Technical Mill lathe buyers let’s see what your doing
Discussion in 'The Hokey Ass Message Board' started by oldsfrench, Apr 1, 2020.
  1. oldsfrench
    oldsfrench
    from France
    ED58212F-D8B3-409E-BF29-9B90E971FD14.png image.jpg image.jpg image.jpg hello hambers
    As a mill and lathe Technician
    , i thougt it would be cool to
    Show what we do for professional or private machining work
    Here in France is a very popular and very rare race car
    I am talking about the famous Renault 8 gordini
    (The red one was mine )
    I had some of those cars and still love them
    Did you know American people
    Philippe Charbonneau was the same French guy who designed the Chevrolet Corvette and the Renault 8 ?
    So here are what i am working on since a lot of years
    I am rebuilding some parts for Renault 8 manual gearbox because those parts aren no more avaible
    Few pics to explain what i am talking about
    First is the rear end of the gearbox
    It is not a aluminium foundry
    I machine from a block
    Second pic is the tachometer gear
    Let’s see what you’re working on your mill lathe machine
    oj, j hansen, stanlow69 and 2 others like this.
  2. Hemi Joel
    Hemi Joel
    from Minnesota
    Nice work. That is some complex machining, especially if you did it on manual machines.
  3. 19Fordy
    19Fordy
    I noticed the question mark which reinforces the common belief that Harley Earl designed the Corvette.
    Charbonneau worked for GM and with Earl but was not the chief Corvette designer.
  4. oldsfrench
    oldsfrench
    from France
    Cnc are involved
    The hard part here is i had no (oops don’t know the right word)
    I had no « draft or no any 3D tool « to work with
    I had to take my old caliper and burn my brain to go on
    stanlow69 and VANDENPLAS like this.
  5. Fitty Toomuch
    Fitty Toomuch
    from WVa
    I owned a red 65 R-8, loved that little ****box.
    Nice car.
  6. Zuffen
    Zuffen
    from Sydney
    I had a bunch or R10's over my poor years when I purchased my first house.
    Great car for the times.
    I almost purchased an R8 Gordini sans engine.
    I did have Renault Dauphine Gordini when I was very young.
  7. sliceddeuce
    sliceddeuce
    Please tell me you had a rotary table for that gearbox case part. Very nice work. Regatds, Jerry
  8. MeanGene427
    MeanGene427
    from Napa
    I learned how to make a steel cube on a lathe the other day- sweet!
  9. Chappy444
    Chappy444
    I made some gauge spacers for my model A at my buddies shop... first time using a lathe for me... good learning experience. Totally basic for you machinist guys but great fun for me. Used some aluminum pipe and had to turn it down (see I even learned some new terms...lol) inside and out to make it right
  10. Lepus
    Lepus
    machining4.JPG machining7.JPG machining1.JPG machining2.JPG machining3.JPG machining5.JPG Nice work, Oldsfrench. Here are come parts I made for my '36 Dodge: a beehive oil filter housing, tail light bezels and lenses, new inserts for two '49 Pontiac speaker grilles (cut on a waterjet) that will go in the new dashboard that I will make some day, and two brackets for one of my brothers to mount lights on the luggage rack of his daily driver truck.
  11. ekimneirbo
    ekimneirbo
    Oldsfrench, Maybe a little language barrier, but the housing does not look like it was machined from a billet block . What type of machine did you use ? How did you determine what dimensions and tolerances were needed? It looks like a casting that was machined with CNC controls.
    In your second post you mentioned not having a "draft" which I ***ume you mean a "drawing or blueprint". Then you mention using a "caliper" to measure the part. I can give you some credit for a language barrier, but you need to explain a little better, because right now what you have said doesn't make sense.
    Let me explain a little. The backside of the housing doesn't look to have been machined from billet......not just because of the texture, but a few other details. To machine a part with that many complex moves, you need some way to make a drawing and you need an original part to measure not only the simple dimensions, but the complex blended radius that intersect at unknown points as well as the non-standard curves. While cutting things like I mentioned are easily done with a CNC machine, you have to have dimensions to program the machine. That means you have to have some pretty serious inspection equipment to measure an existing part.......not just calipers. Please explain how you managed .
  12. I don’t know,,,it looks like a machined part to me,,,,,looks like it was blasted after the mill work . There are a couple of lines that are very close,,,but ,,,leave a cutter line near it .
    Looks great !
    What I’m really impressed with is the tail light lenses that Lepus made.
    They are better than new !
    Tommy
  13. oldsfrench
    oldsfrench
    from France
    You are right Tommy
    The back side is blasted
    Sorry for my poor langage specially for
    Technic words
    I’ll post more pics soon
    I have to find other pics in an old computer
    I really took a caliper
    I had the original part in my hands
    Desoto291Hemi likes this.
