Technical Post some pics of your radiator overflow bottles for 30s hotrod
Discussion in 'The Hokey Ass Message Board' started by Choppedcoupe, Apr 7, 2020.
  1. Choppedcoupe
    Choppedcoupe
    Building a "traditional" model A on 32 rails with 32 grill (see avatar/profile photo) with a sbc. I hope to take it to the drag strip regularly, so, I need a radiator overflow bottle. I may run a hood from time to time, so it needs to fit under a hood side panel. I'd like one that is interesting and cool!
    Please post photos of your radiator overflow bottle ideas?
  2. dana barlow
    dana barlow
    from Miami Fla.
    Depending on rules at your drag strip !.
    All the indoor car shows in the early 1960s,over flow water can was mandatory ,along with a drip pan under engine after you were set up in place for show.<I used a big cookie sheet that had about a 1inch side lip,all the way around in South Florida.
    I've used a few things,for my own rods an help my son too. On my 28A I use a stainless steel lunchbox Thermos.
    My son Lance's 23T ,
    use of a alum beer bottle{a blue one ,it's a match to rods body color.
    For a short time in the early 60s used a alum Army Canteen/highly polished,that I gave to a buddy that thought he had to have it.
    WC145, mayreed246, Stogy and 2 others like this.
  3. Retrorod
    Retrorod
    My '35 Ford overflow made from a Vodka bottle (aluminum). It's been on the car since 2002, only 50,000 miles...works good. overflow.JPG
    WC145 and triumph 1 like this.
  4. L7
    L7
    I've seen some neat ones. old fire extinguishers etc.
    I did a quick search and didn't find what I was looking for but, ran across a neat one @Robert J. Palmer made from an old metal oil filter canister.
  5. Automotive Stud
    Automotive Stud
    Hose onto the ground, it's more traditional that way.
  6. Deuce Daddy Don
    Deuce Daddy Don
  7. jhexide
    jhexide
  8. 48ford
    48ford
  9. sloppy jalopies
    sloppy jalopies
    Going on a '30 sportster,
    got the thermos [no gl***] for xmas,
    just bought a OHV 4cyl. so future engine bay pix probably won't happen...
    WC145 likes this.
  10. Bandit Billy
    Bandit Billy
    Nice idea Dana on the thermos.
    All my cars get one and I use them as recovery not just overfill. Also love the vodka bottle idea.
    seb fontana and dana barlow like this.
  11. Bandit Billy
    Bandit Billy
    Mine. Store bought (sorry) OTB Gear, mounted to the fan shroud and connected from the bottom via a polished SS line that you can see running up alongside the bottle. Ribbed for her pleasure.
    BJR, GearHeadDiver, Dino 64 and 4 others like this.
  12. 57 HEAP
    57 HEAP
    I always thought a beer can was cool...……….before I was old enough to buy it.
  13. I made this one out of some exhaust tubing and some iron plumbing fittings. It was for a survivor hot rod and I took my cues from the lakes plugs already on the car. I ended up welding a bracket and bolting it to the rad support but I seem to only have pics with the temporary zip ties in place. The clear thing was also replaced with black .
    WC145, catdad49, VANDENPLAS and 3 others like this.
  14. Mr48chev
    The metal Canteen on the T in post 7 is close to what a lot of guys used on their drag cars when they started requiring puke cans. I'm not a fan of gl*** bottles used for that although a Liquor bottle seemed to be popular in some circles years ago.
    Those stainless/aluminum water bottles are in just about every yard sale for under a buck most of the time and some of them are pretty good size. Not hard to give a brushed finish to or just paint the same color as the surroundings so they fade into the background and don't bring attention to themselves.
  15. Mr48chev
    That one Cactus1 did sure looks spot on cool. A piece of exhaust pipe and a couple of freeze plugs the right size might work quite well too.
  16. willys36
    willys36
    This is what I did in my buddy's '42 Willys pickup.
  17. willys36
    willys36
    How about this?
  18. Antique, br*** fire extinguisher gutted and plumbed for reserve and overflow, plus dipstick.
    WC145, catdad49 and VANDENPLAS like this.
  19. Jalopy Joker
    Jalopy Joker
    many shown canisters do not appear to have overflow tube from it when it gets full - some don't see way to see how full canister is, and are pretty small - guess most keep coolant low enough in radiator that if coolant ever expands it will not push much, if any out
  20. Blues4U
    Blues4U
    from So Cal
  21. My Dad's idea. The mount is a 4" exhaust clamp.
    [​IMG][​IMG]
    WC145, gotmark73, catdad49 and 3 others like this.
  22. ghalperin
    ghalperin
    That’s what I had on my ‘31.
    WC145, catdad49, UNCLECHET and 2 others like this.
  23. Blue One
    Blue One
    from Alberta
    OTB gear, ordered in pieces as a raw casting and shortened for the reduced height of my 26 T RPU radiator. :cool:
    99893BFE-D193-4FAC-9DD4-297BE39E61A3.jpeg 89DC4C83-4EB8-475C-8142-3439BA38D746.jpeg 486BF94E-6B96-4F06-942C-C3E59E8BD1A9.jpeg E1AF588D-20B1-42A2-8049-774A25B49E20.jpeg
  24. Kevin Ardinger
    Kevin Ardinger
  25. Almostdone
    Almostdone
    The drag strip will want a closed container of at least 16 ounces. They may let you by with an open container, but will probably tell you to do better next time.
  26. swade41
    swade41
    from Buffalo,NY
    My setup on a couple of cars, easy to drain 20160807_212502_zpsz9j1iqmp.jpg 20160807_212418_zps79hdqdfq.jpg
    20160807_190447_zps9pwh0nei.jpg 20160807_190535_zps6fyabtcj.jpg 20160807_190609_zps03ky2qts.jpg
    WC145, Just Gary, catdad49 and 2 others like this.
  27. rustydusty
    rustydusty
    My car had an ugly plastic "schnapps" bottle, that I replaced with an aluminum water bottle... 20190604_155025.jpg 0321191517.jpg
  28. Bursonaw
    Bursonaw
    Sent from my iPad using Tapatalk
  29. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Mine. Made from a piece of Corvette drive shaft.
    WC145 likes this.
  30. esrbuilders
    esrbuilders
    WC145, catdad49 and mgtstumpy like this.
