Features Corvette hot rods - picture thread
Discussion in 'The Hokey Ass Message Board' started by KING CHASSIS, Jan 1, 2011.
  1. loudbang
  2. elgringo71
    elgringo71
  3. 31hotrodguy
    31hotrodguy
    On my phone screen and when in the app it is hard to enlarge the picture. The position of the valve covers looks more straight up and down plus looks narrow..... ie a little nailheadish. After I saved the picture and enlarged it although grainy I could see the exhaust spacing but I still couldn’t see the normal head castings.
    Deuces, loudbang, scotty t and 2 others like this.
  4. What he said^^^^^^:D
  5. loveoftiki
    loveoftiki
    from Livonia,Mi
  6. loveoftiki
    loveoftiki
    from Livonia,Mi
  7. Dave Gray
    Dave Gray
  8. loveoftiki
    loveoftiki
    from Livonia,Mi
  9. enloe
    enloe
    from east , tn.
    I am looking at this thread to get inspiration. I have been working on mine today. New shocks and just took the starter off. It is shot. I will get one tomorrow. Then after I get it in and put the exhaust pipe back on I will take the instrument cluster out and chase some gremlins.
    mkebaird, LowKat, 31hotrodguy and 6 others like this.
  10. primed34
    primed34
    Do you have a good rebuild shop in your area? Parts store starters are usually **** these days. Free replacement ain't worth a damn if you have to go thru 2 or 3 to get one that works.
  11. Deuces
    Deuces
    Yep! What he^^^^^sez.....
  12. DDDenny
    Enloe
    Check the starter bolts for correct GM(knurled) shanks.
    chryslerfan55 and Bowtie Coupe like this.
  13. enloe
    enloe
    from east , tn.
    Our local place that did rebuilds burned. I may try to get a GM starter or a mini starter.
    it does have the knurled bolts. I believe it is the original.
  14. loudbang
  15. loveoftiki
    loveoftiki
    from Livonia,Mi
  16. enloe
    enloe
    from east , tn.
    That is so BAD***
    loudbang, scotty t and Deuces like this.
  17. rumblegutz
    rumblegutz
    Enloe FWIW if your interested the part number 1107320 will be roll stamped on the armature case with a date code of the day it was manufactured. If it is original to your car the date will be shortly before the build of the car.
  18. loveoftiki
    loveoftiki
    from Livonia,Mi
    Detroit Dragway...
    mkebaird, tommyd, jackal396 and 12 others like this.
  19. Dave Gray
    Dave Gray
  20. 65pacecar
    65pacecar
    from KY, AZ
  21. 65pacecar
    65pacecar
    from KY, AZ
    mkebaird, 1947knuck, Deuces and 4 others like this.
  22. 65pacecar
    65pacecar
    from KY, AZ
  23. It’s good to see you back Enloe! I haven’t seen you around much for some time.
  24. 31hotrodguy
    31hotrodguy
    What, no roll bar?
  25. Fairground Queen
  26. enloe
    enloe
    from east , tn.
    I appreciate it.
    I have been just lurking in the background. I hope soon to be posting more. I am hoping our annual guy trip to Bowling Green is not cancelled.
    I just placed a order at Rockauto for a new AC Delco starter for my 66. I believe that it will be here around the first of the week.
  27. loudbang
    posted by swi66 in the vintage thread
  28. uncleandy 65
    uncleandy 65
  29. Corn Fed
    Corn Fed
    That red/white '61 above is confused. With the off color painted hood, scoop and side dump exhaust I think they are trying for a racer look. But those rallye rims with rings, baby moons, and pinner whites does not scream fast to me.
    Of course, it's way better than the 4x4 '41 Merc 4dr in the background :eek:.
  30. jimdillon
    jimdillon
    The 62 posted by LB above I believe is Frank Dominianni's car. Pretty successful road racer from NY I believe.
