Projects 1934 ford three window project
Discussion in 'Traditional Hot Rods' started by Elvis100, Aug 13, 2017.
  1. Weedburner 40
    Weedburner 40
    I am not familiar with that bracket either between the door post and package tray. The bracket is for the drain hose from the window pan.
    kidcampbell71 likes this.
  2. 421-6Speed
    421-6Speed
    Bracket is factory and, yes the clamp is for drain hose.
    kidcampbell71 and rusty valley like this.
  3. Elvis100
    Elvis100
    Did some fitting of the drivers side patch panels. A little more to do
    brEad, kidcampbell71, Stogy and 2 others like this.
  4. Matlack
    Matlack
    Looking great! Nice work on the floor.
    Mike
    Elvis100 likes this.
  5. sliceddeuce
    sliceddeuce
  6. Elvis100
    Elvis100
    Got the cowl I’m going to use back from the sand blaster and the skin around the cowl vent is much worse than I thought it was. I spent the day making a new panel to repair it.
    brEad, 40LUV, uncle buck and 5 others like this.
  7. rusty valley
    rusty valley
  8. Way better than my attempt on my ‘36 [emoji38] May I inquire how you made it? Really enjoying this thread, nice job!!!
    Stogy, brEad and kidcampbell71 like this.
  9. Rocky
    Rocky
    Classified Editor
    I love watching these model 40 build threads. Nice work!
  10. Elvis100
    Elvis100
    I made a positive and negative die using metal and oak. Can only press a little of it at a time...I basically sat at the press for an hour taking small bites at it. I have a little more depth to get today and then do it all again for the interior drip channel. I’ll post some pictures of the die today.
  11. Elvis100
    Elvis100
    Eldonius, Stogy, rpm56 and 6 others like this.
  12. flamedabone
    flamedabone
    Nice die, you could definitely sell a few of those panels.....
    Nice work, -Abone.
    Stogy, 29EHV8 and Elvis100 like this.
  13. Elvis100
    Elvis100
    Started some of the repairs on the cowl. Work stoppage on the vent, waiting for some metal to be delivered for the other die I’m going to make. Moved on to the cowl feet, got the first one spliced in.
    [​IMG][​IMG][​IMG]
    Stogy, brEad, kidcampbell71 and 3 others like this.
  14. Never2old
    Never2old
    from so cal
    I can recommend putting a large radius on the corners of that cowl panel. It will cut down on the warpage.
  15. Elvis100
    Elvis100
    Stogy and kidcampbell71 like this.
  16. Elvis100
    Elvis100
    Finished the second cowl foot and worked on repairing a few holes and some rust.
    Stogy, brEad, kidcampbell71 and 2 others like this.
  17. rusty valley
    rusty valley
    come on, fess up, your dad made the oak part
    Black Fifty likes this.
  18. Elvis100
    Elvis100
    Used up the last of my argon this morning so we did a floorboard for the coupe
    lurker mick, Stogy, brEad and 4 others like this.
  19. sliceddeuce
    sliceddeuce
    Progressing nicely.
  20. Elvis100
    Elvis100
    Thanks...it’s moving forward
  21. Elvis100
    Elvis100
    Got the metal I needed to make the cowl vent drip edge die and spent the last couple days refining it. Now I have nice clean metal to work with
    Just have to transfer a few bits and pieces from the old vent
  22. rusty valley
    rusty valley
  23. Elvis100
    Elvis100
    rusty valley likes this.
  24. brady1929
    brady1929
  25. Elvis100
    Elvis100
    dlw1932 likes this.
  26. Elvis100
    Elvis100
    More work on the cowl vent. I decided to remake the body half of the hinge. I flattened the original hinge to use as a pattern.
    kidcampbell71, Stogy and brEad like this.
  27. Elvis100
    Elvis100
    Took the shell off the floor temporarily, then flipped the floor upside down and applied two coats of red oxide and seam sealer. Should get the body back on it permanently today.
  28. Elvis100
    Elvis100
    Turned my attention to the rear corners. Made some pieces for the bottom of the corners and replaced the skin in the trunk jam.
  29. Elvis100
    Elvis100
    Finished up the cowl vent and installed it in the cowl. I ended up making a new scupper drain, the old one looked pretty thin.
