Technical Issue with Cad 331 using 39 Lasalle trans.
Discussion in 'Traditional Hot Rods' started by dugydog, Apr 12, 2020.
  1. dugydog
    dugydog
  2. dugydog
    dugydog
    Well I just got my 331 Cad motor back from the engine shop and I was gonna bolt on the 39 Lasalle trans so I could take some measurements for fitting it into my ‘35 Ford. After looking at both the extended bell on the motor and the transmission bell housing it appears that there are only 2 bolts (not counting the dowel pins) that are gonna hold this together. After looking at other images of similar vintage Cad motors it looks like my block is missing 2 additional threaded holes more or less just above the dowel pins. Of course I know that the Lasalle trans will be further strengthened when I install the lower portion of the extended bell that houses the starter but still doesn’t seem right. Has anyone else experienced this? I’m attempting to include photos. Thanks!
  3. Ebbsspeed
    Ebbsspeed
    Looks like there are two more bolt holes directly below the dowel pins, but appear to be smaller than the two at the top of the extended bell on the block.
    Straying a bit, but what is that grey stuff surrounding the bearing retainer on the transmission?
  4. Too bad there's not enough meat on the block to just drill and tap 2 more holes.
  5. dugydog
    dugydog
    Yeah those 2 smaller bolt holes below the pins don’t line up with any holes on the bell housing. They gray stuff appears to be sealant not sure why I needed that.
  6. I'm thinking that if the lower half of the extended bell supported the hydro it should support the LaSalle.
  7. TCTND
    TCTND
    I'd be inclined to do what it takes to make the lower pair match up rather than just relying on the extension. It can't be too strong. This may just be my engineer's redundancy kicking in but I like peace of mind.
    regards,
    Phil
  8. dugydog
    dugydog
    Yeah thanks I’m gonna visit the machine shop today and see if he thinks there’s enough material there to drill and tap a couple of holes.
  9. mgtstumpy
    mgtstumpy
    What about fabricating an adapter with crankshaft spacer, a bit of work but doable? A lot more inherent strength then.
    adam401 and kidcampbell71 like this.
  10. sdroadster
    sdroadster
    I understand your desire to insert bolts in all the holes. However the top, and more importantly the series of holes at the bottom are more important. The twisting effort (shear) caused by torque will be restricted by all the bolts. The weight of the motor, and the placement of motor mounts will tend to create a separation or splitting effort between the bellhousing and the transmission.. That will mostly be controlled by the bottom bolts. If you can drill and tap the motor, go ahead, otherwise use grade 8 bolts, and tighten them up. You'll be fine.
  11. patsurf
    patsurf
    being cast,prob wont warp too much if you build the 2 bolt areas up (outward,in this case)w/ weld ,then face it off and drill the 2 holes and tap them-just build up enough to match the 2 above
  12. dugydog
    dugydog
    Thanks sdroadster, I was digging deeper in the internet and found an image of a 1951 331 Cad with the same bolt pattern that I have, meaning there are only the 2 bolts at the top of the block above the dowel pins. This would match an original Cadillac manual trans bell housing which I don’t have and understand are pretty difficult to find. Based on that I’m just gonna bolt it up with some good hardware. Thanks all!
    Hnstray and firstinsteele like this.
  13. timothale
    timothale
    Are you using the Lasalle bell housing ? You probably need the next to impossible to find Olds stick bell housing. My 37 floor shift Lasalle did not come with a bellhousing. I ran it behind a 58 Ford thunderbird police interceptor Special ford FE. (factory 060 over pistons.I used the FE bell and about an inch thick adaptor plate. another option would be to tun the caddy adaptor bell to Ford Fe then the FE to lasalle trans. My older brother (RIP) did a lot of Engine swaps and quit a few using 2 adaptors and allen bolts to get what he needed and turn down a pilot adaptor ring and a double seal ball bearing.
    kidcampbell71 likes this.
  14. timothale
    timothale
    I think the adaptor to move the starter to the opposite side of the engine might provide some support. I sold My olds stuff about a dozen years ago. I don't rember all the bolt locations.
  15. vtwhead
    vtwhead
    From what I recall you end up with 4 bolts (7/16) when doing that swap. Seems @F&J went thru this with me back in 2010 when I had a 50 Olds bell I picked up and had questions regarding the fitment. I don't know if @Paul has done this swap but he may add some thing here.
