Hot Rods THE INDUCTION THREAD
Discussion in 'The Hokey Ass Message Board' started by mad mikey, Dec 9, 2016.
  1. drumyn29
    drumyn29
    I'm looking for this fuel pump drive gear for my Potvin. Does anyone know of one for sale? Someone said that a Flathead speedo gear is the same. 91032410_3109604902383108_2846046760000815104_o.jpg image004.jpg image005.png
    Deuces, mad mikey and loudbang like this.
  2. loudbang
    Gas Ronda
    1957 Vette
    Stogy, 1947knuck, loner2 and 16 others like this.
  3. loudbang
    Sure looks like the tunnel Port manifold.
  4. Dean Lowe
    Dean Lowe
    I did not know Speedwell made a blower for a VW. What a rare piece that is.
    enloe, Jet96, Deuces and 4 others like this.
  5. XXL__
    XXL__
    It's a modernized repro of the old Pepco unit from the 1950's. They are available brand new from Speedwell for a couple grand.
    enloe, mad mikey, Deuces and 3 others like this.
  6. saltflats
    saltflats
    from Missouri
    Another pair to rebuild.
    1947knuck, enloe, mad mikey and 5 others like this.
  7. Jalopy Joker
    Jalopy Joker
  8. loudbang
    1955 Studebaker
    Stogy, 1947knuck, loner2 and 19 others like this.
  9. loudbang
  10. loudbang
  11. loudbang
    427 Mystery engine
  12. loudbang
    1957 Belair Fuelie
    Stogy, 1947knuck, loner2 and 15 others like this.
  13. loudbang
    1956 Pontiac Dual Quad Setup
    The intake manifold carries the casting number D-32960. This shows as being the early/prototype intake for the 1956 Pontiac 316/317 V8 engine. This was the intake that was developed for NASCAR and brought so much success to Pontiac/GM. Some sources say there were as few as 20 of these intake made.
    Disclaimer: NOT my sale don't know the seller. :)
    https://www.ebay.com/itm/1956-Ponti...6d995304d:g:EPYAAOSw5YlcCyaH&vxp=mtr#viTabs_0
    Stogy, 1947knuck, loner2 and 17 others like this.
  14. loudbang
  15. loudbang
  16. oldiron 440
    oldiron 440
    This would be perfect for the Fairlane, but I would have to wonder how much power could be gained or lost going from a Holley.
    enloe, mad mikey and Deuces like this.
  17. loudbang
    1947knuck, loner2, enloe and 5 others like this.
  18. Jet96
    Jet96
    from WY
    "LeMonstre"-331 Cadillac raced in 1950 2BE862B5-CD38-4E8B-9947-1176861D2B6D.jpeg
    Stogy, 1947knuck, loudbang and 10 others like this.
  19. seb fontana
    seb fontana
    from ct
    Stogy, loudbang, mad mikey and 2 others like this.
  20. Jet96
    Jet96
    from WY
    I'd like to see that linkage....
    Stogy, loudbang and mad mikey like this.
  21. 64 DODGE 440
    64 DODGE 440
    from so cal
    Some of the linkage is visible. It looks like the two sides are hooked together and the middle carb would be used as the primary, probably used for the idle setting with the idle circuits blocked off on the four outer carbs. Seems like that would make tuning much easier. The intake manifold is probably a factory single carb unit with the mounts for the outer carbs spliced into the runners at the intake ports.
    Stogy, Jet96, loudbang and 1 other person like this.
  22. jnaki
    jnaki
    Hello,
    Tommy Ivo has always been a step ahead of others in his builds. With the compe***ion ramping up in the 1959 time period, he decided to go with a 671 supercharger in his single engine FED for better results. The single Hilborn Injected Buick FED was well known and won plenty of awards and cl*** records. But the need for speed…
    The 1959 year at Lions Dragstrip was one of the most exciting years for drag racing.
    Tommy Ivo single engine Buick progression
    But, somehow, the 671 add on and tune did not produce the results necessary for a successful campaign. So, a new build of a twin injected Buick FED was created and started winning instantly.
    Jnaki
    The results speak for themselves. Power and more power to crack the record books.
    Then, at the 1960 Bakersfield Smokers March Meet.
    Jnaki
    Stogy, 1947knuck, enloe and 8 others like this.
  23. mad mikey
    mad mikey
    ^^Damn that's nice!^^
    enloe, loudbang, Bowtie Coupe and 2 others like this.
  24. quick85
    quick85
    1947knuck, loner2, enloe and 7 others like this.
  25. quick85
    quick85
    Joliet, Illinois
    Stogy, 1947knuck, loner2 and 10 others like this.
  26. loveoftiki
    loveoftiki
    from Livonia,Mi
  27. Duck's Goat
    Duck's Goat
    I've got one of these in my parts stash as well, except for the air cleaner. Oddly the most rare part of this setup seems to be the correct thermostat housing, its a different shape than any others used by Pontiac. Production numbers are around 100 units from the research I've seen and I've personally laid eyes on about a dozen intakes myself.
    Jet96, egads, loudbang and 1 other person like this.
  28. Bowtie Coupe
    Bowtie Coupe
    That's from Jalopyrama 2019
    Stogy, mad mikey and loudbang like this.
  29. Jalopy Joker
    Jalopy Joker
