1952-59 Ford Cast Iron Exhaust Manifold
Discussion in 'Off Topic Hot Rods & Customs' started by Flattop Tiki, Apr 18, 2020.
  1. Flattop Tiki
    Flattop Tiki
    No info in the Sticky about stock Mustang cast manifolds.
    Search brought up some info, seems like they fit.
    Reason is I have a line on a set from a '69 Mustang, $100. Haven't seen them in person yet.
    Suppose the question for the group is should I even risk getting cast iron if they may end up cracking? Would ceramic coating help with cracking?
    Cheers!
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    For a 302 swap ?
  3. 54vicky
    54vicky
    as to the coating it will not help to prevent the cranking
  4. Flattop Tiki
    Flattop Tiki
    Yeah a 302 swap.
    So just high heat paint it and be done, if I go that route?
  5. Dave Covey
    Dave Covey
    First, the high heat paint will not last all that long.
    Ceramic coating is the better way to go and even that will eventually be gone. I have had numerous headers coated and they all eventually had rust coming through the coating.. I think a cast manifold may even last longer simply because it doesn't expand and contract like a tube header.
    Just my opinion of course/
    Hey, look at Eastwood they have some nice products for your cast iron stuff.
  6. okiedokie
    okiedokie
    from Ok
    I have some of the brush on coating for cast irons manifolds on the 302 in my 53F100.it has been there for at least 20 years and still looks good. I used the same for the ones on my 55. Great stuff for sandblasted cast iron manifolds. It cures as you drive.
  7. JeffB2
    JeffB2
    from Phoenix,AZ
  8. JeffB2
    JeffB2
    from Phoenix,AZ
