Hot Rods 317 lincoln engine ready to dyno
Discussion in 'The Hokey Ass Message Board' started by Bob Kammer, Apr 14, 2020.
  1. Bob Kammer
    Bob Kammer
    two years to get all the parts---had diamond custom make the pistons
  2. AVater
    AVater
    Wow--looks like "you're gonna drive someone to drinkin' with that hot rod Linoln"
    Elcohaulic, loudbang, Deuces and 2 others like this.
  3. stillrunners
    stillrunners
    from dallas
    Nice effort - have plans to put it in something ?
    loudbang and Deuces like this.
  4. wheeltramp brian
    wheeltramp brian
    Any dyno numbers?
  5. RichFox
    RichFox
    Just in case you or someone near San Mateo wants a spare 317 short block free. You haul. I got a good one.
    kidcampbell71 and Deuces like this.
  6. tjm73
    tjm73
    Stock rebuild or hot rodded?
  7. Rickybop
    Rickybop
    One of them newfangled monkey motion motors.
    Nice.
    Had to do a little research after seeing your engine. I didn't realize that Lincoln came out with their overhead valve engine 2 years before Ford.
    Hope you do well in the Mexican road race. LOL
    Sent from my VS835 using The H.A.M.B. mobile app
  8. Why am I not still living behind Heidy's Pies. LOL
  9. Oldmics
    Oldmics
    Viewing the pictures show that the p***enger side exhaust manifold has some sort of "flange" on the front side.
    Thats not a stock item. Is that for a turbo ? Or for test purposes?
    Oldmics
  10. Deuces
    Deuces
    Paxton mount maybe????...... o_O:confused::cool:
  11. squirrel
    from the crossover tube. Probably couldn't or didn't find a manifold to fit the p*** side without the flange.
  12. RichFox
    RichFox
    Dead stock. Used as mock up to modify an FE blowshield to bolt to Y block Lincoln. Also planned to use 317 crank in 368 as a destroker to make cl***. 368 and blowshield long gone.
    Deuces likes this.
  13. jimmy six
    jimmy six
    Id be happy with 190-200 hp...any others?
    Boneyard51 likes this.
  14. Boneyard51
    Boneyard51
    The 312 T-bird Special was rated at 245 horse power. Not sure of the 317 specs, but I would hope it’s North of 200 Horsepower!?
    Bones
  15. 200 hp and 450 ft pounds of torque:D
    Deuces, kidcampbell71 and Boneyard51 like this.
  16. v8flat44
    v8flat44
    Low on H P, but Lot a torque and 1952 Lincoln won Pan American road races . They also did well in their cl*** for gas miliag.
  17. squirrel
  18. drtrcrV-8
    drtrcrV-8
    '56-'57 Lincoln exhaust manifolds/downpipes will fit(slight m***aging) the '52-'54 ch***is & give good results. To those who don't know they look like stock parts(which they are, just different years)
    kidcampbell71 likes this.
  19. Will truck rams horns fit those
    The ones from a MEL industrial engine?
  20. Boneyard51
    Boneyard51
    MEL won’t fit Y-block. Don’t know if Ford Y-block exhaust will fit Lincoln Y-block.
    Bones
  21. studebakerjoe
    studebakerjoe
    Ford used the Lincolns in their bigger trucks and they had the rams horns manifolds on them.
  22. drtrcrV-8
    drtrcrV-8
    NO the 292/312 Y-Block exhaust manifolds don't fit, but the '64 & earlier F-8 ECU engines are the same as Lincoln, & while the ram horns will bolt on to the Lincoln motors, the exhaust pipe routing might be "interesting"(I didn't try them on my '53 Cosmopolitan back in the day because I already had the '56/'57 Lincoln car manifolds/down pipes at hand & they fit nicely & looked good.) If you have a set, go ahead & try them & then YOU can report back about how well they fit!!!
  23. drtrcrV-8
    drtrcrV-8
    If you do find a post '57 through '64 F-8 motor, look at the INTAKE MANIFOLD! It is drilled for the 4bbl 4150/4160 Holley Carb(instead of the '53-'57 Lincoln manifold that's "sunken" for the "teapot" Holley smallbase carb)
  24. bchctybob
    bchctybob
    That hot pipe running across the front of the engine was not one of Ford's better ideas.....
    Nice engine. Post a video of the dyno runs.
    Beanscoot likes this.
  25. Bob Kammer
    Bob Kammer
  26. Bob Kammer
    Bob Kammer
    This is actual a stock engine for a 1954 Lincoln 8:11 compression, We final found one exhaust with out the front pipe and caped the other one. Were at 250 foot pounds of tq and 155 hp which seams under what everyone things it should be. It took us a day to figure out how to get the secondary's to open. Also changed to a 12v protronics we will finish up this saturday
  27. Boneyard51
    Boneyard51
    Does it have the Tea-pot carb? If it does and has the stock 54 cam. It will be considerably lower than the 57 T-bird special at 245. But I still think it should be more than 155, but maybe not!
    Bones
  28. Bob Kammer
    Bob Kammer
    I believe stock carb for that year with a stock camshaft will send final numbers next week
  29. jimmy six
    jimmy six
    I have a Lincoln small base Carter WCFB that was used with the later engine. I believe it’s still for a Load-matic ignition. The Carter’s just make everything easier. And stock this engine should be close to 200 hp as squirrel showed probably at less than 5000 rpm.
  30. drtrcrV-8
    drtrcrV-8
