Technical They bug me.
Discussion in 'Traditional Hot Rods' started by 28 Ford PU, Apr 6, 2020.
  1. 28 Ford PU
    28 Ford PU
    from Upstate NY
    Does anybody know of a Teflon or Silicone spray that could be put on the front of the radiator to make it easier to clean the bugs off?[​IMG]
    loudbang, chryslerfan55 and Deuces like this.
  2. 26 T Ford RPU
    26 T Ford RPU
    I made a bug and stone guard. the holes are about 1/4'' JW
  3. You could spray it with silicon spray, wd40 or Pam cooking spray.
    on longer road trips why not put a piece of window screen in front of the grill ?
    loudbang, 62rebel, Texas Webb and 4 others like this.
  4. hotrodjack33
    hotrodjack33
    I made a reducing adapter and a 4 foot piece of flexible vacuum cleaner hose that slips over the end of my electric leaf blower. First I use it from behind the radiator to loosen up the bugs and ****, then blow it off from the front. It was the only way I could figure out how to clean a radiator that is behind '32 grille bars.
  5. I would think that cooking spray would work best. it is more heat resistant than says liquid wrench or WD40. The rad should only get to a couple hundred degrees but still that is hot.
    I use lemon pledge on the aluminum bits on my motors to make them easier to clean. It seals them up good so that the glunk don't get into the pours but I have never tried it for radiator bugs.
  6. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    ******, what a great idea with pledge on alum!
    Bugs in the radiator are just one of those things that makes a car cool.
    I can tell you who drives their car and who pulls it in a trailer by some crusty old bugs. Wear them as a badge of honor.
  7. HOTRODPRIMER
    HOTRODPRIMER
    The dead bugs prove to everyone you drive your car! :D HRP
    Nicholas Coe, TagMan, nochop and 6 others like this.
  8. RMR&C
    RMR&C
    from NW Montana
    You could wax each fin with Q tips. Grab a few beers, make a day of it!:)
  9. You need to let it dry (?) for a couple of hours, if you get it hot right away it will darken on you. Spray it and wipe it and go take a nap.
    I remember cruising (walking) through a hot rod show (NSRA or the like) and listing to a fella say that the trick keeping the bugs off if you were going to drive it was to put and extra layer of past wax on the front of the car then just go to the wand wash when you got where you were going. Two cars down from that guy was a '37 Chebby that had bugs all over the front of it. I got up close and discovered that at least 2/3 of them were painted on. I talked with the guy and he said that he got tired of trying to get the bugs off at a show so he painted them on for camouflage. I still like the idea.
    I know that this is undesirable (at least for me) but they do make a nose bra for almost anything. That may help.
  10. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    painted bugs sounds worse than a crybaby doll
  11. The guy that painted 'em was a real artist though. ;)
  12. 41 GMC K-18
    41 GMC K-18
    Bugs in the teeth !
    loudbang, jaw22w, 61Cruiser and 4 others like this.
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I've pulled into a few events like that and left my car alone.
  14. 28 Ford PU
    28 Ford PU
    from Upstate NY
    I like the pledge idea. I’ve been using it for a quick detailer for a few years now.
    I’ll give it a go!
  15. 41rodderz
    41rodderz
    from Oregon
    #Bug lives matter .:p
  16. 28 Ford PU
    28 Ford PU
    from Upstate NY
    I agree totally!
  17. solidaxle
    solidaxle
    from Upstate,NY
    Doug,
    Just trailer it. Problem solved.
    I hope I helped!:D
    winduptoy, 28 Ford PU and Kan Kustom like this.
  18. solidaxle
    solidaxle
    from Upstate,NY
    Doug,
    I hope I helped!:D
    Kan Kustom likes this.
  19. Kan Kustom
    Kan Kustom
    Very nice job.
  20. Kan Kustom
    Kan Kustom
    I have never got the whole trailered car hating thing. If a guy wants to drive everywhere and put the wear and tear, maintenance, etc. and is happy with that form of enjoying his hotrod, then that is exactly what he should do. On the other hand If a guy gets his enjoyment from trailering in a car that is as perfect as he can build it and maintain it, slowly cruise around for a little cruising then that is exactly what he should do. I see both sides and don't understand why others care how another guy enjoys his car. Non of us are clones and I just can't get p***ionate about either way.
  21. 41 GMC K-18
    41 GMC K-18
  22. ekimneirbo
    ekimneirbo
    from Brooks Ky
  23. man, I had a gr***hopper that was stuck to the radiator that was almost as big as a chicken!! Well not that big but I was sad when it fell off.
  24. 41 GMC K-18
    41 GMC K-18
    Was it as big as this chicken?
    alanp561, loudbang, Hnstray and 4 others like this.
  25. Pensive Scribe
    Pensive Scribe
    My late friend did the same thing as 26 T Ford RPU. It worked out well for him.
    alanp561 and loudbang like this.
  26. Petejoe
    Petejoe
    from Zoar, Ohio
  27. Corn Fed
    Corn Fed
    This isn't what you asked, but if you have a car with an exposed radiator like a Model A, just use a toothbrush to clean the bugs off the fins. If you let them dry, they actually flake off even easier. You'd be surprised at how quickly you actually can clean it with just a toothbrush. Ya gotta go horizontally with the fins though. Just don't tell your spouse why their toothbrush always looks dirty ;)
    alanp561, loudbang, 61Cruiser and 2 others like this.
  28. 28 Ford PU
    28 Ford PU
    from Upstate NY
    You going to pull it behind the “32”. ‍♀️
  29. solidaxle
    solidaxle
    from Upstate,NY
    That would be a site. Then you would have to explain why. If it will help, I'll sacrifice the 32 and drive in front of you to clear the path. Hopefully all the events don't get shut down this summer.
    loudbang and Texas Webb like this.
  30. winduptoy
    winduptoy
    This is what I use to clean the bugs off the front of my bus...and out of the radiator on the Model A's...and the windshields...works good
    Sent from my XT1585 using The H.A.M.B. mobile app
    loudbang and Nicholas Coe like this.
