Hot Rods Mounting the battery in your early hot rod
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Oct 21, 2018.
  1. da34guy
    da34guy
    Got a 925 mounted under my seat along with a small Battery tender. When not drivin every day I just plug the tender in. Problem solved.
    HOTRODPRIMER likes this.
  2. My '36 Sedan...Battery box , tied to a battery shut off under driver's seat. .....g-willys 20150226_155520.jpg 20140416_113649 (1).jpg
  3. ct1932ford
    ct1932ford
    Me Too! Roadster.
    charleyw, $um Fun and HOTRODPRIMER like this.
  4. joeyesmen
    joeyesmen
    In the vintage cooler . . .
    wandi harry and HOTRODPRIMER like this.
  5. 340HilbornDuster
    340HilbornDuster
    2x 6V behind the rear seat! (6 + 6 = 12)
  6. Bandit Billy
    Bandit Billy
    I hid mine in plain sight. Easy to service too. :cool:
  7. BamaMav
    BamaMav
    from Berry, AL
    I didn’t hide mine in the 47 Linc, it sits in the factory battery tray on the right side corner of the firewall and fender. I feel it balances the look of the engine compartment what with the power brake booster and master cylinder on the left side corner of the firewall. Easy to get to, too.
  8. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Odyssey PC925 AGM under the passenger floor of the '31 coupe.
  9. fleetside66
    fleetside66
    In my Craftsman tool box that I bought for myself for a X-mas present in 1972.
    dana barlow and scotty t like this.
  10. Blues4U
    Blues4U
    from So Cal
    Under the floor of the bed in my 30 pickup.
    dana barlow likes this.
  11. David Gersic
    David Gersic
    from DeKalb, IL
    Mine is in a plastic box in the trunk. Don’t like it there, takes up too much room. But haven’t yet figured out where to move it to.
  12. Deuce Daddy Don
    Deuce Daddy Don
    In the trunk area, use welding cables for great power transfer, & use a sealed battery.
    Hamtown Al likes this.
  13. RoddyB34
    RoddyB34
    EB19F4C1-D1CD-4EB6-B7C6-4CADDB8A7AB5.jpeg C8980175-E70E-4601-926F-64217FBE21B5.jpeg 996F7512-CA8A-4A75-B901-21D2E061596C.jpeg ,changed my battery to the opposite side in our A coupe ,,made a cradle out of sheet gal ,
    jazz1 and Ned Ludd like this.
  14. Ned Ludd
    Ned Ludd
    RoddyB34 likes this.
  15. Scumdog
    Scumdog
    Couldn't fit a big battery there on mine so it went under the deck (Optima)
  16. RoddyB34
    RoddyB34
    Haha Yeah Ned I think your right ,,never thought of that ,but subconsciously definitely!,,,,although I haven’t opened the bonnet (hood) on the Lolite in 2 years,,
    Ned Ludd likes this.
  17. 1934coupe
    1934coupe
    In my 36 Willy's w/4cyl. under the hood. I need ease of access more than looks.
    Pat
    porknbeaner likes this.
  18. cajunfirehawk
    cajunfirehawk
    from Gulf Coast
    Got this battery bracket fabricated out of aluminum for $35 on the web for my pc680, perfect fit!
    [[​IMG]
    jazz1 and kadillackid like this.
  19. jailhousebob
    jailhousebob
    from Illinois
    In my deuce coupe i usede an old delco starter pack and mounted it in the trunk.
    big duece and kadillackid like this.
  20. Gonna be a true running board battery box for me ,on my model T IMG_1187.JPG IMG_1174.JPG
    Bandit Billy likes this.
  21. grdra1
    grdra1
    Mounted my battery under the dash on my 30 coupe. Glen P1010439.JPG P1010441.JPG
  22. krbstr
    krbstr
    On the firewall. I’m lazy and didn’t want to have to crawl under the truck if it needs servicing.
  23. 53 hemi
    53 hemi
    I made a box and put it behind my seat, in the trunk area. One side is for the battery and one is for tools and stuff. There's plenty of gaps in the car; I'm not worried about fumes. 20180828_141423.jpeg 20180828_164834.jpeg
    Sent from my SM-G950U using The H.A.M.B. mobile app
  24. nunattax
    nunattax
    what about routing the vent pipes out through the floor?
  25. Where that becomes a problem at least with a standard battery is venting. Hydrogen even in an open car can be a problem.
    In a sedan with no truck I have been known to mount the battery under the back seat (like a beetle), if the vehicle has a turtle deck or a truck box that is a natural place for a battery.
    When I have a battery in the cab I like to put it in an enclosed box vented to the outside of the vehicle. Paranoid? you bet your ass but you know what they say, "Just because you're paranoid doesn't mean that they are not out to get ya." :D
    olscrounger and dana barlow like this.
  26. 4speed411
    4speed411
    '41 Ford...battery in the box, half into the rear of the cab. IMG_20170704_162426228.jpg
    1933_willys_77 and dana barlow like this.
  27. dana barlow
    dana barlow
    from Miami Fla.
    Old post,but what other then this is going on anyway,good AM to all !.
    I guess even as a teen in the 1950s,I didn't think battery was pretty,so hiding it under seat seemed best. Being my hot rod no longer had a trunk to hide in,and firewall mount seemed the most ugly place of all. Bat has been same place I put it in 1959,but I did replace my first box,with a little bit bigger one for a little bigger bat.
    When my son Lance an I built him a T-bucket,he liked the idea of having it in same place as my old 28A hot rod. So under the seat, in his case a alum hatch cover over the top of bat box. Here's a photo of Lance's "T" going together with seat bottom up .
    Bat box on right! Lift seat bottom and 4 screws gets too bat.[​IMG]
  28. GordonC
    GordonC
    I have a small Braille battery which I stuck up on top of the rear fender well in my roadster. With the gas tank in there and the floor hump to clear the spring there isn't much room for anything and I didn't want to loose more space to the battery. It's a small battery but good cranking power. Hung a kill switch on the side of the mount as well. I may move that to someplace outside the car as it's a pain in the ass to remember it is off after you have gotten into the car! 20191126_141010.jpg
    -Brent- likes this.
  29. Splitbudaba
    Splitbudaba
    D0C5DE9A-A38A-4151-9E62-D777BDC586D1.jpeg Retired from 50 years in General Aviation two years ago. Found a discarded NiCad battery box and cable one day, took them home for future use. So here it will go in my coupe, complete with quick disconnect! Battery will mount inside and the box will be vented with fresh air in and bad air overboard in stainless lines!
    warbird1 and nunattax like this.
  30. Canuck
    Canuck
    Mounted in trunk at end of gas tank. Made two boxes in case battery didn't have enough juice to crank the 425. Boxes made to look like 50 cal ammo boxes, just a little larger. Never used the second one, used as spares and tools box. Battery is a type 51 used in a pile of Hondas.
