Technical Engine, Early Olds Rocket tech summary.
Discussion in 'The Hokey Ass Message Board' started by bluthndr, Mar 7, 2005.
  1. Paul
    Paul
    Editor
    that is a Dynaflow.
    it is my understanding that after the Hydromatic factory burned down the '53 Olds and Cadillac motors had Dynaflows attached in place of the Hydromatic.
    Paul
  2. BigJim394
    BigJim394
    Well, for those searching swaps and ebay for vintage Olds aftermarket parts, here's some manufacturers to be on the lookout for:
    GOTHA, Thomas, and McGurk: variable ratio adjustable rocker arms and lifters/pushrods
    Spaulding, Mallory, DuCoil, Dupoint, Mr. Gasket, Joe Hunt, Vertex: Distributors and Magnetos
    Offenhauser, Edelbrock, Weiand, Cragar: Intake manifolds
    Ansen and B&M: Floor shifters for the early Hydramatic Transmissions
    Trans-dapt: Engine/Trans adapaters & remote oil filter adapters
    Hildebrandt: Oil filter byp*** kits, Starter motor changeover adapters
    Schiefer, Weber: Flywheels and clutches
    Hurst, C-T: Engine mounts and engine/trans adapters
    Offenhauser: main cap support strap kits
    Clay Smith, Engle, Crane, Howards, Herbert, Barnes, Iskenderian, McGurk, Almquist, Weber: Camshafts
    Cragar, Beatty, ISKY, M/T, Weiand, Delta: Blower drives for Olds engines
    MOON, Edelbrock, Offenhauser, Hidebrandt: Valve Covers
    MOON, Weiand: Aluminum race type front engine covers
    Grant, Mickey Thompson, Forgetrue, Jahns, McGurk: Pistons
    Mickey Thompson, Howards: Connecting Rods
    Mickey Thompson: Roller rockers
    Mickey Thompson:Stroker Cranks...C-T and maybe Reath, Howard, and Jewel may also have made them
    Paxton, Latham: Supercharger kits (Paxton using the McCullough supercharger)
    That's off the top of my head...rocket guys feel free to add (or subtract)anything...I didn't mention Fenton exhausts as I havent seen any for sale for over a decade, and I think they made valve covers and maybe intakes, but I never see them for sale anymore.
  3. Paul
    Paul
    Editor
    you're making my mouth water,
    I had a pair of Holmes valve covers,
    and a Wilcap starter switch over
    and had lust in my heart for a Potvin blower setup
  4. speedshifter
    speedshifter
    Studebaker adj. rocker arms are supposed to be adaptable to Olds& are sometimes listed as 1.8 ratio. I have found them to be about 1.5 & the geometry is wrong. I strongly discourage their use on Olds. I think anyone who tries them will be disappointed. If you want to buy a set of rockers, new Cad shafts, & reamed Olds stands cheap contact me. Greg
  5. Paul
    Paul
    Editor
    Thread is almost 10 years old,
    That's me quoted up there both as Paul Smith and as '60 Style :p
    Ok, question for those wiser than myself. I purchased this fly wheel , guy said he took it off a 371 many years ago , he thought the engine was a '58.
    I have a '59 371 and a '56 324 , can I use this fly wheel on either ?
    Any suggestions appreciated, if anyone can I.D the flywheel , brand etc that would be great info also .
    Thanks
  7. F&J
    F&J
    If you can't get an ID by all those numbers printed on it,,,
    It looks like it might be neutral balanced? I don't see counterweighting. If so, it will work on your 56
    57 up all had external balanced wheels from factory. Neutral wheels can be used on a rebuilt motor that was internally rebalanced
    Check it on a tire bubble balancer to see if it is neutral balance
    4t6ford likes this.
  8. tubman
    tubman
    One observation. I don't mind seeing technical threads dragged back up. I would really hate to see these threads get lost. I have a '49 Olds Rocket myself. It has been rebuilt and has a lot of good stuff on it (Gotha rockers, Isky cam, an Offenhauser dual quad manifold, etc.). I don't have a current use for it, but you can bet if I find something, it will be back, front and center. Anybody that knows anythiong new or unique, post away, no matter how old the thread is.
    59sedandelivery likes this.
  9. Paul
    Paul
    Editor
    flywheel looks like it was bolted on but never run
    I would run that on a mild motor in a minute
    4t6ford likes this.
  10. Thanks for the responses guys. I had tried a Google search on numbers but maybe I wasn't
    Holding my tongue quite right.
    Good info on the balance , thanks. I havnt lifted the trans off my 371 yet but being a '59
    I'm expecting to find balance weights .
    Paul , you are correct , I was told it had been fitted to an engine and never run, there is
    No sign of ever having a starter engaged , ring gear is unmarked.
