Customs 1940 Ford Sedan: “Family Truckster” Build
Discussion in 'The Hokey Ass Message Board' started by JohnnyCASHcadillac, Feb 7, 2020.
  1. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    That was connected to my engine compartment heater blower...
    Thor1, loudbang and chryslerfan55 like this.
  2. ccain
    ccain
    I see the CA ***igned VIN tag. My '60 F100 also has an ***igned VIN. But it this car an old "lost ***le" survivor or an older restoration?
    Either way, man that thing is clean.
  3. That heater tube looks like exhaust off of a 2 stroke(snowmobile). Was that an aftermarket item for sale at one time?
  4. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  5. V8 Bob
    V8 Bob
    That was a factory option, along with the conventional hot water heater.
  6. v8flat44
    v8flat44
    Not a big fan of more Chevy in a Ford builds, B U T......I love 348s !
    That's gonna be a GR8 ride. Very nice !
  7. Thanks, I didn't realize they used the hot air system on the "modern" cars. (sealed beams, hydraulic brakes)
    hotrodharry2 and loudbang like this.
  8. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    I found a complete runner and it’s going in!!
    I need more degreaser....
  9. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    brEad and Thor1 like this.
  10. BJR
    BJR
    That engine ought to bring the front end down some. Never seen a W motor with blue valve covers.
  11. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    I stood on the engine and my extra 200lbs did not do much.
    Right now is the stock springs with the top 2 leafs removed.
    I was thinking I need to go to a posie reversed eye.
    How many leafs can I take out 60869468344__82420D2D-A661-4BF6-B269-F6AC18ADD4CF.JPG
    Thor1 and loudbang like this.
  12. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    Looking over the block it has orange on the back side. I think someone picked blue some time ago. Blue intake, valve covers and pan.
  13. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    brEad, bchctybob, enloe and 4 others like this.
  14. scrubby2009
    scrubby2009
  15. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  16. mcsfabrication
    mcsfabrication
    Great looking project! Where did the rear suspension kit come from please?
  17. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    It’s on jack stands now for mock up but I have a Posie rear leaf setup going in
  18. cheepsk8
    cheepsk8
    from west ky
    Very nice, I p***ed once on a 40 sedan at the Louisville Nats a few years ago at a great price. Now you are making me have regrets over that decision. Keep up the good work. I am watching.
  19. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    I am gonna have generator placement problems.
    Anyone know any different mounting locations??
  20. When I'm using original spring packs, I'll keep the main, and next one to it, then alternate leaves, for the balance. See how that works.
  21. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    The new stance is with the posie 2” drop spring.
    I can already tell that was a good move. The stance is right and the front has for forgiveness.
  22. Ok. Knew you were thinking of going to a Posies spring, didn't realize you had it already installed.
    JohnnyCASHcadillac and loudbang like this.
  23. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    It was worth the 200$$
    brEad, bchctybob, Thor1 and 1 other person like this.
  24. Two thumbs up! For the comment, and the stance!
  25. Posies spring and drop axle? or a Posie spring with a stock axle. Make sure you post up with the rear end mods too. I'm going to dive into my '47 in the future.
  26. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    Posie spring and dropped axle. Split wishbones.
    Disc brakes.
    Also learned the difference in a Posie dropped steering arms versus the TCI.
    TCI accommodated the disc brake bracket.
    bchctybob, Thor1 and loudbang like this.
  27. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    Little help:
    As I am mocking up the rear posie spring setup the bump in the frame is getting in the way of the bracket. It’s on both sides.
    Anyone know what it is?
    Cut it out?
    Hammer it in??
  28. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    ADVISE AND HELP:
    I was getting ready to put the Posie rear spring setup in.
    These seem to be right where the bracket needs to go. Anyone know what the are originally for. They are on both sides.
    Should I cut it out?? Hammer them back in? Thanks
    bchctybob and loudbang like this.
  29. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  30. warbird1
    warbird1
    Where is this located at on the frame? I looked under my two-many door and couldn't find anything like you have pictured.
