Technical Model a spring on 46” axle
Discussion in 'Traditional Hot Rods' started by Jay.S, Mar 29, 2020.
  1. Jay.S
    Jay.S
    Will a stock model a front spring fit on a 46” axle? If I de-leaf it will it fit? Or am I stuck buying a different spring or 48” axle?
  2. thirtytwo
    thirtytwo
    No , you can buy or just buy or have a shorter main leaf made
  3. Mr48chev
    I had a main leaf made for my trailer a while back and it was 100 bucks in Yakima WA.
    This SoCal link somewhat tells what eye to eye length spring you need for your axle.
    https://www.est1946.com/frontsprings.aspx
  4. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    Or buy a model A axle for your spring.....
  5. krylon32
    krylon32
    from Nebraska
    The right length new spring for your axle can be bought for a little over $100. Why complicate things?
  6. Jay.S
    Jay.S
    Thanks for the replies. I’ll just be buying a new front spring.
    With a 46” axle do guys run into wishbone problems with the turning radius?
  7. 56don
    56don
    I think...the Model A through 1934 spring is 1 3/4 inches and the 35 and later is 2" in width.
  8. 97
    97
    It really depends on whose 46 inch axle you have, the perch bolt distance varies by manufacturer. It is the distance between the perch bolts that determines the length of the spring . The spring should be shorter than the distance between the perch bolts by about 5 inches from memory! So that the shackles are at a 45 degree angle once the weight is on the car.
    If you have a stock Ford axle which has been dropped , they also vary by years . I think Roadsters.com has a chart.
  9. the flatlander
    the flatlander
    If your perch centers are 34" , you'll need a 29" spring. usa made from Posies is best. Not trailer springs from Speedway etc. Junk ! BOL
  10. RICH B
    RICH B
    No more than normal as the wishbone bosses are narrower.
