Technical 40 Ford deluxe 2dr
Discussion in 'Traditional Hot Rods' started by Graybeard4545, Feb 21, 2020.
  1. alchemy
    alchemy
    My 40's X-member has a big notch removed like Mike's for the shifter.
    Graybeard4545 likes this.
  2. Graybeard4545
    Graybeard4545
    from Maryland
    Great picture and advice. 4 vers 3 point mount? I am using a hurst style on the front and planning on using the Muncie tail mount. You said side to side movement on the trans when clutch is depressed? Maybe I am missing something. I am planning on a Z bar or cable for throw out bearing.
    do you have more pictures of the Z bar? front Mount? What exhaust manifold di you use?
    Thanks
  3. MIKE STEWART
    MIKE STEWART
    39 interior.jpg 327 jan 2020.jpg tail pipe.jpg 39 interior.jpg 39 interior.jpg 327 jan 2020.jpg tail pipe.jpg No movement with side engine mounts - stay away from front mounts. I have a Flaming River stronger Vega box and Ch***is Eng. bolt on mount. The orignal box was wore out, Vega drives nice. Just adapted double D in the stock steering column. Need this box to clear the 2.5 dia Corvette Ram exhaust. This was my Dad's car - bought in 1959. It has 1940 petals - The 1939 petals - clutch pulls from right side vs left. Drake repos them. This 39 has had this Munce and 327 in it since 1969. If you use the 1939 petals vs 1940 - and reclock the arm to the 6:00 position - I think you can engage the clutch fork and not need the z-bar. I am trying to keep this car true to the early 1960's look - did not want to use a hydro-clutch set up. However - I have driven a few 1940's with it and they work well. 39 interior.jpg 327 jan 2020.jpg 327 jan 2020.jpg tail pipe.jpg tail pipe.jpg
    town sedan, olscrounger and Gasser 57 like this.
  4. MIKE STEWART
    MIKE STEWART
    Next project how to shift the Columbia 2 speed rear end. Have old vac*** canister - but controls are very old and rusty. Need a cable shift or electric linear actuator - any ideas? Ring gear is 4.44 - really need over drive on the open road.
  5. Graybeard4545
    Graybeard4545
    from Maryland
    I have gotten a couple linear actuators off Amazon. Takes some looking but you can find any size or speed you need. That rear is really cool.
    I really appreciate all your help and info. Lots to think about and do .
    The car came with a new process 4speed. Kind of neat as it 1 to 1 in 3rd and 4th in over drive. Came in early 80s chevy trucks. Case is the same as a hemi 4 speed.
    Good if you have 410 + ratio rear.
    MIKE STEWART likes this.
  6. Nice car. I have one of those transmissions, although mine came out of van. It has an iron case, and a tall, set back shifter. Not sure how it's going to work for me, when it comes time to use it.
  7. mvee33
    mvee33
    Hi Graybeard, very nice 40 one of my favourites.
    For clutch operating ideas check out the hydraulic v mechanical v cable thread, I used the 39 pedals with the clutch lever reversed and extended to gain the required travel, and a ramp to guide the pull chain to the clutch fork and keep all aligned. Use modified Ford antichatter rods to the 327 to prevent front/rear movement. If you can find a T and F shifter then there is no cutting of the X member required, and a ch***is engineering ch***is center section will allow you to remove the Muncie if required, but bones will have to be split. For steering box clearance use late 60s pickup right hand manifold on the left side. Good luck with your project.
    MIKE STEWART and Graybeard4545 like this.
  8. Graybeard4545
    Graybeard4545
    from Maryland
    Thanks for the info. All things I am thinking about. It looks like the guy had a 39 pedal in the trunk as an option. What is a T and F shifter? Ford antichatter rods?
  9. MIKE STEWART
    MIKE STEWART
  10. MIKE STEWART
    MIKE STEWART
    here is a pic of the Z-bar. I am using 2.5 Corvette Ram manufolds with the Vega box. Z BAR 39.jpg
    town sedan likes this.
  11. Graybeard4545
    Graybeard4545
    from Maryland
    Great pic, thanks.
  12. mvee33
    mvee33
    Hi Graybeard,
    One anti chatter rod can be seen on the left in the picture from the ch***is to the engine block, to prevent forward/rear movement during clutch operation. Easy to modify a pair of original Ford ones to the Chev. I used some old spring shackles for the rod to block connection.
    The 39 pedal ***embly is easy to adapt to a dual chamber Mustang master cylinder, ch***is engineering and others make the simple adapter
    For the exhaust manifold to clear the original steering box, a 1968 pick up right hand side manifold
    Dorman 674-199 will work on the left side,
    there are probably others with a front facing flange.
    The T and F shifter is a top mounted shifter and a real problem solver, $450 for a smooth to operate shifter that places the lever near the original floor location for a 39 Ford. No need to butcher the ch***is. There is some information here on the HAMB, but I think they are hard to find.
    All the Best
    MIKE STEWART and town sedan like this.
