Projects Got a little something to put the rocket in.
Discussion in 'The Hokey Ass Message Board' started by J_J2, Feb 24, 2020.
  1. engine138
    engine138
    from LI NY
    great start good luck
    loudbang and J_J2 like this.
  2. J_J2
    J_J2
    Engine is now at the machine shop. I’ll be starting back to work on Monday, but will be working 4 10’s so I’ll have 3 full days to work on the car.
    brEad, Thor1, Surfcityrocker and 7 others like this.
  3. loudbang
    Just found this thread and it looks like a great start. :)
  4. J_J2
    J_J2
    Well the heads are junk, both are cracked at the exhaust valves at the center exhaust ports, at least I can start looking for some #10’s.
  5. vtwhead
    vtwhead
    gotta expect **** like that. Look around, there has to be some heads near you.
    J_J2 likes this.
  6. J_J2
    J_J2
    I’m already looking, I don’t think it’ll be too much of a problem.
  7. J_J2
    J_J2
    Finding a set of heads is turning out to be a bit more difficult than I had originally thought, but the search continues.
    chryslerfan55 and Cosmo49 like this.
  8. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    Seems like a long # on the fender and door for a race car, hahahahah
    J_J2 likes this.
  9. J_J2
    J_J2
  10. J_J2
    J_J2
    [​IMG][​IMG]
    Started repairing holes cut into trunk floor (right at the shock mounts [emoji35]) until my back told me I was finished
    Thor1 and chryslerfan55 like this.
  11. 56sedandelivery
    56sedandelivery
    ^^^It probably broke the floor mounted shock mounting, and/or someone started to repair it^^^. Fabricate a shock cross-member when you're done with the floor repair. I had a 51 Bus Coupe, bought it right here off the HAMB. the rear interior-trunk divider was all cut up; it looked like a hatchet was used to do the job. And why, I could't figure; finally decided some old farmer had done it so he could put his rowboat into the trunk and push it forward into the interior; only thing that made any sense. I did a better job of straightening out the hatchet job, and covered it with aluminum. Should have kept my Coupe!!! I am Butch/56sedandelivery.
  12. curbspeed
    curbspeed
    Make sure you buy the phenolic spacers for the carbs. They work.
    chryslerfan55, triumph 1 and J_J2 like this.
  13. J_J2
    J_J2
    Picked up a pair of 371 heads from a gentleman in Boise, and dropped them off at the machine shop. [​IMG][​IMG]
    He just happened to have this in his garage.
    Now I’m going to focus on removing the closed driveline. I’ve seen a couple of kits to replace the rear leaf springs Walton Fab, TCI, anyone have any experience with these?
    brEad, King ford, Thor1 and 4 others like this.
  14. BJR
    BJR
    Wish I had something to put my rocket in.:D:eek:
  15. J_J2
    J_J2
    Got a call from the machine shop, one of the heads is junk so the search for one #16 is on, damnit.
  16. tubman
    tubman
    ****. Hate to hear this. I was thinking about replacing the "no number" heads on my '51, but this makes me reconsider. They were completely rebuilt and have all new ancillary parts; how restrictive can they be?
  17. 56sedandelivery
    56sedandelivery
    Looked into Ross's aluminum heads? I know, I know, but I don't want to hear anything more more about it.
    chryslerfan55 and J_J2 like this.
  18. J_J2
    J_J2
    I think Im having a run of bad luck, I still have a couple of options though. Positive thinking, positive results. (But I’m still keeping my fingers crossed.
    brEad, Thor1, chryslerfan55 and 2 others like this.
  19. J_J2
    J_J2
    That is definitely one of the options [emoji6]
  20. BuckeyeBuicks
    BuckeyeBuicks
    from ohio
    Every time I see one of those bare J-2 manifolds I think of the one I bought for $20.00 at Carlisle a few years ago and had to carry from one end of the grounds to the other. Still makes my arms and fingers sore when I think of it.
    chryslerfan55, J_J2 and loudbang like this.
  21. J_J2
    J_J2
  22. Paul
    Paul
    Editor
    Good news!
    chryslerfan55, loudbang and J_J2 like this.
  23. J_J2
    J_J2
  24. vtwhead
    vtwhead
  25. J_J2
    J_J2
    Well, new head is cracked as well, same spot, but is repairable, so we forge on, sacrifices to the Oldsmobile gods have been made.
    Thor1, chryslerfan55 and loudbang like this.
  26. vtwhead
    vtwhead
    where are they finding these cracks?
  27. oliver westlund
    oliver westlund
    that makes 3 cracked heads!? wow!
  28. sliceddeuce
    sliceddeuce
  29. J_J2
    J_J2
    Center exhaust valves
  30. J_J2
    J_J2
    Actually 5, with the 2 originals. But I hope the 3rd time will be the charm.
    brEad, loudbang and chryslerfan55 like this.