  14. oldsfrench
    oldsfrench
    from France
    That is what I made image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg
    41 GMC K-18 and j hansen like this.
  15. oldsfrench
    oldsfrench
    from France
    Here is the original part
    You can see the caliper
    continentaljohn likes this.
  16. j hansen
    j hansen
    I wish I could make parts like you.Really nice.But I only have manual machines,lathe from the -60s and I think the milling machine is from the 1920-30s Skärmavbild 2020-04-02 kl. 13.02.10.png
  17. oldsfrench
    oldsfrench
    from France
    Manual machining are hard to work with
    You must be talented with your hands and brain
    Cnc can make more complicated parts
    But they just do what you say them to do
  18. TRENDZ
    TRENDZ
    Here is a blower drive adapter I made recently...
  19. Hey Oldsfrench, you do good work there! I have an old manual lathe and mill and have taught myself to use them, but looking at your drawings with the all the dimensions has made my brain hurt!
  20. khead47
    khead47
    Long sleeves and lathes do NOT get along. Ask me how I know.
  21. Beautiful work guys,,,,,
    Oldsfrench,,,,no reason to apologize for your English ,,,,,,it is a lot better than I can do for the French language,,,,LoL.
    About all I know is Escargot,,,and,,,,les miserable,,,,, .
    And Hansen,,,,,your manual machines are great,,,,,it’s a lot more than I have .
    Trendz,,,,excellent work .
    This is hot rodding,,,,it’s all about doing the best you can with what you’ve got !
    I am so proud of the younger guys working and trying to keep this going .
    It amazes me to see pics of these old cars from around the world,,,,,in places I would never suspect of seeing an old American hot rod !
    Great job everybody!
    Tommy
    oldsfrench and j hansen like this.
  22. khead47
    khead47
    A good manual machinist can demand 2 or 3 times the pay of a CNC guy.
  23. Just by looking at the sketches he made, it is obvious that he knows what he is doing.
  24. Happy 444 it would be very wise for you to pull up the sleeves of your shirt past your elbows. Anyone that has worked on these machines can tell you how fast you can get snagged and pulled into the machine. That's a good way to get seriously hurt. It's a very dangerous practice. Be safe.
    harpo1313 and Halfdozen like this.
  25. sliceddeuce
    sliceddeuce
    My 13X60 South Bend nearly removed a sweatshirt from me. Will not make that error again.
  26. continentaljohn
    continentaljohn
    image.jpg @oldsfrench awesome work and cool build and wish I had a cnc. . @j hansen very cool machines and shop ,what is the brand of mill. I haven’t see that model before and it’s cool.
    I had a apprenticeship at a mold and model shop back in the day. Not a lot of CNC machines especially small shops . It was amazing the work that was done just using mechanical machines.
    My old machines and as the sign says Standard Service :D
  27. squirrel
    let's see...the day before yesterday, I turned down a carburetor part, for a B&S engine in my 60 year old mini bike, using my 1946 South Bend lathe. The part is a reproduction, and was made wrong, by about 0.005".
    I haven't made any fancy car parts like that transmission case, or speedometer gears. But I use the lathe and mill often, mostly just for little jobs, so they become indispensible.
  28. MeanGene427
    MeanGene427
    from Napa
    You are very lucky- the machine wouldn't even slow down if it ****ed you in. The one thing I don't like about my old 16x60 South Bend is the on/off/reverse switch, mounted on a stalk coming up from the back, so you have to reach over the work area to operate the switch- better not have anything dangling. Been around a couple bad accidents, and reasons why machines seem to have a ridiculous amount of guards these days. First one when I was about 14, one of the farm families in the Southern Tier of NY had an old belt-drive sawmill, and they were using it during the winter. One of the sons leaned over the exposed blade shaft to fill an oil cup on a bearing, and a square- head set crew snagged his heavy winter coat, and he was instantly gone. Second was a post hole digger on the back of an 8N tractor, fellow helping the neighbor with a new fence. The old guy didn't think it was drilling fast enough, so he decided to climb up on the top link off the three-point hitch for some weight, dangling rawhide shoelace- he went round and round inside the hitch
  29. MeanGene427
    MeanGene427
    from Napa
    Oldsfrench's prints look a lot like my old engineering prints from my days building streets and freeways- all those "R"s being radius points for all the big and little curves. That one would be similar to a plan for a street roundabout, with planters around the outside. Now imagine you just had the surveyor stake all that out, and then some truck driver backs in and runs over a half-dozen of those radius points lol
  30. El Hueso
    El Hueso
    EA651B5E-51C8-469C-BA1B-F099DCA8B38B.jpeg I just picked up this Logan 14” lathe. It’s in good shape other than a few bushings in the carriage(& the color). It had been sitting for well over a decade.
    ekimneirbo and continentaljohn like this.
