Projects 1964 Comet ROAD-RACER build Thread
Discussion in 'The Hokey Ass Message Board' started by fiveoh108, Nov 28, 2019.
  1. fiveoh108
    fiveoh108
    I got new floor pans for it, I got them in separate pieces since the entire footwell on my pieces is not too bad. I think the floors are the same since the doors are interchangeable. I think the extra wheelbase is from the c-pillar back
  2. AHotRod
    AHotRod
    I'm going to enjoy seeing a Road Racer built, good to see you doing something outside-the-box.
    loudbang and fiveoh108 like this.
  3. bigmikes50chevy
    bigmikes50chevy
    the last pic is when I met you (In-N-Out / Hot Rods birthday bash at Pomona)
    BigMike
  4. fiveoh108
    fiveoh108
    Getting on some of that rust repair![​IMG][​IMG]
    saltflats, loudbang and AHotRod like this.
  5. fiveoh108
    fiveoh108
    Is it a big block or small block? I wanted to represent the mercury somehow. I also got an early 260 timing cover with the breather tube, so hopefully that will work since the valve covers are solid.[​IMG][​IMG]
    saltflats, loudbang and RMR&C like this.
  6. mgtstumpy
    mgtstumpy
    ^^ SBF, could be a 351W however it could be just my eyes. I see you're adapting FE valve covers to a SBF. Also you don't see too many of those 2x4 intakes, I've only seen them on SBF Shelbys. If a 351W the intake would be wider due to increased deck height. The quickest and easiest way of differentiating between the different family Ford V8 engines is to count the valve cover bolts.
    • 2 bolts: 239/256/272/292/312 (1954 to 1964);
    • 5 bolts: 332/352/360/361/390/391/406/410/427/428 (FE engine;
    • 6 bolts: 221/260/289/302/351;
    • 7 bolts: 429/46; and
    • 8 bolts: 351C/351M/400 and 302C (Australia only)
    saltflats, neilswheels and loudbang like this.
  7. fiveoh108
    fiveoh108
    It’s a 351w with a 427 looking dual quad intake, carbs mounted backwards, and FE valve covers with valve cover adapters small block to big block. Good eye! Hopefully will be in the comet soon
    loudbang and mgtstumpy like this.
  8. loveoftiki
    loveoftiki
    from Livonia,Mi
  9. fiveoh108
    fiveoh108
    I go back and forth over that look over the H/M 64 Fairlane, stripped of side trim, window trim ect. IMG_1577.JPG IMG_1576.JPG IMG_1578.JPG
    charleyw, loudbang, AHotRod and 2 others like this.
  10. loveoftiki
    loveoftiki
    from Livonia,Mi
  11. fiveoh108
    fiveoh108
    It’s been a while since I updated this thread, still going strong! I got a 302 with a spun main nearing for cheap, that will not be a dual quad 331 for the comet. Working on floor rust repair, the back floor under the seat is not re popped so I gotta make it or find it somewhere.
    As I have been reading, I have learned that the engine compartments where painted grey on team am style cars of the day so oil leaks and cracks could easily be seen. May go that direction. Still deciding on what kind of roll bar/ cage to put in it... I welcome any input
  12. loudbang
    Good to see your helper hard at work.
  13. Steve Ray
    Steve Ray
  14. rustynutz
    rustynutz
    fiveoh108 and loudbang like this.
  15. rustynutz
    rustynutz
    Where did you get your floor pans from and are the stamping accurate to the original floor?
  16. fiveoh108
    fiveoh108
    From Autokrafters, pay the money for the better stamping , not the machine done owns, I got those at first and the fit was terrible, the AK stampings are nice and fit
  17. fiveoh108
    fiveoh108
  18. loveoftiki
    loveoftiki
    from Livonia,Mi
    Killer Cousin from the Falcon’s done right thread....
    355F42AF-96FA-4A13-AD23-3F45DEB6B415.jpeg 1A8D9A8D-5D7C-4E81-942B-C3C1F9156098.jpeg
  19. fiveoh108
    fiveoh108
    More floor work![​IMG][​IMG][​IMG]
    Gammz and loudbang like this.
  20. fiveoh108
    fiveoh108
    loudbang and Muttley like this.
  21. fiveoh108
    fiveoh108
    Fitting the F-500 hood scoop![​IMG][​IMG][​IMG]
  22. RmK57
    RmK57
    I had a line on one those scoops a couple months back. Guy was wrecking a 1969 Ford tandem dump truck that had one. I told him I wanted it over the phone and mentioned there kind of hard to get, hot rodders want them. Never heard back from him. I guess he researched it and found out he had gold sitting on that old Ford hood.
  23. fiveoh108
    fiveoh108
    I think I have an extra one if you are interested. It’s not quite as expensive as gold, but it’s not a freebee
  24. saltflats
    saltflats
    from Missouri
  25. fiveoh108
    fiveoh108
    Floors in and all fitted, need final welding, grinding etc. so glad to be back on solid ground. For the new Shelby GT350-R race oil pan too! Really nice piece [​IMG][​IMG][​IMG]
  26. loveoftiki
    loveoftiki
    from Livonia,Mi
    No Comet...but still cool inspiration for ya C863ECD9-07BB-43F7-A03D-842F913BE82A.jpeg E8695A22-6FDC-4268-B441-15EAF6FBB052.jpeg E68D2C1E-B052-4482-A42C-9107B81871F4.jpeg
    fiveoh108, Muttley, loudbang and 3 others like this.
  27. fiveoh108
    fiveoh108
    New TCP motor mounts, mock up motor and dual quads. Also got the hood scoop mounted and radiator hole cut out for a 24” radiator. IMG_0842.JPG IMG_0845.JPG IMG_0853.JPG IMG_0855.JPG IMG_0861.JPG IMG_0862.JPG IMG_0863.JPG IMG_0865.JPG IMG_0866.JPG IMG_0867.JPG
  28. Hate to tell you, but you'll have to hack the shock towers to get that 351 in there... if you want any kind of decent exhaust. I've seen it done without hacking, but the owner used early 221 SBF exhaust manifolds and they choked the motor pretty badly. Headers are impossible...
  29. kabinenroller
    kabinenroller
    It is looking good! Are you planning to use ‘65 style manual steering? I had to convert to that style to clear the big tube JR headers with the Boss 302 in mine. I also convert d to a large radiator, I am using a big block Cougar/Mustang unit with a matching shroud and the stock Boss flex fan. Cooling should not be an issue. Keep the updates coming.
    Here is my setup: (the tower brace is not installed in this photo)
  30. fiveoh108
    fiveoh108
    I have 331 stroker, 302 based.
