Hot Rods Need help, 12v to 6v reducer not reducing
Discussion in 'The Hokey Ass Message Board' started by BillyBobsSpeedShop, Apr 11, 2020.
  1. BillyBobsSpeedShop
    BillyBobsSpeedShop
    Hope someone can help with some guidance, I purchased a 12v to 6v voltage reducer (the gold one with fin's) to reduce the voltage to my autopulse 6v fuel pump as I converted my T to 12v. Took the reducer out the box and wired it like it stated and I'm reading 12v thru the reducer at the pump wire? I swapped the wires and still 12v.
    When a reducer goes bad will it allow 12v thru and not reduce or would it just stop working? Also is there a ground needed, directions does state? Also will the voltage not drop till the fuel pump pulls amps? Below is the reducer I have.
    https://www.speedwaymotors.com/Elec...MIzOat8ebh6AIVRpyzCh2GnQIzEAUYASABEgIiffD_BwE
    Thank you
  2. razoo lew
    razoo lew
    from Calgary
    That looks a lot like a power resistor to me. If so, you will need to connect a load to it to see the voltage reduction.
    tb33anda3rd likes this.
  3. BillyBobsSpeedShop
    BillyBobsSpeedShop
    Ok, so what's the best way to test it? Should I see the voltage drop while tht car is running?
  4. squirrel
    yes, when the pump is running is the only time you'll see the voltage drop.
  5. BillyBobsSpeedShop
    BillyBobsSpeedShop
    So I tested system today while the pump was running. I cut the fuel supply off and then slowly opened it while pump was running. When the **** off valve was opened up about a 1/4 way the volts where reading around 6.5 to 7.8, the more I opened it up the more volts the pump was using. With the shut-off valve all the way open the pump was pulling 10v but didn't go over 10v.
    I'm wondering if I need a different resistor or reducer?
  6. Budget36
    Budget36
    Not sure the issue, but I think I'd just eliminate the reducer and run a 12volt pump.
    ffr1222k likes this.
  7. badshifter
    badshifter
    That reducer specifically states it’s for a HEATER BLOWER motor. Your fuel pump isn’t pulling enough load on the reducer (not enough amp draw) to see the voltage drop you’d see with a higher amp draw of a heater blower motor. You’re time, money, and aggravation ahead to simply buy a 12 volt fuel pump.
  8. squirrel
    As the fuel flow increases, the load on the pump motor decreases. This changes the current draw of the pump. Since you are using a voltage divider circuit to drop the voltage, this also changes the voltage balance, and the pump gets more voltage. That's just how the type of voltage reducer you have, works. It's resistance has to match the load exactly, if you want the voltage to drop exactly in half.
    If you want to keep it at 6 volts you'll need to use a solid state voltage regulator. Something like this might work.
    https://www.amazon.com/Aweking-Waterproof-Converter-Regulator-Transformer/dp/B06W9MZJ8X/
    Or get a 12v pump. Or just run it with that reducer, and see how long it lasts. Might last for a long time.
  9. BillyBobsSpeedShop
    BillyBobsSpeedShop
    Squirrel thank for the information, makes sense why I'm seeing the voltage fluctuate. Ill look into the regulator
