Technical hidden bolts in concrete floor; how to do it???
Discussion in 'The Hokey Ass Message Board' started by atch, Apr 13, 2020.
  1. atch
    atch
    I've got one of those cheapie tire machines. Don't know what brand it is 'cause I bought it at a swap meet about 20 years ago. It looks just like the HF model shown below though.
    I want to put 4 anchors in the middle of my concrete shop floor that I can use to bolt this to when I need to use it. BUT, 99.99% of the time I won't want it there. So I need a way to put bolts into the anchors but not have the bolt heads stick up where I would trip on them. If there're no bolts in the empty anchors in about 3 days the holes will be full of dirt/grit and no bolt would ever go into the anchor again.
    I've had this thing bolted to a pallet ever since I bought it, but I need the floor space and want to get it off of the pallet.
    I'm thinking if I had a masonry drill bit larger than the bolt head (and appropriate sized socket) I could just countersink the bolts down into the concrete to where the bolt head is flush with the surrounding concrete. Unfortunately I don't have any such animal and don't really want to put out the ca$h to buy one to countersink 4 holes.
    Anyone got any better suggestions than buying a drill bit?
  2. uncleandy 65
    uncleandy 65
    Check with Lowes or Menards and look in their cement section and see what they use to anchor things in cement.
  3. squirrel
    put four set screws into the anchors when you're not using the thing. You can make them by cutting the heads off bolts, and cutting a slot in the end with a hacksaw.
    I put my tire machine like that outside on the concrete pad in front of my shop, off to one side. Doesn't get in the way there.
    41 GMC K-18, Mr48chev, acme30 and 5 others like this.
  4. kidcampbell71
    kidcampbell71
    What Squirrel just said. ^^^
    Look for a female threaded drop in anchor. Hilti makes different sizes. Plenty strong once set.
    It makes sense to machine a screwdriver tanged top .. to replace the bolt. Thanks for the idea, Squirrel.
    Don't know my practical use for it .. but definitely filed away for future use. Keeping it simple, right ?
    Texas Webb likes this.
  5. 41rodderz
    41rodderz
    from Oregon
    When I worked for the state we had anchors recessed in the cement with a flip top and some had square cover that fit recessed flush with the floor . Flip tops kept dirt, foreign objects etc out . Flat recessed covers just had a hole in the middle to stick your finger in .
    kidcampbell71 likes this.
  6. drtrcrV-8
    drtrcrV-8
    Suggest looking at a HILTI catalog for flush concrete inserts. They work just like any insert, except they are "innies" as opposed to "outies", & you use bolts to retain your tire machine, & have a flush surface when you remove them. I would also suggest using allen set screws in the holes when the machine is in storage, to keep dirt out of the holes. It's really a lot simpler/easier than it sounds!! LOL!
  7. 41rodderz
    41rodderz
    from Oregon
    Nobody say anything about sticking “your finger in the hole”:oops::p
  8. nochop
    nochop
    from norcal
  9. FD7A58AF-4A83-4DFB-AA26-E226CF5898F4.jpeg CEC028E5-06F5-4412-B2DD-E8EB1CB566E4.jpeg
    these guys
    you can rent a larger concrete drill bit to counter sink the hole so the bolt head sits flush to the floor once you thread it back into the insert
    Or carefully chisel a recess in
    Only gotta go down the thickness of the bolt head.
    And like squirrel said, use a hack saw and cut a line in the top of the bolt so you can unscrew it with a screw driver once it’s in flush.
    or be fancy and use Allen head bolts !!
    jimmy six, Cosmo49, Firedup and 2 others like this.
  10. Atwater Mike
    Atwater Mike
    Go Dutch...
    belair likes this.
  11. Jalopy Joker
    Jalopy Joker
    also, check Grainger and other hardware supply locations for Red Head concrete anchor fasteners
    seb fontana, swade41 and uncleandy 65 like this.
  12. wraymen
    wraymen
    Recess the anchors slightly and use rounded head Allen bolts.
    VANDENPLAS, I missed your last line.:)
    nochop and VANDENPLAS like this.
  13. Bearing Burner
    Bearing Burner
    from W. MA
    Years ago at work we put lead sleeves in the hole and then thread a Lag bolt into that which can then be unscrewed leaving the sleeve in place.
  14. ROADSTER1927
    ROADSTER1927
    Put a plastic plug in that pulls out easy.
  15. fastcar1953
    fastcar1953
    Atch pm me. I have the drill and bits. Would be glad to help do it. I'm just a few miles away.
  16. BamaMav
    BamaMav
    from Berry, AL
    I would use anti seize on the bolt threads when you screw them in. It will help keep them from binding up with the grit from the floor that will find its way into the socket threads.
    Texas Webb and clem like this.
  17. flatford39
    flatford39
    I used those inserts on my floor. When I need to use them I just blow it our with my air compressor.
  18. '34 Terraplane
    '34 Terraplane
    from Western PA
    "Set-screw" type allen will thread down into floor-anchored nut of about any size you want. (You'll probably have to clean the dirt out of the end of it when you want to get the allen wrench in it for removal.) allen.jpg
  19. RmK57
    RmK57
    Thats what I used. Small ones from hydraulic fittings work perfect.
    VANDENPLAS and Cosmo49 like this.
  20. Cosmo49 likes this.
  21. Firedup
    Firedup
    from Oregon
    Like a few have said. Flush shell anchors are the cat’s ***.
    VANDENPLAS likes this.
  22. Tickety Boo
    Tickety Boo
    from Wisconsin
    I bolted mine to a 4 x 4 foot sheet of 3/4" plywood with stove bolts, got it standing in the shop corner with the more H.D. H.F. bead breaker. Put it where you want when using it, just make sure your standing on the plywood base.
    Works for me ;)
    I have even borrowed it out. :cool:
    Paulz likes this.
  23. Blue One
    Blue One
    from Alberta
    This is the answer and really the best solution from all the suggestions.
    I installed them in my garage and then I put the same bases on many other shop tools so that I can use the same anchors for multiple uses.
    1) my JD2 tubing bender
    2) my power bead roller
    You get the idea. :cool:
    Cosmo49 likes this.
  24. atch
    atch
    Thanx everyone for your replies. I hadn't thought of hacksawing a slot in a bolt or using allen head set screws.
    I like those ideas.
    I had thought of putting it on the concrete apron outside but I've seen several of them that rusted up pretty badly when put outside. Besides, about the only place out there on concrete is where I store firewood.
  25. atch
    atch
    That's pretty much what I have now except it's a pallet instead of plywood. And yes, you HAVE to be standing on the pallet when using it.
    Tickety Boo likes this.
  26. Cosmo49
    Cosmo49
    hacksawing a slot in a bolt That is what I thought everybody used for transmission install guide pins, works like a good helper that half knows what he's doing!
  27. Ebbsspeed
    Ebbsspeed
    Not sure if everyone does, but I certainly do. They work slicker than owl **** on a green hickory limb.
    Cosmo49 likes this.
  28. Fortunateson
    Fortunateson
    X2 I did the same thing...
  29. I’m just wondering why when I start a thread like this somebody reports it and then it says oh this would be better for garage journal and shut it down.
    Is that just me
    swade41 and kidcampbell71 like this.
  30. MAD MIKE
    MAD MIKE
    from 94577
    Maybe you have a fan.
