsters! Just saying! Lol
    Bones
  8. gimpyshotrods
    gimpyshotrods
    Yup. I'd bet beer that you could file two flats in the threads, 180º apart, to the base of the threads, and it would still seal, so long as the cone is not damaged, and you get the nut on straight.
  9. DDDenny
    VANDENPLAS, hayu, Johnny Gee and 7 others like this.
  10. Graham08
    Graham08
    If they're in a tight spot, get one of these. I have a couple in different sizes that have been life savers at one point or another:
    https://www.mcmaster.com/2667a438
    It's a thread repair die. These are intended for repairing threads and aren't as finicky as a thread cutting die for running back over existing threads.
  11. thintin
    thintin
    Gotta like Mcmaster - Carr.....always something to get you out of a bind. Maybe still the fastest shipping ever.
    jim snow and Graham08 like this.
  12. onetrickpony
    onetrickpony
    from Texas
    Like Tbody said, a set of jewler's files, about $5 at Harbor Freight, and a bit of patience. Triangle shape works best.
  13. squirrel
    Thanks for looking up the die he needs.
  14. alchemy
    alchemy
    The OP said he bought a fuel cell. I've never seen a tank or cell with male fittings welded to it. I ***umed he was talking about a bung that had messed up internal threads. Maybe he'll stop ghosting us and let us know which he has.
  15. big duece
    big duece
    from kansas
    Probably like the one from summit, cut them off and get new an8 to pipe thread fitting. Drill, tap, install. SUM-293210_ml.jpeg
    Sent from my SM-G900P using The H.A.M.B. mobile app
    VANDENPLAS likes this.
  16. 32v
    32v
    from v.i.
    Drill it out and install a an bulkhead fitting
  17. DDDenny
    That crossed my mind too!
    Not saying this is the case with @southcross2631 but I sure wish guys would take the time to (at a minimum) educate themselves about components they use on their projects.
    Also, knowing the difference between taps and dies sure would make discussions here go a little smoother.
    https://www.google.com/search?q=alu...VTvJ4KHc6lA4YQ_AUoA3oECAoQAw&biw=1280&bih=752
    Not sure I understood you correctly but the above search does not agree with your statement.
    Just noticed big duece posted the photo I was about to post.
  18. big duece
    big duece
    from kansas
    If you can get your hand inside to tighten it up... good idea!
  19. The thread restoring files that I bought from
    Harbor Freight have saved a lot of threads for me.
  20. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    I have one exactly like this in the '32. Actually kind of nice not F'ing with pipe threads, adapters and additional fittings, but remember (especially on these) anti-seize is a necessity!
  21. big duece
    big duece
    from kansas
    Also, depending on what your fuel requirements are you might want the an10 size...
  22. RichFox
    RichFox
    Some guy from 767 O'haul used to bring me a -8 potable water fitting. Stainless with a -8 thread on one end. Threads a little ******ed. I used a jewelers 60 degree file and a female fitting with lapping compound to clean up his threads. He kept coming back so I guess it worked.
  23. southcross2631
    southcross2631
    This is the fuel cell that I have . I will figure it out. DSCF3616.JPG The fittings just won't screw on . I need to cap one and one goes to the fuel pump.
    bchctybob likes this.
  24. Budget36
    Budget36
    Can you put up a blurrier Pic? I can almost make it out...;)
  25. southcross2631
    southcross2631
    Yes I will post one up in the morning. :cool:
    Boneyard51 and Budget36 like this.
  26. bchctybob
    bchctybob
    Sometimes asking a simple question is brutally painful, ain't it southcross?
    I would have suggested the chaser die like the one from McMaster-Carr and totally expect to get flamed about how the AN fittings are close tolerance and you'll f it up with a cheap die even though the active sealing surface is the taper and the threads just have to be good enough to take the proper torque.
    BTW, you're movin' right along on the wagon, lookin' good!
  27. southcross2631
    southcross2631
    Thanks to the people with all of the suggestions. I bought a 3/4-16 die and had it fixed in about 5 minutes per fitting. Remember to spray WD-40 on the die threads or it gums up aluminum.
    I am glad that people are so willing to help even though some of the posts were going to be a lot of work. DSCF3637.JPG
  28. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Glad you fixed it. One suggestion... PLEASE say you have some other method (straps) of mounting that cell than just those feet.
    Speedwrench likes this.
  29. southcross2631
    southcross2631
    Yes it set in a cage with a strap over the top.
