Projects 1934 Plymouth 2 door sedan build
Discussion in 'The Hokey Ass Message Board' started by RMR&C, Nov 19, 2017.
  1. Mike Colemire
    Mike Colemire
    What a find, I've seen them years ago but it sure been awhile. Goo to see you back on this and thanks for the help you gave me.
    chryslerfan55, RMR&C and loudbang like this.
  2. RMR&C
    RMR&C
    from NW Montana
    I finished most of the metal work on the doors....figured I should chop/build the garnish moldings before I get too far. I don't have the correct garnishes for my 2 door, but I do have a full set for a 4 door.
    After much slicing and fitting, I finally got them tacked. Had to make a piece to add length on the bottom.
    Sharpone, dwollam, brEad and 5 others like this.
  3. bobbytnm
    bobbytnm
    Atta boy Scott
    Looks like time consuming work, but I'll bet there is a real sense of satisfaction when it all comes together.
    Looks good
    Bobby
    chryslerfan55, loudbang and RMR&C like this.
  4. RMR&C
    RMR&C
    from NW Montana
    Next up is the gas tank. My original plan was to mount a universal tank in the back seat area inside the car. I even bought the tank....
    After more thought, I really don't want the gas tank inside the car....it takes up a lot of room, plus the filler cap would end up pretty high on the body.
    So I ended up getting a stock tank and mounting it more or less in the stock location.
    When I built the ch***is, I bobbed the rear frame rails...luckily I saved those pieces....
    I was able to tuck the tank up under the body nicely, then made some mounts and added a hd spreader bar.
    I'm liking how this gives the car a more balanced look. Still need to do the finish welding, etc. Haven't decided if I will make a cover for the tank...
    Sharpone, mgtstumpy, dwollam and 16 others like this.
  5. bobbytnm
    bobbytnm
    See, it pays to not throw anything away...
    I kind of like the exposed tank look
  6. JOYFLEA
    JOYFLEA
    Love it , I wish I hadn’t put the tank in my Tudor.
  7. nunattax
    nunattax
    no need looks great as is
    chryslerfan55 and RMR&C like this.
  8. RMR&C
    RMR&C
    from NW Montana
    An update at last.....I finished the body work on the doors and got some primer on them
    Then I finished welding/boxing the rear frame horns. Also built my trailer hitch.
    Yes, a trailer hitch, to pull my teardrop(eventually). A receiver type hitch would look like ***, to me anyway, so I designed something different. The spreader bar/pipe is 1/4" wall so plenty stout for my lil trailer...
    Also chopped the wood that goes around the rear window. Had to make a new lower piece for it.
    Sharpone, mgtstumpy, dwollam and 10 others like this.
  9. goldmountain
    goldmountain
    I built a trailer hitch for my car too, but because I realize how slow I am, built the teardrop trailer first.
    Sent from my SM-T350 using The H.A.M.B. mobile app
    mgtstumpy, loudbang, brEad and 2 others like this.
  10. Gary Addcox
    Gary Addcox
    Should be setup as a Plymolet ! LOL. I love Ford sheetmetal, but the early Mopars are so neat and underrated. Good luck and I will be watching.
    loudbang, RMR&C and chryslerfan55 like this.
  11. Gary Addcox
    Gary Addcox
    dan31, he just has no bedside manners at all ! He will be heavily critiqued by US ! LOL.
    loudbang, dan31 and chryslerfan55 like this.
  12. Slick111
    Slick111
    The chop you did is perfect not to extreme but did change the look just right .
  13. Gary Addcox
    Gary Addcox
  14. Mike Colemire
    Mike Colemire
    Glad your back on it!
  15. Gary Addcox
    Gary Addcox
    What are those 8 holes/half holes on either side of the intake just below the partial valve cover flanges ? Just kidding !
  16. bobbytnm
    bobbytnm
    Fantastic!!
    I'm glad you're back at it. Its really looking good.
    You don't have to convince me about the trailer hitch, I figured I'd have one on my roadster pick-up project also.
    Bobby
  17. RMR&C
    RMR&C
    from NW Montana
    Haha, yep, I built the teardrop trailer last winter....which is why not much has gotten done on the car. Oh well, I have a couple other hot rods to tow it with.
  18. Gary Addcox
    Gary Addcox
    Trailer hitch looks great.
  19. RMR&C
    RMR&C
    from NW Montana
    So I tore down the FE.......No big issues, everything is OE standard. Needs total rebuild. Got about 10 pounds of crud out of the water jackets.....
    Took the block, crank etc to the machine shop last week.
    Sharpone, mgtstumpy, dwollam and 7 others like this.
  20. RMR&C
    RMR&C
    from NW Montana
    I hung the front sheet metal to see how it's gonna fit.... the hood is really bent up in places.
  21. brEad
    brEad
    That is going to be great!
    Hombre, loudbang, RMR&C and 1 other person like this.
  22. bobbytnm
    bobbytnm
    Wow!
    The look with the front sheet metal in place is awesome. Its gonna be one sharp car
    Bobby
    Hombre, loudbang and RMR&C like this.
  23. roseville carl
    roseville carl
    wow, props on a great job so far, great skills too....................
  24. Arthur
    Arthur
    from NC
    I know this is old,but just in case you are still wondering,my 33 Ply coupe has a beam front axle. IIRC,it is a PD.
    Hombre, chryslerfan55 and loudbang like this.
  25. RMR&C
    RMR&C
    from NW Montana
    Well, I got the block and heads back and all of the engine parts.....gonna do some ***embly this weekend.
    Also been beating and heating on the hood. Getting closer, man this thing is FUBAR
    Sharpone, mgtstumpy, dwollam and 8 others like this.
  26. RMR&C
    RMR&C
    from NW Montana
    I got most of the bottom end together and the heads ***embled. Been trying to find a decent oil pan, mine is fubar and the POS one I ordered from Summit is unusable. Finally found an OEM pan yesterday.
    I need to buy more parts for this engine, but don't really want to spend the $$$ with unknown future finances.....sux, now I have the time, but no money.
    Sharpone, mgtstumpy, dwollam and 5 others like this.
  27. 392
    392
    I hear ya RMR&C. Play money for many is done and could be norm. I’ll say again nice build.
    chriseakin, RMR&C and loudbang like this.
  28. milwscruffy
    milwscruffy
  29. RMR&C
    RMR&C
    from NW Montana
    Nothing! Haven't touched it since spring. I took on a large rust repair project for a customer and just haven't had any time. Hopefully soon!
  30. bobbytnm
    bobbytnm
    Dang
    I was sure hoping someone was making progress. I have been stalled on my project as well.
    Hopefully soon (I keep saying that and time keeps flying by)
    Good luck
