Features Falcons done right?
Discussion in 'The Hokey Ass Message Board' started by guiseart, Nov 20, 2005.
  1. RmK57
    RmK57
  2. 62rebel
    62rebel
    post up a pic, I might have a loose one I can give you
  3. loveoftiki
    loveoftiki
    from Livonia,Mi
    Don’t know yet...been trying to get it wrapped up..between work and now COVID haven’t done anything to it..last thing that got done was getting the headers on it and plugs in..no easy feat..had to make some tools....gotta get a new fan, a spacer, and a trans cooler, bend all the lines for fuel and trans cooler, mount and hook up gauges, get shifter hooked up, and get u joints on and drive shaft installed..then gotta break it in...Gave Comp my parts list and my desire to have power from 1800-6000 rpm, told them I’d run premium fuel, and they did the cam..really compression is about 10.8:1..but close enough..should be a Snappy little motor..
    Basically I used some some of the info below..and Alex knew his stuff..I opted for better heads..and aluminum will allow a little more CR..also have a 3 core aluminum radiator and hi flow aluminum water pump..I’m hopeful for 350 hp...should be a real fun little car..
    http://mustangsandmore.com/ubb/BudgetSmallBlock.html
    MUNCIE likes this.
  4. loveoftiki
    loveoftiki
    from Livonia,Mi
    Saw this on FB Marketplace..nicely done little street car 068CAA51-B0A4-4ACE-97B6-59C40C5E5D7A.jpeg 8119FCC6-8CE5-4341-B88A-77E2EC040B30.jpeg
  5. Nailhead A-V8
    Nailhead A-V8
    Yeah that little mod of using the stock wheel arch from a pair of front fenders for the rear wheel arch is the only way to get any rubber under a Falcon... and so subtle compared to a custom (bondo) flare
  6. gimpyshotrods
    gimpyshotrods
    1990-1992 Ford Ranger 8.8. 1/2" wider than stock.
    Or, Explorer 8.8, narrowed to use two short-side axles.
    Both were made by the hundreds of thousands, and are currently in yards.
    Gammz, 62rebel and Nailhead A-V8 like this.
  7. Nailhead A-V8
    Nailhead A-V8
    what's the bolt pattern? seems to me it's the old chevy pattern? or is it the same as 60's
    ford 5 lug?
  8. gimpyshotrods
    gimpyshotrods
    Both the Ranger and Explorer are 5-on-4-1/2", same as Ford p***enger car, of the US Falcon era.
    Nailhead A-V8, Gammz and 62rebel like this.
  9. Boulderdash
    Boulderdash
  10. gimpyshotrods
    gimpyshotrods
    I used Falcon front arches. I tightened the radius a bit, and mounted them lower back than the fronts.
    MUNCIE, brEad and 62rebel like this.
  11. 62rebel
    62rebel
    I have two sets of those I've been holding onto for years. Need me another round body tudor
    gimpyshotrods likes this.
  12. loveoftiki
    loveoftiki
    from Livonia,Mi
    Anybody got a T Bolt hood they wanna part with for a 64-65 Falcon?
  13. gimpyshotrods
    gimpyshotrods
    They are starting to creep up in price. Folks used up all of the Mustangs.
  14. Boulderdash
    Boulderdash
    Very nice. So this allows larger rear wheels?
    Digging the fuel filler cap mod too
  15. gimpyshotrods
    gimpyshotrods
    The fuel filler is from an XJ Jag. The cap is not featured in the picture, as that primer was wet there.
    This is one step to larger wheels.
    The wheel houses in Falcons part company with the quarter panel at the wheel arch. From there, they move inward quite quickly.
    That tends to interfere with a wider tire, especially so if lowered.
    I added these.
    62rebel and RmK57 like this.
  16. 62rebel
    62rebel
  17. 62rebel
    62rebel
    Not so much a creep up, but a flying leap. I've bought nice, solid Falcons for a hundred bucks, but those days are long gone. The last round body I bought was $1100 and I thought it was a great deal.
    Gammz likes this.
  18. gimpyshotrods
    gimpyshotrods
    Here in the land of Neverwinter, an unmolested round body can fetch $6-8K, and then you start your project.
  19. raven
    raven
    Man I wish I could find a good 60-1 for that kind of money.
    r
  20. CGuidotti
    CGuidotti
    1965 Falcon, my daughters daily driver in high school. 6 cylinder with a auto, lowered it a couple inches, smooth driving car. She’s off to college, and it’s just sits in the back yard. My son wants to make it into a g***er haha
  21. RmK57
    RmK57
    Looks like to nice a car to hack up into a g***er.
    CGuidotti and gimpyshotrods like this.
  22. loveoftiki
    loveoftiki
    from Livonia,Mi
    No on the G***er..but a hot 302 and some cast grey Americans and that thing is money..
  23. Gammz
    Gammz
    from Lincoln Ne
    It’s money as it sits.
  24. gimpyshotrods
    gimpyshotrods
    Hell yeah it is. That car is finished. I would drive the wheels off of it, put them back on, and do it again.
  25. loveoftiki
    loveoftiki
    from Livonia,Mi
    It does look really nice....
    loudbang and CGuidotti like this.
  26. loveoftiki
    loveoftiki
    from Livonia,Mi
    Nice one on FB Marketplace over by me..I got way more than this into mine and it’s not done yet...checks a lot of boxes...hot 289, 4 speed, 9 inch...18K...timing is everything they say.. 4BBED6A6-A36A-4026-B517-DB88637290FC.jpeg 0B1E387F-A69C-4008-9534-08E9E7F81330.jpeg BEBDBD73-6854-441C-8726-1F3C7DFF9125.jpeg 6FDF52D6-7345-499F-94B0-11E3CF7A35F4.jpeg
  27. gimpyshotrods
    gimpyshotrods
    No V8 is required to cruise. I don't have one in mine, and I can haul comfortably at 85, all day.
    brEad likes this.
  28. loveoftiki
    loveoftiki
    from Livonia,Mi
    This is a wild concept...anyone wanna guess.. CEBFF657-528D-46A8-9068-78FE903438B7.jpeg
  29. gimpyshotrods
    gimpyshotrods
    1961 Impala bubble top, grafted on a 1963 Falcon Sprint.
  30. loveoftiki
    loveoftiki
    from Livonia,Mi
    Close.....think small version of said GM product..it was deemed a death trap...
