Technical Multi Carb Setups -Let's see 'em!
Discussion in 'The Hokey Ass Message Board' started by pkhammer, Apr 11, 2020.
  1. indianmark
    indianmark
    Cragar intake with 97's and straight linkage on a 56 354 in a 31 Plymouth PA
    pkhammer likes this.
  2. johnnymac1
    johnnymac1
    My triplets, large logo Holley bowls,
    Dyno Dave, WC145, Lil'Alb and 16 others like this.
  3. rbrewer
    rbrewer
    My Offenhauser 4 x 2 with Roch. 2 GV's (SBC) , special thanks to Tim Bowman at Old School Induction!, This for a future project (tbd).
  4. ramblin dan
    ramblin dan
  5. BigRRR
    BigRRR
    6-97's 371 Olds in my 50 Merc!!!
    Dyno Dave, WC145, Lil'Alb and 15 others like this.
  6. swade41
    swade41
    from Buffalo,NY
    Well I missed out on this one, drug my feet contacting the seller, looks like I'll keep my 2x4's on the T Screenshot_20200415-223944_Facebook.jpg
    Dyno Dave, WC145, Lil'Alb and 9 others like this.
  7. 2OLD2FAST
    2OLD2FAST
    from illinois
    Dummy carbs (sigh) , an insult to hotrodders everywhere....
    WC145 and Blue One like this.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    sorry man, bone stock engine in a custom....
    LOST ANGEL likes this.
  9. 2OLD2FAST
    2OLD2FAST
    from illinois
    Its kinda like the first time you took a " falsie" bra off a girl ....
    Blue One and loudbang like this.
  10. Jalopy Joker
    Jalopy Joker
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    can't say that that ever happened....to me... all the rest of my multi carb setups run all the carbs, If that one had a modified engine I may have made all the carbs work but honestly, I drive that car like an old man, low and slow.. My corvette on the other hand I drive like I don't have a nickel in it....
  12. slick36
    slick36
  13. FrankenRodz
    FrankenRodz
    Dual 2-Barrel Progressive Carter/Webbers on my '49 Chevy Styleline.
    Dyno Dave, WC145, 270ci and 14 others like this.
  14. ssracer
    ssracer
    from oklahoma
    Dyno Dave, WC145, dana barlow and 9 others like this.
  15. jnaki
    jnaki
    upload_2020-4-29_4-0-9.png April-May 1960 Lions Dragstrip
    Hello,
    Our multiple carb set up was first used on a 283 SBCwith 6 Strombergs on an old 60’s Weiand Manifold in March 1960. We bought the 283 long block from a tiny speed shop hidden in a residential area of Long Beach. (kind of like our own, small garage shop) We got the motor completely built with locally bought, speed stuff and put it into our 40 Willys coupe.
    With the 6 Strombergs fully adjusted, it ran well for a first time build. The light weight of the Willys, the 283 SBC with 6 Strombergs got put into the B/Gas cl***. It was compe***ive, but not against the top of the cl***. We were way off those top times and speeds. But, it was our first time build and racing adventure. It was fast for a street legal coupe, but not as fast as the top compe***ors at the time, Jr. Thompson, Doug Cook, K,S. Pittman, Al Hirshfield, etc.
    Then several months later, with more racing under our belts, we upgraded that same motor to a 292 c.i. (plus more internal blower grade speed stuff), went to a new Isky Gilmer 671 Belt Drive and the Edlebrock blower manifold for the 671 blower on this motor in May 1960.
    Since we could not afford the two port Hilborn Injectors at the time, the 6 Strombergs went on a new, flat Weiand manifold on top of the 671
    The initial tune up of the 6 Strombergs on the SBC was hectic, to say the least. Adjusting one carb was hard enough, let alone 5 more. But, let us just say that it took the longest of anything on the first time build. Once, it was adjusted, it made such a great sound when revved up. If you thought a single 4 barrel carb with the air cleaner removed made a ****ing sound, 6 two barrels easily made more horsepower and a more powerful sound.
    Jnaki
    The crazy thing was that later on in the rebuild, when we put the fully adjusted, 6 Strombergs on top of the 671 blower, we thought they were already adjusted and should have run well on the start up… That was not the case. It must have taken us a few more tries to get everything in good working order for the drags. Who needed those fancy, expensive, two port Hilborn Injectors? These Strombergs worked well on top of the 671 and made it super powerful.
    upload_2020-4-29_4-1-51.png Similar 6 Stromberg carburetors on a different manifold for the new 292 c.i. blower grade SBC.
    41 GMC K-18, Dyno Dave, WC145 and 9 others like this.
  16. 65pacecar
    65pacecar
    from KY, AZ
  17. mgtstumpy
    mgtstumpy
  18. bschwoeble
    bschwoeble
  19. bschwoeble
    bschwoeble
    OMG ! So many Fords without a Ford, Mopars without a Mopar. Didn't look to see if any GM without a GM. When will the rioting start ?
    1947knuck and loudbang like this.
  20. cruiserjohn76
    cruiserjohn76
    My 56 324 Olds, three 94's. It's come along way since the last picture, should be running and driving in the next few months. IMG_2566.JPG IMG_2921.JPG
    Dyno Dave, WC145, Jet96 and 19 others like this.
  21. Sonofabob
    Sonofabob
    HarryT, Dyno Dave, WC145 and 16 others like this.
  22. old.hot.rodder
    old.hot.rodder
  23. Bandit Billy
    Bandit Billy
    I ran into a little issue with my trio of 97's on the '34 that I thought might fit well in this thread. With all three carbs open (progressive linkage) the choke plates would **** closed a bit (471 blower) on carbs 1 & 3 and as a result the fast idle cams would create a 1300 PRM idle at the next stop light until I got out and pulled it back manually. I asked Clive @ Stromberg how to remedy and he sent me these
    Simply remove the large fulcrum bolt, pull the detent and spring out of the carb and inset this little piece.
    All you have to do is remove the detent pin and spring pictured here
    and install the new lock out pin $7.50 @ summit Racing
    It engages the holes in the linkage and locks out the choke in minutes. Now only my center carb has a functioning choke on a cable to the dash and I don't have to worry about the outer two hanging up any longer.
    Hope it helps.
    WC145, rod1, dana barlow and 9 others like this.
  24. jailbar joe
    jailbar joe
    no need to justify... your car your way
    Moriarity likes this.
  25. 1low52
    1low52
    Wow!
    Just came across this thread! Pure ****!!!
  26. seabeecmc
    seabeecmc
  27. Stllrng.
    Stllrng.
    Ford Y-block
    Dyno Dave, Deuces, pkhammer and 7 others like this.
  28. Gary in MN
    Gary in MN
    Model A Ford , 4 Stromberg 97's two for show and two for go. Gary in MN DSC00652 (300x169) (2).jpg
    Dyno Dave, WC145, Deuces and 4 others like this.
  29. RACE ROD
    RACE ROD
