Technical Rolling Bones Hot Rod Rearend
Discussion in 'The Hokey Ass Message Board' started by lake_harley, Mar 30, 2020.
  1. lake_harley
    lake_harley
    I've been drooling over photos and videos of Rolling Bones hot rods the last couple days and have a question. The rear tires generally appear to be tucked up very close to the body, and it seems they're perhaps even more narrow than any V8 banjo rearend I'm aware of. Maybe not? If they are narrower many of the cars appear to have a rearend that has the axle "snouts" on the rear hubs/drums. Granted, they're typically quick changes, but how do they accomplish a rearend that's quite narrow, so that the tires and wheels don't stick out, but appear to retain the stock looking banjo rearend hubs? Do they narrow banjo bells and use bolt-in axles but just somehow adapt the banjo looking hubs? Do they cut, re-taper the end, cut a new keyway slot and thread the end to shorten a regular banjo axle? My guess is neither of those, so how do they keep the tires so tucked against the body, or am I imagining something that's really not different?
    Lynn
    kadillackid likes this.
  2. lodaddyo
    lodaddyo
    Im pretty sure they use quick change read ends with steel bells from Winters. Ive seen some cars they built with 35/36 rear ends and quickchange
  3. Weedburner 40
    Weedburner 40
    Probably the best way to get this info would be to contact Rolling Bones themselves.
  4. winduptoy
    winduptoy
    Been reading their books....QC Ford V8 rear end is what it says....what you will see if you race Judy IMG_20200330_163344277.jpeg
    Sent from my XT1585 using The H.A.M.B. mobile app
    sko_ford and catdad49 like this.
  5. lake_harley
    lake_harley
    So-o-o.....how did the rearend in the sedan become so narrow? Has it been genetically modified? Depending on wheel backspace the rearend under the sedan isn't anything more than 54" to 56" at the wheel mount surface, is it? The narrowest stock banjo I know of is a Model A at about 58" or 58 1/2".
    I did some more searching and found that Winters standard V8 QC is 56" at WMS, but they'll do custom widths, I think. But, at $3,000+ for a new QC, I'm too much of a tightwad to be that cool. :rolleyes:
    Lynn
  6. winduptoy
    winduptoy
    Wheel offset
    lake_harley likes this.
  7. clem
    clem
    Now where’s the fun in that ? Besides, that sounds too easy. Far better to have pages and pages of speculation and theory’s .
    ( although in reality, I’m sure that someone on here will actually know ).
    catdad49 likes this.
  8. alchemy
    alchemy
    Probably V8 Ford rearends with new slide in axles (can narrow it as much as you want then), and they cut the backside off an old hub and slide it over the studs for the "look".
    Malcolm and lake_harley like this.
  9. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    Yes, I've seen the hubs are aesthetically placed for the look online someplace. I think a party at rolling bones video on YouTube.....
    deucepickup32 likes this.
  10. Tim
    Tim
    from KCMO
    Guys he already answered his own question you can order the winters rear that narrow.
    some of the cars do have slide in axles but not all of them
  11. lake_harley
    lake_harley
    You're correct Tim, I probably do have my answer and that would indeed likely be either a now QC with bolt-in axles or a conversion like Hot Rod Works' kit.
    I can also understand that in some cases the distinct banjo hub protrusion is perhaps just "window dressing". That's about like a QC looking rear cover on a 10-bolt GM rearend.o_O
    Lynn
  12. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    You trying to end this informative thread for some reason.....?
  13. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    This is my morning reading material, and good threads are scarce these days....
    Pist-n-Broke likes this.
  14. A Boner
    A Boner
    Early V8 rear, not latter V8 rear.
    continentaljohn likes this.
  15. lake_harley
    lake_harley
    :D By no means....discuss to your heart's content! At least we're all "social distancing" while we're discussing things here!
    Lynn
  16. continentaljohn
    continentaljohn
    Yeah Like @A ***** said 1932 1933 1934 bells with stock 16 inch rims most likely 16x4.5 and a few examples of beautiful cars with a similar look BF481DF9-25C6-4C82-ADAC-85B2D26D0BB5.jpeg 6336F0F9-9947-45E9-BEBC-9445B8EF8E5A.jpeg
    akoutlaw, OFT and Tim like this.
  17. the-rodster
    the-rodster
    Interesting....
    Rich
  18. Tim
    Tim
    from KCMO
    @B*** built some “fake” axle stubs for the Wade coupe. He put a lot of fantastic build videos of it on you tube maybe it’s featured in one or in the build thread?
  19. lake_harley
    lake_harley
    Interesting comparison of the two cars viewed from the rear. Seems quite a difference of tire to wheel well clearance on the two. Do you know specifics on the rearends and/or wheels used? I'm not as well versed as others, but the car on the left is a '32, correct? Are they a bit wider than the Model A on the right? I'm going to do some searching now to try to answer my own question.:confused:
    Lynn
  20. alchemy
    alchemy
    Lynn, in the under-construction black coupe there is a new Winters V8 style rearend. Those can be ordered brand new ***embled in any width you want. It's being built by Steadfast and he really likes to tuck the wheels in tight. A very clean look I think.
    The two coupes facing away show a 32 on the left and 31 on the right. If the 32 has an old Ford banjo rear it's probably an early one, at least 36 or before. Usually a 37-40 or 41-48 rear sticks the wheels out more than that.
    continentaljohn and lake_harley like this.
  21. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    I have a 57 inch width Winters rear under my 32 pu with 16X6 inch wheels with the center at neutral and 750/16 tires and have 1 inch of clearance between the side walls and the box on each side. I have a 56 inch Winters rear in my deuce roadster with So-Cal 6 inch knockoff wheels and 750/16 tires and have an inch of clearance there also.
  22. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    That’s due to some careful measuring, I’m sure!
