Projects Fuel filter with 5/16if fittings
Discussion in 'Traditional Hot Rods' started by oj, Mar 23, 2020.
  1. oj
    oj
    I've been trying to find a fuel filter that has 5/16 inverted flare fittings at each end, maybe 1 1/2 diameter and a couple inches long, fittings at each end. I think they were normal filters back in the '50's but I can't find one anywhere, I need one to ****on up my fuel system.
    Anybody know where I can order one?
    Thanks, stay safe, Oj
  2. jimvette59
    jimvette59
    Try a 70s Jaguar
    stillrunners and oj like this.
  3. OLDSMAN
    OLDSMAN
    Go to a parts store that has access to Donnelson filters. If they have a book browse through it to see if they have one. They are probably the largest supplier of filters around. If they don’t have it it isn’t out there.
    oj likes this.
  4. Sporty45
    Sporty45
    neilswheels and mgtstumpy like this.
  5. Almostdone
    Almostdone
    Not strictly what you asked, but you can get NPT x flare fittings and make other filters work with your flared lines too. That’s what I did.
  6. squirrel
    Just curious...why do you think this? Have you ever seen one? If so, where?
    (I use a 33032 and bubble the ends of the metal line, and connect with rubber hose. Easy to find a replacement at a parts store, when you need it)
  7. oj
    oj
    Seems I remember hard line going to and from the fuel filters, I might be wrong and maybe there were male adaptors in there but seems like OEM wouldn't have extra fittings when they could just make the filter to fit the line.
  8. saltflats
    saltflats
    from Missouri
    3/8 inverted flare was common, you could use a reducer fitting or maybe they make a flare nut for 5/16 line with the 3/8 inverted flare nut.
    mgtstumpy and oj like this.
  9. oj
    oj
    I think I found one, difficult to see the size but like SaltFlats says I can use the bigger nut on the line.
    Thanks to jimvetter59 that suggested to look for a Jag, I searched that then went to Chrysler and then to GM where I found this one.
  10. squirrel
    That's 3/8, from the mid 60s (65 Vette 396).
    The 50s saw a lot of hard line connected fuel filters, but they were usually the gl*** bowl type, which had 1/8" NPT x 5/16" IF fittings screwed into it.
    oj likes this.
  11. seb fontana
    seb fontana
    from ct
    Napa. Napa Gold 3481 looks like for 3/8th ferrel fitting nuts [?] but will get you in the ball park.. Depends on counter person.
  12. 57 HEAP
    57 HEAP
    I think I found this one at AutoZone, but I'm not sure. Maybe for a Ford. Has pipe thread on the outlet side, so not exactly what you asked for.
    KoolKat-57 and oj like this.
  13. squirrel
    Ford used that 1/8" NPT screw in filter for years, mostly 60s-70s. I forgot all about that one.
  14. my heater uses this one,
    They are special order and Expensive like 14 bucks
    There’s a wix cross reference, for it to 7B45293E-C01F-48A5-A533-B12702DF68A8.png C3E7F775-FDC4-4A87-ACBA-2F73B04F2C8A.png
  15. squirrel
    interesting, that fits 1960 Fords. I guess that was the predecessor to the little one.
  16. oj
    oj
    Which heater do you use it on?
  17. neilswheels
    neilswheels
    from England
  18. old torpedo heater
    “Champ junior job maker” very early 70s
    It uses a standard burner ch***is that you’d find in any oil burning furnace or boiler.
    thing kicks *** too. Very Quiet and clean.
  19. KoolKat-57
    KoolKat-57
    from Dublin, OH
    [​IMG]1982 Ford V8 4.6 litre 2 barrel filter. Been using the same one on my '57 tri-power for years!
    KK
  20. stillrunners
    stillrunners
    from dallas
    Mopar even had them in their transmission line.....have an original some where around......think it was from a 1962 Dodge.........
  21. Bob Lowry
    Bob Lowry
    Look up AC fuel filter GF90, used on mid-60's corvettes and 350hp, 327" motors. Here is a picture...all of
    the restoration sites sell them for between $50-$60... Carid has similar listed for $12..just doesn't have the
    neilswheels and oj like this.
  22. jimvette59
    jimvette59
    I'm glad you found what you needed, that one looks like a 60s Rochester Fuley filter.
    oj likes this.
  23. bschwoeble
    bschwoeble
    Bob Lowry, good info. I found that same filter on Amazon. I bought several just to have them. Jim Forbes, that filter was on my "64" 300 horse Corvette. I am a bit **** when it comes to fuel filters. The filter with the rubber line on each end, to me, are so tacky.
    oj likes this.
  24. oj
    oj
    Since you guys helped me find one, i thought I'd post the results of having it: 069.JPG 070.JPG
    Now I think I can 'nail down' my intake and make the line dropping down to the pump.
    Thanks for the help, Oj
  25. FOURTYDLX
    FOURTYDLX
  26. Almostdone
    Almostdone
    Nice and clean looking. Thanks for closing the loop.
    Cosmo49 likes this.
  27. mgtstumpy
    mgtstumpy
    Ive a similar NOS one of these packed away somewhere, for aesthetics only:D
    Cosmo49 and chryslerfan55 like this.
  28. Sporty45
    Sporty45
    That is different! What is it from?
  29. jimvette59
    jimvette59
    Wow I should have remembered that because I had a 63 fuley in my 34 3 window coupe.
  30. David Gersic
    David Gersic
    from DeKalb, IL
