Technical What did you do today?
Discussion in 'The Hokey Ass Message Board' started by Daniels Auto Repair, Jul 9, 2016.
  1. David Gersic
    David Gersic
    from DeKalb, IL
    Yeah. Needs work. Fighting to keep it from blowing holes through.
  2. Boneyard51
    Boneyard51
    Dang! That makes my stump look kinda puny! I bet you had something bigger that a Polaris to pull it out!
    Bones
  3. jimmy six
    jimmy six
    I attached a stainless steel welding rod to a cap screw that holds on the timing cover. Once you find tdc, many ways, I marked that spot with a paint line on the timing cover to your tdc on the damper . Then made the rod to come across it painted white. You can expand the photo I’ve included at the damper and see it. 0523E038-4B27-4B64-A847-85B51D804261.jpeg
  4. Hombre
    Hombre
    Great idea I'm stealing it. Thanks Jimmy!!
  5. Cliff Ramsdell
    Cliff Ramsdell
    I used three 4x8 sheets and I’ll have a small pile of left overs and maybe a 40x36 piece. I used more than I thought and that’s without any real mistakes.
    Cliff Ramsdell
    chryslerfan55 and Hombre like this.
  6. ERguitar
    ERguitar
    0321201159.jpg Maybe I've been "sheltering in place" too long.
    Decided to see if I could convert a T5 with an electronic speedometer to cable drive using an old cabledrive speedo T4 transmission I've been running.
    I swapped the tailshaft housings and speedo gears, used some JB weld, the speedo gear clip and the hole in the output shaft to hold the gear in location.
    Drove it last night and it seems to work fine so far.
    I'm not recommending it at as a tech solution until I get some miles on it but perhaps it will give someone else an idea to play with in their down time.
  7. 57 HEAP
    57 HEAP
    Watching the USNS Comfort leave port Saturday, bound for NYC. Stay safe everyone.
  8. blowby
    blowby
    from Nicasio Ca
    Tractor with backhoe. Took a week. I hauled it to the local compost yard. They said "Get the hell out of here!". After some pleading they agreed to take it if I returned with a saw and cut it up, which I did.
    chryslerfan55 and Boneyard51 like this.
  9. Boneyard51
    Boneyard51
    Well, your stump may be bigger!! But I’m quicker, it only took an hour and a half to get mine out!!lol
    Bones
  10. Dooley
    Dooley
    from Buffalo NY
    Working on head swap... Raising compression 20200330_174110.jpg 20200329_113007.jpg
  11. Jalopy Joker
    Jalopy Joker
    Have you lost your mind?
    40two and swade41 like this.
  12. Dooley
    Dooley
    from Buffalo NY
    Working on it
    swade41 and Hombre like this.
  13. HOTRODPRIMER
    HOTRODPRIMER
    When I'm not working in the garage I have started watching some old hot rod movies on DVD's. HRP
  14. sliceddeuce
    sliceddeuce
    Machined a few parts for a home made q/c
  15. TA DAD
    TA DAD
    from NC
    Made some shock plates for my Studebaker ! studebaker build 001.JPG shock plates 003.JPG shock plates 008.JPG shock plates 005.JPG
  16. blowby
    blowby
    from Nicasio Ca
    Tore up the landscaping on the side yard, have been putting down pavers for more hot rod parking! Almost done..
  17. Lloyd's paint & glass
    Installed a rear disc brake kit on the 39 Chevrolet. The drums were fine, but i get paid to do this **** :D 20200330_144106.jpg
    lothiandon1940, Lil32 and Hombre like this.
  18. 61Cruiser
    61Cruiser
    Looks trick. Even better cause you made it yourself [emoji106]
    chryslerfan55, Hombre and swade41 like this.
  19. 61Cruiser
    61Cruiser
    Definitely a future hot toddler there.
  20. 61Cruiser
    61Cruiser
  21. WTF really
    WTF really
  22. 61Cruiser
    61Cruiser
  23. TRENDZ
    TRENDZ
    A little port clean up after bigger seats... F6F037DA-0F61-49F5-B592-C3AB9728CE30.jpeg
  24. swade41
    swade41
    from Buffalo,NY
    Thanks, part of the fun
    Hombre likes this.
  25. 2deuces64
    2deuces64
    Prepared the out side of a powered coated frame for body color IMG_20200327_164135394.jpg
    chryslerfan55, 40two, Hombre and 2 others like this.
  26. mnjeff
    mnjeff
    Ah, Spring! Sunshine, birds chirping, and sanding on the Willys....outside, in my jammies....
  27. pnevells
    pnevells
    finishing up top end after winter freshen up, new valve springs, valve job
  28. oldsfrench
    oldsfrench
    from France
    What did i do today ?
    Nothing funny
    I can’ t go to work
    Here in France non essential business are closed
    You are not allowed to go outside
    If the cops caught you in your car on the road : they give you a big ticket
    But this morning i had to go at work
    Because it is the last day for this month
    And i had to send the papers for employees paiment
    Now i am a little bit bored,
    Drink some alcool watch tv
    It’s so cold here i wait for better days to
    Work on the 1956 olds
    F.......,cking virus will shut down my business for a month or so
    I am hamboolic i know that
    But i hope i wont be a real alcoolic
    Because i stay at home for the next month
  29. lothiandon1940
    lothiandon1940
    .............I'll drink to that!:eek::D
    chryslerfan55, Hombre and harley jim like this.
  30. Hombre
    Hombre
    oldsfrench, Man it is tough everywhere. Sometimes it is easy to not realize that everyone every where is suffering. Most important thing is to stay safe. It will get better and in time you will be back working on that Olds. Once again Stay Safe over there!