    Are you planning on using side mounts attached to that bell housing like the factory did?
  16. dugydog
    dugydog
    Yes I’m using the original Lasalle bell housing because that’s what my understanding was, that it was a direct bolt on to the early Caddy block, and I still think it is just not the block I have. I’m not sure what you mean by side mounts on the bellhousing, was that on the Lasalle’s?
  17. vtwhead
    vtwhead
    here is a pic from one of F&J's posts.
    the left bell is a 51+ olds unit. It has the two side mounts attached that go to the crossmember in the Olds configurations. The unit on the right is the hard to find 50 Olds std bell #558701 with only one mount attached. Now, Cads apparently did not use the side mounts on their bells I am told and they are not configured to accept any mounts.. What is the number on your bell casting? From the front of your pic it looks to have the tap holes for the side mounts and it appears that it may in fact be a 50 Olds unit..558701
    So, where are you planning on placing the rear mt(s) for the ****** in your installation? Wonder if you would gain any advantage of using the side supports versus a single mount near the rear of the ****** if that is where it may be planned for. That is with the four bolts attaching the bell would you be better off supporting near the bell rather than at the rear of the ******?
    kidcampbell71 and Hnstray like this.
  18. vtwhead
    vtwhead
    Just for grins here is a pic of a cad engine with the factory bell
    and a close up of that same bell. Looks darn similar to your bolt config on your bell. FWIW.
    mgtstumpy, kidcampbell71 and warbird1 like this.
  19. vtwhead
    vtwhead
  20. dugydog
    dugydog
    Ok so based on your photos it looks like I have an Olds bell. I didn’t give it much thought into how I was gonna mount the trans but now it would seem like a side mount would be best. I have a lot to do still before I get to that point. Thanks for all the info! IMG_4245.JPG
    Toms Dogs and kidcampbell71 like this.
  21. vtwhead
    vtwhead
    I am still a bit confused about the rear of the Cad bell. All the 49-54 331's I have found on the net seem to have two more bolt holes which are missing on yours. what year is the 331?
  22. Paul
    Paul
    Editor
    yup, the transmission is bolted to a '50 Olds bell, if it were me I'd be looking for the Cadillac bell.
  23. dugydog
    dugydog
    Yes vtwhead but look closely at the Cadillac bell you sent me a picture of, that bolt pattern matches my 331 motor which is a 1951 by the way. You don’t suppose they had 2 different style blocks one for the hydro and one manual?
  24. vtwhead
    vtwhead
    I doubt that. As Paul stated above it would be great if you could find a cad bell. I made an inquiry with another member that had one a while back. Waiting to hear.
  25. dugydog
    dugydog
    Well I just confirmed that my block originally came bolted to a synchro-mesh transmission because the stamping on the top of the extended bell begins 2N1, so yeah I think you are correct Paul I should try to find a Cadillac bellhousing. That’s gonna be a tough one![​IMG]
    warbird1 likes this.
  26. 37 caddy
    37 caddy
    from PEI Canada
    The 37 ****** has a shaft that sticks out the front,its for reverse?,not sure if your housing has the hole for it,37 is a one year only setup,38 and up does not have the shaft,move the gearshift on your ******,it will pop out of the front.Also there is a oil p***age for the top bearing,oil flows through it and goes back into the case,that is why there is a gasket between the ****** and the bellhousing.I dont have any pictures of mine,but if you go to the Cadillac-Lasalle club forum,there is some technical advice there as well. OOPS, i didnt read the whole ***le,this is for a 39,just disregard the above,I cant help any with that. :rolleyes: Harvey
    ted kovacs likes this.
  27. vtwhead
    vtwhead
    @dugydog did you ever find a cad bell?
  28. dugydog
    dugydog
    No I didn’t!
  29. dugydog
    dugydog
    @vtwhead So I just found a nice Cadillac bellhousing however I think Im gonna stick with the olds one because the Cad one is thicker and because of that the input shaft will not fit completely into the pilot bushing.
  30. ss34coupe
    ss34coupe
    My 331 Cadillac motor has the same hole pattern as yours - no need to drill and tap anything.
    Used a 39 Ford trans with an adapter behind this motor. Have an original Cad bell housing as well sitting in the parts pile. IMG_0728.jpg