  13. mvee33
    mvee33
  14. Graybeard4545
    Graybeard4545
    from Maryland
    MVee33,
    Great pictures. Great Ideas. It seems the T and F is as rare as a hens tooth. I reached out to him and his number is no longer in service. I like that shifter. I may try and write him and see if he would share the design.
    I wonder if someone else has picked that up yet?
    Thanks!
  15. MIKE STEWART
    MIKE STEWART
    Love the roller chain to the clutch fork. Cool fabrication.
    olscrounger and Graybeard4545 like this.
  16. Graybeard4545
    Graybeard4545
    from Maryland
    Update on shifter relocation for the muncie and sbc in the 40 standard.
    I made a plate to relocate the hurst shifter up and to clear the floor and tunnel. I trimmed the tunnel lip on the bottom. The stock rods worked with a little tweaking. Reverse lever had to be flipped so reverse is now next to 2nd gear on the shifter.
    I uesed the offset hurst so the shifter in now centered on the trans.
    Now on to the clutch linkage.
    bowie, MIKE STEWART and BFXJason like this.
  17. MIKE STEWART
    MIKE STEWART
    I had to heat the bottom of the 4 speed Muncie shifter and reshape it to clear the seat. Got lucky - did not melt the wire for the reverse lock out and dog ears.
  18. sliceddeuce
    sliceddeuce
  19. Bluedot
    Bluedot
    I too put a SBC and Muncie in a '40 Tudor. Like others, had to notch some of the cross member to clear the shifter. For clutch linkage, I used thru floor aftermarket pedal ***embly made by some outfit in AZ that recently went out of biz. Too bad, as it's a pretty good product.
    I did not want to go hydraulic either, and going mechanical linkage turned into a nightmare because of bad misalignment of the rod from pedal lower arm to the throwout fork. Solution: A mid-60s Chev II bell clocks the fork at about 7:30 instead of the usual 9:00, effectively lowering the rod connection point. Perfect align, works great. There are still a few of those bells around.
    mvee33, town sedan and Graybeard4545 like this.
  20. Yutan Flash
    Yutan Flash
    from Gretna, NE
    Dammit - you've got Deluxe window garnish moldings. A full set of those and a clock are the last things I need set to convert my Standard tudor to a Deluxe, but I'm not in a rush - mine's a shell that has been apart for 40+ years and still waiting its turn to look like your pics.
  21. Rustygt
    Rustygt
    from Emeryville
    Yes on the spacers, figure your engine weight etc and measure. Mine were 1 1/2 inches
  22. nobby
    nobby
    hello
    sbc in a 35-40, just been reading up on it.
    mechanical fuel pump fouls on crossmember? - where did I read that there are now fuel pumps with built in regulators / returns? for carburettor pressures? - do these live in the tank? or outside with a return to the tank?
    you are not advised to use an aluminium bellhousing with a hurst front mount? - is it because it rips the threads out of the bell housing? or just cracks them?
    - finned alloy oil pans are a no-go , no clearance, stick with a tin one.?
    harmonic damper is stumping me as I think there are large and small diameters? is this something to do withearly and late engines?
    this battery tray too low?
    if I have a 68 153t bell house and Muncie t5 with s10 tail, do I aim to get the trans mount on the stock 35-40 crossmember thing.
  23. Slopok
    Slopok
    Not that it matters to your question, but I think you have a Standard not a Deluxe.
    @olscrounger would know for sure.
    X38 likes this.
  24. nunattax
    nunattax
    the light in the footwell where are these available[​IMG]
  25. Graybeard4545
    Graybeard4545
    from Maryland
  26. Graybeard4545
    Graybeard4545
    from Maryland
    Correct, It is a standard. Thanks.
  27. Graybeard4545
    Graybeard4545
    from Maryland
    I am using a Hurst style front mount and it is in the way of the fuel pump. I am using an electric one mounted out side the tank.
    A lot of guys have advised against using an aluminum bell because it stressed it a bit being spread so far out.
    I have built a mid stabilizer mount to help with that.
    I am using a stock tin pan, no clearance issues with speedway rubber mount kit that fits in stock ford mount holes.
    Add a 3/4 in spacer to raise Hurst mount and all fits well including the large harmonic balancer.
    The original trans mount I cut out, and built a new one that centers the M20 trans perfect in the hole. I trimmed some of the tunnel lip to help with clearance. The shifter relocation did the job so no cutting into the cross frame or boxing needed.
    The stock 40 clutch peddle was used and I made the link to it 1in taller to help with geometry. Offset heim and it is a straight shot to the Z-bar that came from a Chevelle and I took 2 1/4in out of. Clutch works well.
    Your Battery box looks good to me. Mine is a bit higher but I don't see that it matters.
  28. Graybeard4545
    Graybeard4545
    from Maryland
    I guess my battery box is a bit higher.
  29. Smart62
    Smart62
    from UK Sussex
    Hi Just saw your hurst mounted SBC in a 40 Ford. I am building a 39 coupe with one. Would like to ask did you put in mid mounts at the back to support the trans bell housing? If so do you have any pics? Cheers
  30. Graybeard4545
    Graybeard4545
    from Maryland
