Technical Vintage Speed Rochester tripower base kit
Discussion in 'The Hokey Ass Message Board' started by J_J2, Apr 3, 2020.
  1. J_J2
    J_J2
    cactus1, Gofannon, Deuces and 2 others like this.
  2. 41rodderz
    41rodderz
    from Oregon
    Your fuel inlets look like they are coming out the back , have you tried them on the intake to check interference with the fitting and the next carb?
    J_J2 and mad mikey like this.
  3. J_J2
    J_J2
    I did, I have 90 deg. fittings and there’s good clearance. These are going on a J2 manifold and Im trying to get as close to factory as I can.
    41rodderz, egads and Deuces like this.
  4. J_J2
    J_J2
    s55mercury66 and Deuces like this.
  5. Almostdone
    Almostdone
    Interesting. If those carbs were on a Chevy 348 the float bowls would face forward. If so, the ‘front’ fuel inlet would be consistent with the 1958 models. They came out the side after that. Help me learn here - are yours installed correctly, or backwards?
    RMR&C and J_J2 like this.
  6. Hemi Joel
    Hemi Joel
    from Minnesota
    The float bowls should be towards the front. Otherwise the fuel splashes away from the Jets when accelerating.
    Deuces and J_J2 like this.
  7. J_J2
    J_J2
    I realized that after I posted the pics, I had a duh moment lol
    s55mercury66, Almostdone and Deuces like this.
  8. Taboo56Chevy
    Taboo56Chevy
    Is that middle carb fuel inlet pointing downward? That would be a late 60s unit then.
    J_J2 likes this.
  9. J_J2
    J_J2
    They’re backwards [emoji54]
  10. J_J2
    J_J2
    I have the primary torn apart at the moment, I just threw that on the manifold for the pic.
    Deuces likes this.
  11. carbking
    carbking
    This may help:
    Jon
    bchctybob, J_J2, egads and 1 other person like this.
  12. J_J2
    J_J2
  13. Rich S.
    Rich S.
    Here’s a pic from my 57 Pontiac. It also has 90 degree fittings. It may help. IMG_3577.JPG
    J_J2 and bchctybob like this.
  14. J_J2
    J_J2
    egads and bchctybob like this.
  15. Almostdone
    Almostdone
    Pretty exciting when you start building the carbs. I get it. Keep us posted as you go.
  16. 41rodderz
    41rodderz
    from Oregon
    Cool beans .
    J_J2 likes this.
  17. manyolcars
    manyolcars
    did you buy off ebay?
    J_J2 likes this.
  18. J_J2
    J_J2
  19. J_J2
    J_J2
