Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. Paul
    Paul
    Editor
    a few minutes here and there and pretty soon it starts to look like something
    made some brackets to take the rear rod ends on the four link,
    like the front brackets they were cut from 3/8" plate
    1/4" plate washers were made and welded to them
    to provide enough thickness for the rod ends
    welds cleaned up
    and holes reamed with taper to take the rod ends,
    test fit
    IMG_20200415_123529.jpg IMG_20200415_134256.jpg IMG_20200415_135436.jpg IMG_20200415_141439.jpg IMG_20200415_151333.jpg IMG_20200415_151318.jpg
  2. Paul
    Paul
    Editor
    now where can a guy find short tube shocks like these?
    J_J2, scott27, loudbang and 3 others like this.
  3. alchemy
    alchemy
  4. Paul
    Paul
    Editor
    Thanks! found some on line,
    now to dig around for some F1 mounts...
    I think I have some... somewhere..
    jebbesen, scott27, brEad and 5 others like this.
  5. flatheadgary
    flatheadgary
    from boron,ca
    What are the numbers on the shocks. i also need a pair.
    Stogy and loudbang like this.
  6. Paul
    Paul
    Editor
    I searched shocks by description, didn't get a number.
  7. bct
    bct
    Thanks for the consistant updates. Very welcome distraction .
    Stogy, Paul and loudbang like this.
  8. 31Apickup
    31Apickup
  9. Paul
    Paul
    Editor
    Tacked (short welds) together enough to check action and ride height, rolled outside for pix..
  10. Paul
    Paul
    Editor
    closing in on the front suspension, rear needs some more work, going to break a few tacks and reset the rear spring brackets and fab up a cross member and spring pad..
    body needs to go back on temporarily to locate steering box and brakes.
    the tentative pedal plan is to use an Ansen swing pedal setup turned backwards and under the floor..
    scott27, bchctybob, loudbang and 2 others like this.
  11. Paul
    Paul
    Editor
    and rolling it is a bit of a chore, the posi is in locked mode.. makes it tough to turn..
    I will go through the other pumpkin before it gets swapped in..
    loudbang and Stogy like this.
  12. Paul
    Paul
    Editor
  13. dentisaurus
    dentisaurus
    from Boston
    Like the 4 bar set up, not generally a fan of 4 bars on a hotrod but this works well.
    Atwater Mike likes this.
  14. Paul
    Paul
    Editor
    Kinda where it's headed with the pedal sitch..
    Ansen style swing set placed backwards and under foot..
    It would get pedals cut leaving lever and rod to master with new pedals fabbed
  15. Paul
    Paul
    Editor
    Ford truck steering box, would like to swap out ball type pitman arm for typ tie rod type..
    What year and model should I be looking for? It has the larger 1-1/4" sector shaft..
    J_J2, scott27, loudbang and 1 other person like this.
  16. Paul
    Paul
    Editor
    And a couple more with the body on outside to check overall look..
    IMG_20200416_163345.jpg IMG_20200416_163405.jpg IMG_20200416_163535.jpg IMG_20200416_163549.jpg IMG_20200416_165554.jpg IMG_20200416_165614.jpg
  17. I feel like you build faster than I read. :D Awesome work, love how this one is coming together!
    J_J2, bct, bchctybob and 4 others like this.
  18. Paul
    Paul
    Editor
    Ha! Thanks man
  19. Stogy
    Stogy
    Nice Hotrod @Paul...Have you went for a virtual drive with Motor Sounds yet?...:)...Neat twist on the Double Spilt Bones to...
  20. Paul
    Paul
    Editor
    Thanks!
    Yes, the wife came into my side of the shop and caught me sitting in it dreaming.. I could feel it with all my senses
  21. alchemy
    alchemy
    I can't guarantee, but I think the F-100 boxes from around 1960 had the tapered rod end hole and fit on the older sector too.
    Atwater Mike and loudbang like this.
  22. Paul
    Paul
    Editor
    Thanks, I'll do a little more searching..
    Here's a cropped image from above,
    Again looking for a typical tie rod end style pitman arm with 1-1/4" sector pinch bolt hole to replace my ball style arm.
  23. alchemy
    alchemy
  24. F1 steering boxes had the shaft enter to the bottom side of the box. F100 had the shaft enter to the top side of the box. You have an F100 box.
    53-56 had a ball style pitman arm. 57-60 had a tie rod style pitman arm.
  25. Paul
    Paul
    Editor
    Good to know thanks
    I'm having a hard time finding info on sector shaft diameter
    Both my boxes have the larger 1-1/4" sector shaft
    F250 same years?
  26. loudbang
    Have you decided what style header and exhaust you are going with yet?
  27. Paul
    Paul
    Editor
    Not exactly, I know what I like and I know what I don't like, so at least that's a start..
    Something late '50s- early '60s style..
  28. F250 is the same box, yes. Except 59/60 4x4 which will be a longer(?) pitman arm and a different steering box flange and code. (If you come across one of these, I'll happily buy it off you).
    F100/250 trucks had a 3CC31 code steering box. F100/250 4x4 trucks had a 4CC39 steering box code.
    57-60 F100/250 boxes will have a 1-1/4" sector shaft diameter as well.
    F350 is a completely different box and I do not know if the sector shaft or pitman arm is a similar size.
    loudbang and Paul like this.
  29. Paul
    Paul
    Editor
    Cool, thanks
  30. Paul
    Paul
    Editor
    hate to beat this one to death but
    what would this smaller sector (1-1/8") from my junk pile go to?
