Projects 1960 Studebaker Lark Gasser
Discussion in 'The Hokey Ass Message Board' started by Hightone111, Jul 8, 2010.
  1. Six Ball
    Six Ball
    from Nevada
    Very cool. Jake and I talked about it today. We'll be learning from you from here on! :cool:
    Hightone111 and loudbang like this.
  2. Hightone111
    Hightone111
    Dusted off the ol’ Bieber Changer and stuck it back in place today. Getting ready to paint the cage. A couple steps closer to plumbing/wiring.
  3. Hightone111
    Hightone111
    Being quarantined and shutting down my business is going to help me make some progress. The last several days I have finish welded/painted my rear axle, interior cage, trans crossmember, headers and steering. I worked on some figment issues with the tunnel and started wrapping in dynamat, got my tach in place and mounted a gauge pod in place of the radio.
  4. Six Ball
    Six Ball
    from Nevada
    Making the best of a bad situation, great progress. I thought you'd be an essential business or at least be selling sanitizer and wipes from stand on Carson Street. :rolleyes:
  5. Hightone111
    Hightone111
    I’ll hang onto them until this blows over and there’s none left!
    Six Ball likes this.
  6. Hightone111
    Hightone111
    Update:
    The guy that built my axle drilled and tapped a 5x4.75 pattern for the magnesium wheels I have. It was off enough that I decided they won’t work without destroying lug nuts/studs. So I utilized the 5x5 pattern and was loaned these mags which I sandblasted and am considering painting cast iron grey.
    I also got all of the brakes plumbed, but I’m still lacking full pressure. It’s difficult to bleed brakes solo. Especially with a tiny Wilwood reservoir buried up under the dash. But I’m confident I’ll figure it out. I’m running a line lock/park brake and proportioning valve to the fronts as the brakes are designed for a lighter car and it’s on 4” wide tires.
    It’s been very difficult trying to order everything overnight and stay ahead of progress to avoid running around town for parts during all of this covid ****....
    loudbang and Six Ball like this.
  7. Hightone111
    Hightone111
    I’ve been spending 6-8 hrs a day on the stude and today I completed the wiring! This would have taken me another 10 years if it weren’t for this pandemic. Just need to have some fuel lines made, get the distributor on a dyno to phase the rotor, and a few odds and ends before I can hopefully take it for a test drive!
  8. southcross2631
    southcross2631
    Very nice. This virus has turned out to be good for some car builders. It means I won't miss as many races before the season starts up.
    I really like your Stude.
    loudbang and Hightone111 like this.
  9. Hightone111
    Hightone111
    Thanks! Hopefully the momentum continues.
  10. Six Ball
    Six Ball
    from Nevada
    So close! The wiring looks nice. Love the dash shot.
    Does your TBI require a return line to the tank?
  11. Hightone111
    Hightone111
    It does. Hoping to have them made today/tomorrow at hydraulic industrial
  12. Hightone111
    Hightone111
    It’s looking like I’ll take a maiden voyage today! Efi still need some tuning, trans is shifting funny and sticking between 1st/reverse which I attribute to the crazy shifter but it moves on its own[emoji1362] IMG_3904.JPG Adjustments.JPG Adjustments.JPG
  13. Six Ball
    Six Ball
    from Nevada
    That is great! Take some Video! Be careful! Wash your hands and don't touch your face.
    I had a '48 Chevy fastback with a ****py floor shift kit that would shift into second and stay in first. ******s don't like that. Yours looks pretty complicated but cool.
    I hope you can find a way to pick up some cool air from outside the engine bay.
  14. Hightone111
    Hightone111
    Went up and down the street a bit and ended up exploding the trans mount doing a little burnout. But it did ok[emoji1360]
  15. Six Ball
    Six Ball
    from Nevada
    Congratulations! I thought it was another earthquake. It's been a long road. Now the road has a little rubber on it. Trans mounts are cheaper than trans gears.
  16. Hightone111
    Hightone111
    Also, I’ve got a plan for cool air but I have to get the front end on it before I know if it’ll work.
  17. Hightone111
    Hightone111
    I started working on the front end. It will be a flipper eventually. I think I have the basic idea started but it’ll need some more engineering before it’s functional. IMG_3931.JPG
    I replaced the trans mount and fixed the throttle linkage after some burnouts went south on the maiden voyage. I was going to try test drive #2 today but the alternator isn’t charging and I’m over it now. So, maybe tomorrow! BCD9B31F-6DE0-4470-93AA-20FD33DC6427.jpg
    cactus1, loudbang and Six Ball like this.
  18. Six Ball
    Six Ball
    from Nevada
    Bad *** Tony Running good enough to break stuff on the Maiden Voyage, you can't ask for much more from a South Bend Maiden. o_O
  19. Hightone111
    Hightone111
    Got it back on the road today with no issues! Only my 3rd time ever riding in a Studebaker[emoji1360]
  20. Six Ball
    Six Ball
    from Nevada
    It looks good! Studebakers are way cool. How is it running? How do you do the logging for the EFI? Set your parameters and drive?
  21. Hightone111
    Hightone111
    Running pretty good so far. I have a buddy that’s pretty experienced with the FiTech and he’s going to do some tuning for me. There’s definitely some bugs to work out. Yeah you basically just set them and go, then make adjustments as needed anytime after that.
    Greg Rogers and Six Ball like this.
  22. loudbang
    Looks like it's ready to launch. :)
    Six Ball and Hightone111 like this.
  23. Greg Rogers
    Greg Rogers
    WOW- sooo cool!!
    Six Ball, loudbang and Hightone111 like this.
  24. Hightone111
    Hightone111
    Got some exhaust handled so no I can hear all my hard work fall apart
    The rear springs are definitely too soft to be on their own so traction/ladder bars are a must have soon.
    Also, as cool as the Bieber shifter is, I’m not sure it’s for me. It may just need some kind of adjusting but I’m having a hard time with it so far.
    loudbang, Six Ball and wvenfield like this.
  25. That thing is cool!
  26. TRENDZ
    TRENDZ
    So, Im curious about the front wheel/tire combo. Really want to run those wheels on mine, but tires seem to be extremely limited. How did the car drive/ steer? Do you have a spool in the car.
  27. Hightone111
    Hightone111
    So far it seems to drive pretty well but I have been keeping things pretty mild since I just got it on the road. No hard stops or swerves yet. It’s been awhile since I’ve looked for tires, but they are for a motorcycle.
    I have a Yukon “ratcheting” locker in it.
    P.s. the spindle mount brakes SQUEAL loud and I have yet to find a solution, so if anyone has any ideas let me know.
    TRENDZ, loudbang and Six Ball like this.
  28. Six Ball
    Six Ball
    from Nevada
    Lookin better all the time. Some things from our brains don't work on our cars. If it was easy everyone would do it.
    Did you use the anti squeal grease on the back of you brake pads?
  29. Hightone111
    Hightone111
    I’ve tried 2 different types so far. I have one more in mind. Then I move on to figuring out some type of spring setup I think
  30. TRENDZ
    TRENDZ
    Really like the car. You have definitely captured the look in my opinion.
    Great job!
