Technical FULL FENDERED 28-29 Ford Running board question
Discussion in 'Traditional Hot Rods' started by The37Kid, Apr 5, 2020.
  1. The37Kid
    The37Kid
    If you have a 28-29 Ford that is FULL FENDERED and has a nice looking rake what is the distance street to the front & rear running board brackets? Got a bare frame no axles, just wondering what those dimensions will be. Thanks. Bob
  2. phill
    phill
    Hi Kid, on my Sport Coupe it's 5 1/2" at the f
    Hi Bob,
    on my Sport Coupe in avatar it's 5 1/2" front and 6 1/2" rear. Tire size 165/65 ×15 And 255/70 × 15. Hope it helps. Phill.
  3. The37Kid
    The37Kid
    Thanks! That gives me something to work with, want to set the ch***is on blocks or jack stands, looks a bit low with just one inch clearance.;) Bob
  4. sloppy jalopies
    sloppy jalopies
    Something I do to save my shins is slide and tape a piece of radiator hose over the ends of the brackets.
    raven likes this.
  5. phill
    phill
    It has a lot more than 1" of clearance. Those measurements are under the running board brackets. Lowest part on the car is under the middle of the front axle at 4 1/4". Nothing hangs belo6the running boards.
    Phill.
  6. The37Kid
    The37Kid
    Good tip, but they will be shelf brackets for the life of the project.:) Bob
