Technical What did you do today?
Discussion in 'The Hokey Ass Message Board' started by Daniels Auto Repair, Jul 9, 2016.
  1. Mmmm, doughnuts.
    Lil32 and jimmy six like this.
  2. terry k
    terry k
    from toledo oh
    I was working on my boat at the marina(inside) when they came and sent us all home until Apr. 13. Man I was so close to being finished.
  3. cheepsk8
    cheepsk8
    from west ky
    Worked some more on my new wiring harness. Cranked it for the 1st time with a keyswitch. Had a pushbutton switch before and just wired to crank. Still have a lot to do but I can move it around again. 20200327_143304.jpg
    40two, Hamtown Al, LAROKE and 4 others like this.
  4. Jalopy Joker
    Jalopy Joker
    yep, maybe if you did not go home like instructed
    mad mikey likes this.
  5. RICH B
    RICH B
    Slow with the pictures; but the Monday I cut and crimped a couple A/C hoses for the '33, ran out of fittings before I got very far. Next I put the wiper motor on the '47; then figured out I had no idea where the rubber gaskets for the towers were; then I worried that maybe I never had it place with the heater. Dug out the heater and ran up to the shop with it the Wednesday and hung it on the firewall. It all fit together, so I put the dash on so I could trim the upper corners that I had forgotten to do sometime in the past. Gave up looking for the tower pads, found some rubber washers that will probably work better anyways. Yesterday I made a stand for the trunk lid and DA'ed of a few years worth of crud. Attacked with a shrinking disc today and eliminated a few lumps. Wish there were more access holes on the backside to ding it out better.
    IMG_20200323_112238 (Medium).jpg IMG_20200323_172101 (Medium).jpg IMG_20200325_090018 (Medium).jpg IMG_20200325_091317 (Medium).jpg IMG_20200325_091348 (Medium).jpg IMG_20200327_163856 (Medium).jpg
    40two, mad mikey, j-jock and 3 others like this.
  6. harley jim
    harley jim
    Looking really good 31 vickey[emoji106]
    Sent from my SM-A102U using Tapatalk
  7. Gimpy, don’t forget to clean out the inter cooler (we call it a charge air cooler) if it has one. I am guessing her car is gasoline powered, but I have seen a very nice road tractor literally get totaled when the goofball roadside mechanics replaced a turbo on a Cummins and didn’t clean the oil from the CAC. The engine sucked up the oil and oversped. By the time the driver got it shut down, the engine had blown up and ripped itself from the chassis.
  8. 56don
    56don
    Perfect spring day here today. 80 degrees, sunshine.....I went fishin'
    blowby, chryslerfan55 and Budget36 like this.
  9. gimpyshotrods
    gimpyshotrods
    Diesel. I will clean everything all the way out.
  10. gimpyshotrods
    gimpyshotrods
    Today I dragged a wheel and a Saginaw power steering reservoir over to a friend's shop.
    "Moved" the valve stem hole to correct a mismatch in the wheel set, and welded two AN -6 return fittings on the power steering pump reservoir. 90797717_3097155320317395_6749598233024004096_o.jpg
    40two, GordonC, mad mikey and 4 others like this.
  11. glrbird
    glrbird
  12. The37Kid
    The37Kid
    We've loaded our third dump truck load of leaves today. Bob
    40two, chryslerfan55 and Lil32 like this.
  13. leon bee
    leon bee
    I shouldn't post this, but it's an example of the depths to which some of us can sink. I'm pulling the engine out of my wife's former car, a 2013 Fiat. At least 2 days for me to get it out, lord only knows how long to get another engine back in there:
  14. vinny harms
    vinny harms
    from Earf
    birth day febuary 21 2008
    chryslerfan55 and stanlow69 like this.
  15. WB69
    WB69
    from Kansas
    Worked this morning. Then burnt pastures in the afternoon and evening. Just got home. Was a long day!
  16. David Gersic
    David Gersic
    from DeKalb, IL
    Spent the afternoon in the garage, welding on 22ga scrap for practice.
    Needs work still.
  17. DRUGASM
    DRUGASM
    Finally reached a point where this can go back on tires and off jackstands.
    40two, chryslerfan55, MO_JUNK and 5 others like this.
  18. Budget36
    Budget36
    May I suggest you get some 1/2 plate/scrap, and just work on your beads. Use a "little cursof E" motion moving along. Just turn the heat up-most likely will not penetrate and the bead will be on top-but will get you into a good habit.
    Now with thin metal like you have, you really don't want to run a continuous weld anyways.,
    It's a lot easier to start on thick stuff and work your way down, but I was raised with a stick welder so using a wire welder was easier to learn. Best of luck!
  19. David Gersic
    David Gersic
    from DeKalb, IL
    I’m ok on thicker stuff. New to trying thin sheet metal.
  20. Budget36
    Budget36
    Learn to tack the thin stuff and then flip it over, make sure you are going all the way through.
    It looks like your welds are laying on top of the metal, what does the backside look like?
  21. David Gersic
    David Gersic
    from DeKalb, IL
    First pic is top. Second pic is bottom.
  22. Budget36
    Budget36
    OK, so I snipped a pic of the back side and have circled poor/no penetration, kinda comparing to your topside pic, easy to see why. Take a look, see if you understand it.
  23. harley jim
    harley jim
    Maybe turn the wire speed down a little
    No blow outs so that's great. [emoji106]
  24. WTF really
    WTF really
    She runs and charges. Going to help a good friend tomorrow then play with the wiring. Screenshot_20200328-220628_Messages.jpg
  25. tombstone
    tombstone
    from sk.canada
    Almost finished my “bomber” style seats today , incorporating a simple tilt mechanism A6BCD1C2-32CF-4018-B9B0-B0EBC814152C.jpeg 41A56CD0-895E-47AF-AB18-B687C7E56422.jpeg
    40two, GordonC, chryslerfan55 and 4 others like this.
  26. That is exactly why I work on big diesel trucks! Man, I feel for you.
    chryslerfan55 and deathrowdave like this.
  27. Today, Little Truckdoctor and I rebuilt the entire front suspension and steering linkage under my O/T Ford Ranger work truck. Not a very fun job, but very enjoyable to work with my son!
  28. Tom Sherry
    Tom Sherry
    Valve adjustment on my '37 Packard 115C
  29. swade41
    swade41
    from Buffalo,NY
    I dilly dawdled on the Henry J, figuring out where I wanted my fuel regulator and then making a simple bracket for it, I'll add a few lightening holes and polish it tomorrow since my knee was getting to swollen to be on it any longer today.
    20200328_173234.jpg 20200328_173223.jpg 20200328_185133.jpg 20200328_185238.jpg
    40two, 61Cruiser, LAROKE and 8 others like this.