    Ring gear has no leading edge either , strange or ?
  11. GOATROPER02
    GOATROPER02
    from OHIO
    It's neutral balanced..... 56 and earlier Olds.....And it's drilled for dowel pin so early caddy as well
    4t6ford and loudbang like this.
  12. Thanks all for the input. Helps me decide what direction I'm going. The flywheel will go on the 324 with a LaSalle trans that's converted to closed drive and then it'll all
    Get slotted in my '39 .
    Means the Model A will get the 371 , I can live with that !
    Anybody have a flywheel for a '59 371 available? Hey if ya don't ask ya don't get, right!
    Dago 88 likes this.
  13. F&J
    F&J
    I don't have an Olds parts book newer than 1958. I am pretty sure someone put up some info on the later flywheels, and there were more than just one on the 59-64. I don't know who would have a book to look it up.
  14. Paul
    Paul
    Editor
    I have come across a couple stock '57-'58 stick flywheels but only one '60 371 and no 394s.
    Must be quite rare.
    I'm sure you could find a new aftermarket one pretty quick, Ross Racing, McLeod...
  15. Paul
    Paul
    Editor
    I've also got a Cad LaSalle converted to closed drive behind a 324 in one of my projects.. maybe one day I can get back to it, Damn thing just sits there collecting dust..
  16. falcongeorge
    falcongeorge
    from BC
    Thats the setup I am using. By the way, I am on the hunt for a set of period high ratio adjustible rockers, if anyone has a set...
  17. F&J
    F&J
    So, would aftermarket be balanced for each model of late 371 and also 394? Seems unlikely?
    What "is" the balance difference on these 59-64 motors?
    I do have a GM iron 394 flywheel, but I don't know what year it is.
  18. F&J
    F&J
    I thought you had a lead on a partial set of Thomas rockers? If you do, I will look at my single rocker shaft with 8 Thomas rockers, to see what ratio they are...and if they freed up yet. Been soaking in parts washing tank for a year :)
    Hey, time f'ng flies....it was 50 years ago this year, that I bought my first set of adj Olds rockers for a 57 field car... I wasn't even in high school yet.
    warbird1 and 4t6ford like this.
  19. falcongeorge
    falcongeorge
    from BC
    I did, but I havent heard back. I will follow up, its been a couple weeks. I gotta chase down the lead I got last night as well, honestly, I am a little skeptical about that one...
  20. Paul
    Paul
    Editor
    When I say I've never seen one I mean never seen one attached.
    I've had several external balanced stock stick flywheels over the years but only a few that were still attached to their original engines.
    The stock steel flywheel that came off my '60 371 is now bolted to my '63 394, I did not have it reballanced and it seems to spin nice with no signs of out of ballance.
  21. engine138
    engine138
    from Commack NY
    OK question from what I've seen here you can or can not use a 324 stock manifold on a 303 ? example: 54' 324 manifold on a 53' 303 block?
  22. They'll bolt up. It's just a matter of exhaust port sizes. Early 303's had round ports. Not sure if they were all round until the 324's, or if later 303's had square ports as well. @GOATROPER02 will know for sure.
  23. RainierHooker
    RainierHooker
    from Tacoma, WA
    Probably a little late, but I looked up the patent stamped into @4t6ford 's flywheel. The patent is ***igned to Schiefer, filed in 1952, and approved in 1955. That'd make it a really early aftermarket 303 flywheel.
  24. Fedcospeed
    Fedcospeed
    Iam in the middle of getting a 303 and 324 built. Please keep this thread going.Even if just a small tidbit gets past on its worth it.Thanks JF
  25. martyk98
    martyk98
    from washington
    I've got an old Hilborn FI unit with 303 casting numbers on it. Anyone ever hear or see of an Olds 303 with a Hilborn FI unit on it?
  26. mad mechanic
    mad mechanic
    I've not, but I've been searching for one....
    Please could you post some pictures of it and tell us the part number?
    Jay
  27. Car Guy Russ
    Car Guy Russ
    I have a question. I have a 1961 olds 394 that I'm having rebuilt. I have all parts except main bearings, I need .010 over. I can find 59-60 and 62-64, but no 61 main bearings. My question is, does 1961 stand alone, are the mains different, did they make three different bearings for the 394 in the 5yrs run of that engine or are they all the same bearing?
  28. saltracer219
    saltracer219
    Tony @ Ross Racing Engines would be the one to talk to. Just google them and give him a call
  29. Many Thanks to bluthndr and everyone else who contributed to this thread...It's great!
    I used to have a 394 in the '60s with an Isky E2 and Mallory dualpoint that I raced. Stilll think about that great engine even though I now have a Pontiac 428 that I love too.
